    WiFi help please
    1.3k
    • whosrdaddyundefined
      whosrdaddy @DanL
      @danl if you enter M588 S"*", it should delete all known networks, then only add shop2 and you should be good to go.
      • DanLundefined
        DanL
        @whosrdaddy
        Hmmm...will give that a shot. Thank you.
        DanL
          dc42 administrators @DanL
          @danl, M588 S"SHOP" should be all you need to send, if the original access point is called exactly SHOP.
          • DanLundefined
            DanL
            Right. I entered exactly M588 S"SHOP" using YAT, to no effect.
            I want to keep DANL2.4 and SHOP2.
            This is how SHOP is reported from M588:
            Remembered networks:<LF>T********** IP=xxx.xxx.x.xx GW=0.0.0.0 NM=0.0.0.0<LF>DANL2.4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>SHOP IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>SHOP2 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
            All is working fine now on SHOP2. Pesky SHOP......
            Thank you.
            DanL
              Are you using DuetWiFiServer version 1.23? If so then I'll re-test this.
              You will get clearer responses in YAT if you go into Settings -> Text Settings and change the line ending to LF only.
              DanLundefined 1 Reply Last reply Reply Quote 0
              • DanLundefined
                DanL @dc42
                Using 1.21
                Should I go to 1.23? ...this is all foreign to me...
                DanL
                  Phaedrux Moderator @DanL
                  @danl said in WiFi help please:
                  yes.
                  • DanLundefined
                    DanL
                    @dc42 said in WiFi help please:
                    Geez....feeling stupid......I searched and find PanelDue v 1.23, but cant for the life of me find DuetWiFiServer version 1.23.
                    Is it this? Duet2CombinedFirmware.bin
                    DanL
                      You can find it here: https://github.com/dc42/RepRapFirmware/releases/tag/2.02
                        Though you should be able to upload the entire zip file to the DWC settings page and it will update everything as needed.
                        https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02b.zip
                        • DanLundefined
                          DanL
                          Duet2Combined or DuetWiFiServer?
                          DanL
                          • DanLundefined
                            DanL
                            BTW, Thanks for the fast response.
                            DanL
                              Both are available at the first link.
                              But you can just download the zip file from the second link and upload that to get everything at once.
                              • DanLundefined
                                DanL @Phaedrux
                                @phaedrux
                                Yep...just before your response the lightbulb went on. I was trying to upload the unzipped folder. In retrospect, this stuff seems straightforward, but the first time through is a bear.
                                Loaded the full zipped folder and it loaded fine.
                                Are differences summarized somewhere please?
                                Again, the support you provide is awesome. Thank you and the other "first responders".
                                DanL
                                  Yes there's a what's new link in the description of that first link.
                                  https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                                  • DanLundefined
                                    DanL @Phaedrux
                                    @phaedrux @dc42 @Red-Sand-Robot
                                    Got through loading 1.23 and the M588 worked first try.
                                    Thanks for all the help....and patience...ha.
                                    Feel like I'm still in 3D printing kindergarten, but amazed how good the DuetWiFi is. That old chinese board, drivers and Marlin were driving me crazy.
                                    Just bought a second printer - another disowned, unloved, pre-assembled FT5. This kit does build into a good printer with some TLC. Some mechanical and electrical upgrades and it should be great....but only with another Duet and PDue.
                                    So...should I get another DuetWF now, or is a newer version maybe coming sometime soon?
                                    DanL
                                      @danl I think the duet 3 would be overkill for an ft5. The duet 2 boards aren't being replaced either they are still sticking around. The 3 is just another tier above that for people who need more.
                                      • DanLundefined
                                        DanL
                                        Thank you.
                                        DanL
