WiFi help please
1.3k
    DanL
    I think I'm fairly bright....have the Duet WiFi humming along on an FT5 producing great prints, but WiFi network stuff is totally greek to me.
    Recently moved the printer to a remote garage (100 m away from home wifi router) and set up a Linksys CPE 210 system (see diagram).
    When I attempt to connect the Duet to SHOP2 (the strongest signal), it connects instead to SHOP, a weak signal from the distant Linksys unit.
    I'm confused that each unit....the router and both Linksys units have the same IPv4, even with different SSID's.
    How do I get the Duet to connect to the strong signal on SHOP2?
    Do I need to make changes in the network setup, or is it all Duet WiFi settings?
    Thank you.
    DanL
      Red Sand Robot
      @DanL I think to ensure that it only connects to the SHOP2 network, you need to send M588 to disconnect from the original network it was connected to (in this case SHOP).
      M588: Forget WiFi host network
      M558 S"ccc" Network SSID to remove from the remembered list
      almost an engineer
        wayne thornton
        it don't work I wont the ethernet one so someone is going to. I did all that it don't work
          The Duet should connect to the strongest known network that it finds. Are you certain that you have entered the details of the SHOP2 network correctly using M587? Send M587 without parameters to get the list of known networks.
          As @Red-Sand-Robot says, you can tell the Duet to forget the SHOP network if that helps; but it should connect to SHOP2 anyway if it is stronger and you have entered the SSID correctly.
            DanL
            @dc42 @Red-Sand-Robot
            THANK YOU!
            Had to enter lower case pword letters with preceding single quote. That got Duet connected to SHOP2.
            But I tried everything and cannot get SHOP off the remembered list. That's OK though, as long as Duet connects to SHOP2.
            DanL
            undefined 1 Reply Last reply 4 Jun 2019, 19:56 Reply Quote 0
              whosrdaddy @DanL
              @danl if you enter M588 S"*", it should delete all known networks, then only add shop2 and you should be good to go.
                DanL
                @whosrdaddy
                Hmmm...will give that a shot. Thank you.
                DanL
                undefined 1 Reply Last reply 4 Jun 2019, 20:21 Reply Quote 0
                  dc42 administrators @DanL
                  @danl, M588 S"SHOP" should be all you need to send, if the original access point is called exactly SHOP.
                    DanL
                    Right. I entered exactly M588 S"SHOP" using YAT, to no effect.
                    I want to keep DANL2.4 and SHOP2.
                    This is how SHOP is reported from M588:
                    Remembered networks:<LF>T********** IP=xxx.xxx.x.xx GW=0.0.0.0 NM=0.0.0.0<LF>DANL2.4 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>SHOP IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>SHOP2 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>ok<LF>
                    All is working fine now on SHOP2. Pesky SHOP......
                    Thank you.
                    DanL
                      Are you using DuetWiFiServer version 1.23? If so then I'll re-test this.
                      You will get clearer responses in YAT if you go into Settings -> Text Settings and change the line ending to LF only.
                      undefined 1 Reply Last reply 5 Jun 2019, 15:45 Reply Quote 0
                        DanL @dc42
                        Using 1.21
                        Should I go to 1.23? ...this is all foreign to me...
                        DanL
                        undefined 1 Reply Last reply 5 Jun 2019, 16:02 Reply Quote 0
                          Phaedrux Moderator @DanL
                          @danl said in WiFi help please:
                          yes.
                            DanL
                            @dc42 said in WiFi help please:
                            Geez....feeling stupid......I searched and find PanelDue v 1.23, but cant for the life of me find DuetWiFiServer version 1.23.
                            Is it this? Duet2CombinedFirmware.bin
                            DanL
                              You can find it here: https://github.com/dc42/RepRapFirmware/releases/tag/2.02
                                Though you should be able to upload the entire zip file to the DWC settings page and it will update everything as needed.
                                https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02b.zip
                                  DanL
                                  Duet2Combined or DuetWiFiServer?
                                  DanL
                                  undefined 1 Reply Last reply 5 Jun 2019, 18:49 Reply Quote 0
                                    DanL
                                    BTW, Thanks for the fast response.
                                    DanL
                                      Both are available at the first link.
                                      But you can just download the zip file from the second link and upload that to get everything at once.
                                      undefined 1 Reply Last reply 5 Jun 2019, 19:01 Reply Quote 0
                                        DanL @Phaedrux
                                        @phaedrux
                                        Yep...just before your response the lightbulb went on. I was trying to upload the unzipped folder. In retrospect, this stuff seems straightforward, but the first time through is a bear.
                                        Loaded the full zipped folder and it loaded fine.
                                        Are differences summarized somewhere please?
                                        Again, the support you provide is awesome. Thank you and the other "first responders".
                                        DanL
                                        undefined 1 Reply Last reply 5 Jun 2019, 19:04 Reply Quote 0
                                          Yes there's a what's new link in the description of that first link.
                                          https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
                                          undefined 1 Reply Last reply 5 Jun 2019, 19:18 Reply Quote 0
                                          10 out of 23
