    Warning Light for Bed temp
    19
    1.2k
    • PaulHewundefined
      PaulHew
      Hi.
      I would like to have a physical warning light to indicate the bed is still hot, ie over say 35 /40 degrees.
      I have 24v LEDs to indicate that the bed and hotend is 'On' but would like a way to show that the bed is still hot, is this possible?
      I have asbestos fingers but someone else might not!
      Thanks in advance. BTW i have a Maestro.
      deckingmanundefined 1 Reply Last reply Reply Quote 1
        jay_s_uk
        Use a fan output and link it to the bed as you would a fan for cooling the hotend.
        E.g. M106 P2 T35 H0
          deckingman @PaulHew
          @paulhew As fans can be configured to run thermostatically, then one way would be to connect an LED to spare fan connector and map this to the bed heater. So something like M106 Pn S255 I0 F250 H0 T40 should work. Where "n" is the number of the fan connector. H0 is the bed heater. T40 is the temperature at which the "fan" would come on, in this case 40 deg C.
          Or if you wanted, you could vary the brightness of the LED by using something like T35:60 with maybe a low threshold of like L125. That would light the LED at 50% when the temperature is 35 deg C or above, rising to 100% at 60 deg C and above. You'd need to play around with those values.
          EDIT. I was typing my response at the same time as others so didn't see their answers.
          • aidarundefined
            aidar
            I belive you can use fan2 pins for that, of course assuming they are not in use already. Configure it as thermostatically controlled fan monitoring bed heater.
            https://duet3d.dozuki.com/Wiki/Gcode#Section_M106_Fan_On
            • PaulHewundefined
              PaulHew
              Thanks to @aidar @deckingman and @jay_s_uk
              I am using all of my fan outputs, P2 is used for the case cooling fan, P1 for hotend and P0 for part cooling.
              I do have a spare heater output (E1) which I was going to use for LEDs, could I use that?
              I thought one of the spare pins I have like on the expansion header or somewhere else could be used.
              Thanks again.
                jay_s_uk @PaulHew
                @paulhew You can use the hotend too.
                The A parameter can be used to assign a fan to a different output pin, for example a spare heater output (use a M307 command to disable the heater and free up the pin first).
                From the info for M106 from the wiki.
                Is your case cooling fan always on? If so, switch that to one of the always on fan outputs.
                • PaulHewundefined
                  PaulHew
                  So I have issued the following command to disable the heater2, my spare heater port.
                  M307 H2 A-1 C-1 D-1
                  When I send the next command I get this
                  M42 P3 S0
                  Error: M42: Logical pin 3 is not available for writing
                  Obviouly I am doing something wrong, I am not a GCode wizard!
                  This board is a Duet Maestro
                    dc42 administrators @PaulHew
                    @paulhew said in Warning Light for Bed temp:
                    M42 P3 S0
                    P3 is Heater 3. Use P2 in that M42 command.
                    PaulHewundefined 1 Reply Last reply Reply Quote 0
                    • PaulHewundefined
                      PaulHew @dc42
                      @dc42 Thank You David.
                      Doh! LED now works.
                      I was going to write a line like this which I use for my can fan control
                      M106 P2 T25:65 L128 H100:101:102 ;Case fan temp control
                      So
                      M106 P2 T35:100 H0
                      But I can already see the issue in regards to the P2. Can I map the logical pin2 to a new fan number, so I can use P3 in that line?
                      Or am I going about this the wrong way?
                      • DocTruckerundefined
                        DocTrucker
                        80C thermal normaly open (at room temp) switch. No software involvement needed.
                        PaulHewundefined 1 Reply Last reply Reply Quote 1
                        • PaulHewundefined
                          PaulHew @DocTrucker
                          @doctrucker said in Warning Light for Bed temp:
                          Sorry, I do not understand.
                          I would like the lamp to be lit if the bed is still hot, I have a glass bed and it takes a while to cool and I do not always have DWC open, hence by using code so it can read the temp and light the LED if conditions are met.
                            A Former User
                            Search for KSD-01F and you'll find lots of cheap chinesium parts that will work, just pick a temperature and a normally open (NO) part.
                            Run the lamp in series with the bimetallic switch attached to the bed, it will only conduct if above its marked temperature. It will work with the only requirement being that power supply is on.
                              DocTrucker @PaulHew
                              Hi @paulhew. @bearer beat me to it.
                              In a nutshell it's the reverse of a kettle bimetallic switch, but self resets.
                              It closes once the switch hits a certain temperature and opens once it cools below that temp give or take a little hysteresis. Commonly used as a really simple fan controller.
                                Yes, you can use:
                                M106 P3 A2
                                then fan 3 will be mapped to heater 2 output.
                                • PaulHewundefined
                                  PaulHew @dc42
                                  @dc42 said in Warning Light for Bed temp:
                                  M106 P3 A2
                                  Thanks DC.
                                  After disabling H2 again, even though it is in my config.g, I tested to make sure the LED illuminates which it does, then issued your string.
                                  M106 P3 A2
                                  Error: M106: Fan number 3 is invalid, must be between 0 and 2
                                  Should it work with a Duest Maestro?
                                  P.
                                    M106 P3 A2
                                    Thanks DC.
                                    M106 P3 A2
                                    P.
                                    Good point, the Maestro is limited to 3 fans in RRF 2. The RRF3 early beta for the Maestro supports 4 fans, but the way you setup the pin mapping is different. See https://forum.duet3d.com/post/91906 if you want to try it.
                                    • PaulHewundefined
                                      PaulHew
                                      Thanks David.
                                      I could move one of my fans, like the case fan.
                                      I was going to ask in the rrf3 forum, but can I take a decent ssd card, format it and drop rrf3 on it an keep my original card and swap if need be?
                                      Thanks again David and all, it is appreciated.
                                      Ask me a network question or something about model helicopters and I could help back!
                                      dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        @paulhew, a copy of your existing config should work except as described at https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview.
                                          Phaedrux Moderator @PaulHew
                                          Thanks David.
                                          The firmware doesn't reside on the SD card itself, rather, the bin file for the firmware is written onto the board itself, so to swap between firmwares you would need to reflash each time.
