    First Test Print following Duet3d Upgrade
    3.2k
      The maximum speed and jerk of your extruder is quite low. At the very least this can impact your retraction speed and could impact pressure advance if and when you decide to try it.
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z600.00 E600.00 ; Set maximum speeds (mm/min)
      Try M566 E1200 and M203 E6000
      It's hard to see from the picture because it's very small, but if it looks similar to the first picture you posted it still looks over extruded. Since your E steps have been calibrated, perhaps we need to look at other sources of over extrusion. Perhaps the Z axis steps per mm is incorrect at 400? If it's not raising the nozzle the expected amount for eachlayer, it would appear as over extrusion.
      If you raise the nozzle 100mm above the bed does it measure out as 100mm in actuality?
      I have been working on Part 4 of the Ender 3 guide for initial calibration. It's still in draft form, but you can take a look to see if anything jumps out at you. https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
      B0M0A0Kundefined 2 Replies Last reply Reply Quote 0
      • B0M0A0Kundefined
        B0M0A0K @Phaedrux
        @phaedrux Thanks very much. I will review all that you have said here and see what changes I can make (it's currently printing a very raggedy Benchy).
        I would very much like to take a look at your calibration guide. I was sorry to see it missing when I ran through "commissioning".
        No fate but what we make ....
        • B0M0A0Kundefined
          B0M0A0K
          I really wouldn't want to put to sea in this, but hopefully the photos are closer in and you can get a better idea of what i am seeing.
          3_1559665966945_WIN_20190604_17_30_24_Pro.jpg 2_1559665966945_WIN_20190604_17_30_15_Pro.jpg 1_1559665966945_WIN_20190604_17_29_55_Pro.jpg 0_1559665966945_WIN_20190604_17_29_48_Pro.jpg
          • B0M0A0Kundefined
            B0M0A0K
            .. for comparison. This is what my Benchy looked like with the old Melzi board.
            2_1559666516054_WIN_20190604_17_40_20_Pro.jpg 1_1559666516054_WIN_20190604_17_40_09_Pro.jpg 0_1559666516054_WIN_20190604_17_39_59_Pro.jpg
            • B0M0A0Kundefined
              B0M0A0K @Phaedrux
              @phaedrux said in First Test Print following Duet3d Upgrade:
              Actually I took this measurement from the EEPROM of the old Melzi board.Thought it was probably a good place to start.
              • Vetiundefined
                Veti
                can you print a temperature tower?
                https://www.thingiverse.com/thing:2625999
                B0M0A0Kundefined dc42undefined 2 Replies Last reply Reply Quote 0
                • B0M0A0Kundefined
                  B0M0A0K @Veti
                  @veti Haven't tried that yet, great suggestion. I'm desperately trying to get this to an acceptable level where I can print the BLTouch mount and get that installed to help with the hell that is bed levelling 😞
                  • bricorundefined
                    bricor
                    Are you using the stock extruder? I just configured a model like this for someone and the extruder steps/mm were in the 90s (like 94).
                    Were you serious with the be leveling comment? Why is bed leveling so difficult for you?
                    Can you post the full config.g file.
                    B0M0A0Kundefined 1 Reply Last reply Reply Quote 0
                      It certainly seems like under extrusion in some of the pictures.
                      Can you check your printer setup in Cura to ensure that it's set to use 1.75mm filament and not 2.85mm.
                      Also the temperature tower would be a good idea. We need to verify that your temperatures are accurate, or at least find a temperature where extrusion can happen smoothly.
                        dc42 administrators @Veti
                        @veti said in First Test Print following Duet3d Upgrade:
                        I agree, it looks to me that your test print with the Duet is printed at too high a temperature.
                        • B0M0A0Kundefined
                          B0M0A0K @bricor
                          @bricor Yes, I am using the stock Wanhao Duplicator i3 v2.1 extruder wich is described as;
                          MK10 Single-Extruder (with Steel X-Carriage)
                          Re: Bed leveling. Yeah, kinda am. Its just such and ambiguous process. You can give 4 people the same printer and tell them what to do and they will all assume a different criteria for success. How on earth are you supposed to condense that into anything approaching a fool-proof method.
                          • bricorundefined
                            bricor
                            Apologies for going off subject with the bed leveling, but it may be the i3 design that's the issue. Bed leveling is a straight forward procedure on a printer like this and does not require a probe. Delta printers require a bit more to get right and probing makes life easier but also not necessary.
                            To get back on track, print the temp tower and post the results. Interested to see where this goes.
                            • B0M0A0Kundefined
                              B0M0A0K
                              @Phaedrux @dc42
                              I have the print running at what Cura (4.1.0) calls "Extra Fast" the settings for which are as follows;
                              Resolution: 0.3mm
                              Print Temp: 190
                              Print Temp Initial Layer: 190
                              Initial print temp: 180
                              Build Plate Temp: 60
                              Flow: 100%
                              Retraction enabled
                              Retraction Distance: 6.5mm
                              Retraction Speed: 25
                              Print Speed: 60
                              Travel Speed: 120
                              Initial Layer Speed: 30.0
                              Cooling Enabled
                              FAN Speed: 100
                              FAN Regular Speed: 100
                              FAN Max Speed: 100
                              Support: No
                              Build Plate Adhesion: Brim
                              Brim Width: 8.0
                              Print Sequence: All At Once
                              However. The Wanhao Duplicator i3 profile is active in the Cura interface so I'm not sure how much of that it keeps if you choose a Cura based resolution rather than the Wanhao profile (included below).
                              It's worth mentioning that I used the "Extra Fast" setting to produce the better quality Benchy while the Wanhao i3 was still using the factory Melzi board.
                              3_1559674614870_Wanhao Printer Profile Settings.png 2_1559674614870_Printer Machine Settings.png 1_1559674614870_Nozzle Settings.png 0_1559674614870_MaterialsPlusSettings.png
                              • B0M0A0Kundefined
                                B0M0A0K
                                Let me know if these are too small, I was getting told off by the system earlier for trying to post images that were too large, so have been reducing the images by 50%
                                  As I suspected, the screen shot of your machine settings extruder tab show it's using 2.85mm for your filament diameter. Change that to 1.75 or whatever the measured diameter of your filament is.
                                  • B0M0A0Kundefined
                                    B0M0A0K
                                    @Phaedrux Thanks for spotting that. I am confused about the relationship between the Wanhao profile and the Cura "Extra Fast" setting. Does that suggest that Cura uses the Wanhao profile as the base setting and then applies the Cura Extra Fast setting as a "tuning" of the model to be printed?
                                    By the way, I'm definitely using 1.75 filament.
                                      I don't think the machine setting has much of an effect on the print settings exactly. But it does define the physical properties of the machine.
                                      Either profile you choose will likely work fine ok nice the filament diameter is set correctly.
                                      • B0M0A0Kundefined
                                        B0M0A0K @Phaedrux
                                        @phaedrux Thanks, I will try printing the temp tower and see what happens.
                                        • B0M0A0Kundefined
                                          B0M0A0K
                                          I have adjusted the machine settings to reflect 1.75 filament, re-leveled the bed, leveled the X-axis and started to print the temperature tower. Looks like a good 'squish' but there is already sign of melting on the left hand 0_1559677025847_temptower.png
                                          • B0M0A0Kundefined
                                            B0M0A0K
                                            OK Folks. The temp tower has finished printing and the results are in. I am adding photos and the Cura GCode for your perusal.
                                            0_1559680332452_BM-GCODE.txt
                                            8_1559680352561_WIN_20190604_21_28_45_Pro.jpg 7_1559680352561_WIN_20190604_21_28_25_Pro.jpg 6_1559680352561_WIN_20190604_21_24_54_Pro.jpg 5_1559680352561_WIN_20190604_21_24_49_Pro.jpg 4_1559680352561_WIN_20190604_21_24_26_Pro.jpg 3_1559680352561_WIN_20190604_21_23_43_Pro.jpg 2_1559680352561_WIN_20190604_21_23_38_Pro.jpg 1_1559680352561_WIN_20190604_21_23_35_Pro.jpg 0_1559680352559_WIN_20190604_21_23_25_Pro.jpg
