microSD card for 0.6 Duet board with RRFw v 0.78b
That looks OK, but you need to look at it from just above the main processor. Sometimes it's evident that the pins on the right hand (as seen from that angle - it's the left hand end in your photo above) end of the row are just sitting on the PCB pads instead of being soldered to them.
Is the SD card pushed into the socket far enough so that it clicks, and you have to push it again to release it?
@dc42 or ?
I try to seat the card properly; have used canned air to blow out to no effect.
Reflowing the soldered joints is next on the list; spare parts are in the post... in case the hot air melts the plastic part
I can't be certain because that part of the photo is a little out of focus; but the joints look OK to me. It's usually clear when the joints are bad.
If the joints at the back of the SD card are bad, it's easier to mend them using a no-clean flux pen and a fine-tipped soldering iron than with hot air.
The other likely possibilities are a bad or damaged contact in the socket, a damaged processor, or a bad soldered joint on one of the processor pins that connects to the SD card. Or just possibly a short (solder bridge) between 2 processor pins, but that's less likely.
Where in the UK are you?
@dc42 Lincolnshire
Have you tried to reading the files on your computer? Have you checked the file system matches what is expected? The duet maybe case sensitive.
@cn said in microSD card for 0.6 Duet board with RRFw v 0.78b:
@dc42 Lincolnshire
That's a long way from me (Somerset).
@dc42 it is There’s a town here which shares a name with a village down there…
@doctrucker the Duet seems unable to read any microSD cards presently.
Have replaced the microSD socket; the problem persists.
If the Duet used to be able to read SD cards, then sadly the most likely reason it won't now is that one of the microcontroller interface pins is no longer working. It's possible to replace the microcontroller, but not easy. I wrote off the first two Duets that I tried to replace the microcontroller on, by lifting PCB traces. The 3rd and 4th I did successfully.
@dc42 I'm not sure it's ever read uSD cards since I've had it
Hopefully this morning's soldering is still viable ![endoscope view of Duet SD socket]()
https://.chrs.nl/cloud/index.php/s/9q4X9Nfyh9Y9broA new board is outside my current ad hoc budget ...
Was it offered for sale in "known to be fully working" state?
@dc42 was part of a printer listing; operative state unspecified
@dc42 if M122 reports that the board has reset itself via software and/or that the MCU temperature is around/above 100°C the Duet is in a bad way?
You may want to run this procedure to calibrate the CPU temp, since it could be up to 45c off on the older boards. Even so, that would seem high to me.
https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
How warm does the MCU feel? It should be no more than slightly warm.
@dc42 it was becoming too hot to touch before the SD slot replacement; hence the heatsink
To answer @Phaedrux, it would be hard to calibrate without configuration provided by the microSD card in normal circumstances.
I expect the extruder could be configured in the console; and its thermistor connected to provide a figure for those commands.
I tried pointing a laser thermometer at the heatsink to get some idea of how hot the MCU was getting before disconnecting power when it reached the 80s per M122
That indicates that the processor needs to be replaced. It should be cool or barely warm to the touch.
You didn't overclock it did you? Glaring eye
I am just playing. Althought it sound like you amp is high Does is your ethernet POE? I don know if that is a problem. but maybe even touch up the pins on your mcu chip and the usb. (maybe sure you use the no voltage module when connect it via usb. Dc42 would know more of course but just thought i would try my thoguhts.
@dc42 well, I’ve attempted a chip replacement. Despite some lifted tracks there’s minimal remedial rework needed as far as I can tell…
I have no intention of powering up until I’ve dealt with the obvious bridge.
