    Duet wifi lost web connection
    web control lost connection
    11
    37
    4.6k
    • avaradusundefined
      avaradus @dc42
      @dc42 See the video https://youtu.be/psSlSt5nMyk
      I'm trying send command M122 but result is truncated and not full =(
      whosrdaddyundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • whosrdaddyundefined
        whosrdaddy @avaradus
        @avaradus use YAT instead of Pronterface (and don't forget to set the line ending to <LF> in YAT)
        avaradusundefined 1 Reply Last reply Reply Quote 0
        • avaradusundefined
          avaradus @whosrdaddy
          @whosrdaddy Trying YAT and nothing changes. IMHO problem in firmware, does not send complete data.
          • Adrian52undefined
            Adrian52
            I have a similar sounding problem, using a 1.01 duet wifi and most recent rc firmware, dwc2. When connection is lost, even rebooting the host PC and restarting browser (firefox) doesn't help. The print continues to finish perfectly. With YAT, M122 gives no response (on earlier occasions I have had a truncated response). M552 S-1 switches off the wifi, and M552 S1 switches it on, but still no connection. Board responds to M999 with reset, but M122 then gives a partial response and halts YAT with the error message 'an unhandled asynchronous non synchronised exception occurred while running YAT' the detailed info 0_1556045927327_20190423_yat_exception.txt
            On restarting YAT, M122 then works fine.
              YAT can be a bit funny when the USB COM port disappears and the reappears, as it does when you reboot the Duet.
              My guess is that the Duet is running out of buffer RAM, but I don't know why.
              @Adrian52 , which versions of firmware (main and WiFi) exactly are you running? How many PC/tablets/smartphones are or have accessed the Duet since it was originally powered on or reset?
              Adrian52undefined 1 Reply Last reply Reply Quote 0
              • Adrian52undefined
                Adrian52 @dc42
                @dc42 I am on main 2.03beta3(2019-03-25b6), WiFi 1.23, dwc 2.0.0rc6. I am only connecting via win10 pc/Firefox - deleted the duet app from phone and tablet at the moment, to eliminate concurrent connections.
                Have the impression that this is a progressive thing - I initially get no response to M122, then M122 triggers a disconnect /reconnect, then connection is lost with multiple retrys from dwc.
                  It's possibly a progressive loss of message buffers, which prevents both a full status response to DWC and a full M122 report.
                  Is it any different if you use DWC 1.22.6 instead of DWC2? You can revert to DWC 1.22.x just by putting "/reprap.htm" after the Duet IP address in your browser address bar.
                  • Adrian52undefined
                    Adrian52 @dc42
                    @dc42 same behaviour when using dwc 1.22 with the ip/reprap.htm method
                      I guess I'll have to start leaving my printers on overnight to see if I can reproduce this. Does the problem occur if you leave the printer idle for 2-3 days, or only if it is printing?
                      Adrian52undefined avaradusundefined 2 Replies Last reply Reply Quote 0
                      • Adrian52undefined
                        Adrian52 @dc42
                        @dc42 away for the weekend - will check next week
                        • Adrian52undefined
                          Adrian52 @Adrian52
                          @adrian52 I think I may have found the answer for my issue - this comment on a thread yesterday rang a bell:
                          gnydick 1 May 2019, 07:33
                          One possibility. I found I have a DC power brick plugged into the same circuit that is SQUEEEEELING, I think a cap is ready to blow. That could be interfering.
                          I had a noisy DC brick supplying a desk lamp next to the duet. Since I unplugged it, I have had the printer on all day with no lost connection or failed M122
                            Phaedrux Moderator @Adrian52
                            @adrian52 said in Duet wifi lost web connection:
                            That's interesting. Why would that be?
                            • avaradusundefined
                              avaradus @dc42
                              @dc42 In my case, this happens when it is printing
                                dc42 administrators @avaradus
                                @avaradus said in Duet wifi lost web connection:
                                Does it get as far as displaying the "Used output buffers" bit? That's the 4th line down from the top.
                                • avaradusundefined
                                  avaradus @dc42
                                  @dc42 Yes, that is right 20 of 20 max. How can i increase the number of buffers?
                                    I will increase the number of buffers in the 2.03 release, however I am not sure that increasing the number of buffers is the solution. The question is, why are all the buffers allocated and not getting released?
                                    Do you access the Duet via the web interface from a single device (PC/tablet/smartphone), or from multiple devices? Many firmware versions ago there was a problem with buffer management if you turned a device off without disconnecting it from the Duet in DWC first; but that was fixed (it now times out and releases the buffers for that client after 10 seconds of inactivity form the client).
                                    You can monitor the number of buffers when the machine is idle. When I run M122 from DWC with just a single web client and an attached PanelDue, it reports either 1 or 3 buffers allocated.
                                    • avaradusundefined
                                      avaradus @dc42
                                      @dc42 I have only one computer and one connection to the web interface.
                                      DWC too often sends requests. When many requests fail, repetitions are performed without a timer delay. IMHO at this moment buffers overflow.
                                        @avaradus, I'll ask chrishamm how long DWC waits for a response before timing out and sending another request.
                                        Next time this happens, please try closing the browser tab that DWC is open in. Then wait more than 10 seconds, and after that either use YAT to send M122 and check whether the buffers have been released, or try reloading DWC. What should happen is that if DWC doesn't receive any traffic from an IP address in 10 seconds, it should time out that client and release any associated buffers.
                                        • avaradusundefined
                                          avaradus @dc42
                                          @dc42 Now again it happens. I'm connect via USB and send M122. And i see Used output buffers: 15 of 20 (20 max).
                                          Then i wait 10 secs, i wait 30 secs, i wait 30 minutes and nothing changes.
                                          i see the Used output buffers: 15 of 20 (20 max).
                                          I try to turn off Wi-Fi with M552 S-1
                                          WiFi module stopped
                                          Again send M122
                                          And still nothing has changed: Used output buffers: 15 of 20 (20 max)
                                          DWC cannot connect and results M122 truncated and not full again.
                                          • Anidalundefined
                                            Anidal
                                            I confirm the problems with the Wifi connection in 2.03RC1. In combination with HTTP + FTP, the connection was extremely unstable, it was impossible to transfer files over hundreds of bytes either via http or ftp.
                                            Editing config.g to disable ftp caused it to self-delete when writing.
                                            Recovered on sd card from backup.
                                            In the only http mode, it became possible to record files, but the recording speed dropped 10 times.
                                            M122
                                            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03RC1 running on Duet WiFi 1.02 or later + DueX5
                                            Board ID: 08DGM-9T6BU-FG3S8-6J1DJ-3SD6P-1SKMF
                                            Used output buffers: 3 of 24 (11 max)
                                            Static ram: 25656
                                            Dynamic ram: 94672 of which 28 recycled
                                            Exception stack ram used: 492
                                            Never used ram: 10224
                                            Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3752) IDLE(ready,156)
                                            Owned mutexes:
                                            Last reset 05:55:41 ago, cause: software
                                            Last software reset at 2019-05-12 13:42, reason: User, spinning module GCodes, available RAM 10128 bytes (slot 1)
                                            Error status: 24
                                            Free file entries: 8
                                            SD card longest block write time: 403.7ms, max retries 0
                                            MCU temperature: min 30.7, current 35.9, max 36.7
                                            Supply voltage: min 0.5, current 24.2, max 24.5, under voltage events: 1, over voltage events: 0, power good: yes
                                            Driver 0: ok, SG min/max 0/1023
                                            Driver 1: ok, SG min/max 0/1023
                                            Driver 2: standstill, SG min/max 0/93
                                            Driver 3: standstill, SG min/max 0/1023
                                            Driver 4: ok, SG min/max 0/1023
                                            Driver 5: standstill, SG min/max not available
                                            Driver 6: standstill, SG min/max not available
                                            Driver 7: standstill, SG min/max not available
                                            Date/time: 2019-05-12 19:37:56
                                            Slowest loop: 123.17ms; fastest: 0.06ms
                                            I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                                            Hiccups: 58, FreeDm: 163, MinFreeDm: 106, MaxWait: 10107016ms
                                            Bed compensation in use: none
                                            === DDARing ===
                                            Scheduled moves: 238342, completed moves: 238317, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
                                            Heater 0 is on, I-accum = 0.0
                                            Heater 2 is on, I-accum = 0.4
                                            Segments left: 1
                                            Movement lock held by null
                                            http is idle in state(s) 0
                                            telnet is idle in state(s) 0
                                            file is doing "G1 X94.042 Y115.929 E0.22561" in state(s) 0
                                            serial is idle in state(s) 0
                                            aux is idle in state(s) 0
                                            daemon is idle in state(s) 0
                                            queue is idle in state(s) 0
                                            Code queue is empty.
                                            === Network ===
                                            Slowest loop: 404.11ms; fastest: 0.00ms
                                            Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                            HTTP sessions: 1 of 8
                                            • WiFi -
                                              Network state is running
                                              WiFi firmware version 1.23
                                              WiFi MAC address cc:50:e3:14:fc:fb
                                              WiFi Vcc 3.30, reset reason Turned on by main processor
                                              WiFi flash size 4194304, free heap 19184
                                              WiFi IP address 192.168.1.6
                                              WiFi signal strength -66dBm, reconnections 0, sleep mode modem
                                              Socket states: 0 2 0 0 0 0 0 0
