    Duet/RRF Big printing problems
    4.6k
      Your thermistor config is incorrect, it should be B4725. See https://e3d-online.dozuki.com/Guide/V6+RepRap+Firmware+Configuration/26?lang=en. That means you have been printing at the wrong temperature. HTH David
      pro3dundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • pro3dundefined
        pro3d @dc42
        Thanks - Does this mean the config online tool gives another value than what it should have?
        Valkyrie DIY High Temp 3D Printer
        R&D - Engineering Designer - Viking 3D Printers
        https://vkingprinter.com/
          Phaedrux Moderator @dc42
          @dc42 said in Duet/RRF Big printing problems:
          The configurator gives M305 P1 T100000 B4388 C7.060000e-8 R4700 when The E3D Semitek-104 GT2 option is selected. It looks like that may have been correct for firmware versions older than 1.16, but the configurator seems to have not been updated to give the new values for firmware versions 1.17 and above.
          I recently swapped a burnt out PT100 sensor for the E3D Semitek GT2 and used the values from the configurator for it, oddly enough I didn't notice any temperature related issues for the week or so I used it while waiting for a replacement PT100.
          • pro3dundefined
            pro3d @Phaedrux
            @phaedrux
            Nice catch about the E accel - I did not ever change this at any point in Marlin so I did not know its value. I will test your recommendations
            • pro3dundefined
              pro3d @Phaedrux
              @phaedrux
              How ever max accel is overided by these values in Marlin no?
              #define DEFAULT_ACCELERATION 1000 // X, Y, Z and E acceleration for printing moves
              #define DEFAULT_RETRACT_ACCELERATION 2000 // E acceleration for retracts
              #define DEFAULT_TRAVEL_ACCELERATION 1000 // X, Y, Z acceleration for travel (non printing) moves
                Phaedrux Moderator @pro3d
                @pro3d That would depend on how the slicer is sending acceleration values, if you are using those settings.
                Still, the file you posted has higher limits set than 1000,2000
                 * Default Acceleration (change/s) change = mm/s
                 * Override with M204
                 *   M204 P    Acceleration
                 *   M204 R    Retract Acceleration
                 *   M204 T    Travel Acceleration
                #define DEFAULT_ACCELERATION          1500    // X, Y, Z and E acceleration for printing moves
                #define DEFAULT_RETRACT_ACCELERATION  3000    // E acceleration for retracts
                #define DEFAULT_TRAVEL_ACCELERATION   1500    // X, Y, Z acceleration for travel (non printing) moves
                pro3dundefined 1 Reply Last reply Reply Quote 0
                • pro3dundefined
                  pro3d @Phaedrux
                  @phaedrux
                  I dont know how slicer sends values I am sorry
                    Regardless of what the differences in settings between marlin and reprep, the issue as presented is retraction related. And the solution to reduce the blobs at the layer seam is to try and make the extruder more responsive. Faster retractions in combination with pressure advance to reduce the need for retraction distance.
                      @pro3d said in Duet/RRF Big printing problems:
                      @phaedrux
                      For Cura you'd have to specifically enable it. By default the accel and jerk settings are hidden.
                      In RepRap the M204 command works differently than in Marlin though. In Marlin it controls acceleration for Print moves, Travel Moves, and retraction. Where as in RepRap it's only Print and Travel moves. Retraction acceleration is dictated by M201.
                      • pro3dundefined
                        pro3d
                        Update - Progress is present 🙂
                        So I changed 3 things and I know this is stupid but at least it shows progress. It might just have been the thermistor but I need to run more tests later today
                        1. I changed thermistor to B4725
                        2. Upped E-accel from 1000 to 3000
                        3. Upped E-jerk from 600 to 900
                        PETG test at same model and filament as before
                          dc42 administrators @pro3d
                          @pro3d, I'm glad you are making progress. It sounds that the online configurator is setting the incorrect thermistor B value when you choose the Semitec thermistor. I'm sorry this has caused you so much trouble. We'll get it fixed.
                          grizewaldundefined 1 Reply Last reply Reply Quote 1
                            deckingman
                            If you take a gander at Semitec specs, the GT-2 is now superseded by the NT-4. http://atcsemitec.co.uk/product-category/glass-thermistors/
                            The 104NT-4 has a quoted B value of either 4267 or 4390 depending on type https://atcsemitec.co.uk/wp-content/uploads/2019/01/Semitec-NT-4-Glass-NTC-Thermistor.pdf
                            But what is interesting is that the resistance tolerance is quoted as +/-3% and the B value tolerance is +/- 2%.
                            Which brings me back to what I said earlier that there is no substitute to finding what temperature actually prints best. e.g. if you have one machine that prints fine at 200 deg C and the thermistor is at one end of the tolerance band, then the actual temperature could be 3% or 6 degrees lower so 194 deg C. A second machine using the same thermistor but at other end of the tolerance band might actually print 6 degrees higher so setting 200 deg C could result in an actual temperature of 206 deg C which would likely lead to blobs and stringing. That's an extreme example but I believe it serves to illustrate the point I have been trying to make.
                              Bear in mind that the B value quoted in the data sheet is invariably over a small temperature range, typically 25C to 75C. It's not accurate over the larger ranges of hot end temperatures. Also, when you use the C parameter in M305, you need to use a lower B value. So B4388 is correct if you don't use a C parameter, but B4725 with the C parameter is more accurate.
                              • pro3dundefined
                                pro3d @Phaedrux
                                @phaedrux
                                I am struggling to get the plugin activated. I did not find it in marketplace but downloaded it from a um forum post - Is is jsut to drop in the plugin folder?
                                [0_1549572902627_PrinterSettingsPlugin.curaplugin](Uploading 100%)
                                  I think you double click on the plugin file to install it? I can't remember, but I'm pretty sure it's available in the market place now. I'll have to double check. There should be some installation instructions where you downloaded it from.
                                  • pro3dundefined
                                    pro3d
                                    I might have been a little early to celebrate. Guess its time to look for component trouble or filament issue
                                      Is the extruder idler tensioned properly?
                                      pro3dundefined 2 Replies Last reply Reply Quote 0
                                      • pro3dundefined
                                        pro3d @Phaedrux
                                        @phaedrux
                                        I was thinking NO so I did re-tension it now so it extrudes fine at 30mms without skipping/ripping the filament and re printed the part above so no luck there
                                        looks to hot and this is the suppliers suggestions for everything. I think speed and temp look to high but wanted to test their settings /add.North
                                        • grizewaldundefined
                                          grizewald @dc42
                                          @dc42 Please can you also update the text at: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Heater_and_thermistor_section
                                          This states: "The Semitec 104GT-2 thermistor supplied with the E3Dv6 hot end has a quoted B value of 4267, but the actual value over 25C to 220C is 4388."
                                          Given that text, and what the online configurator suggested, that's what I'm using.
                                          I'm chasing similar problems to pro3d as well, also on a CoreXY with a 700mm long Bowden tube (Capricorn) fed via a Bondtech BMG extruder. While I am getting there, I'm still seeing what look like over-extrusions at the layer changes, so I'm following this thread with interest.
                                            dc42 administrators @grizewald
                                            @grizewald said in Duet/RRF Big printing problems:
                                            Thanks, I've updated it.
