    BLTouch V3.0 Information, Setup, and O'Scope Pictures
    27
    4.3k
    • JamesMundefined
      JamesM @cabal2000
      @cabal2000 My newest BLTouch does the same thing for me but it will work after turning the printer off and back on once.
      • cabal2000undefined
        cabal2000 @zapta
        @zapta Nozzle is no where close to the bed, pin is free. But I will be adding the reset command. Thanks man
        • jaurandundefined
          jaurand
          @JadonM Would you be able to share which pins you are using for your setup? I am having some odd issues and want to try to emulate your setup.
          JadonMundefined 1 Reply Last reply Reply Quote 0
          • JadonMundefined
            JadonM @jaurand
            @jaurand said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
            Absolutely! I would love to have some novel wiring scheme that would solve all your problems, but unfortunately, I've just followed the wiki! 🙂 I have the Maestro, which takes different wiring than the Wifi, Ethernet, or Duet3.
            My wiring is all on the Z-probe connector and consists of:
            BLTouch Out - Maestro In
            GND - GND
            Control - MOD
            5V - 5V
            Hopefully that is a help to you, and feel free to ask me any other questions you have!
            • jaurandundefined
              jaurand
              @JadonM Thank you for the o'scope images
              I followed this setup https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/ for duet wifi and am unsure about the pins to use for bltouch error reset and 5V logic mode for the duet wifi
              I keep getting a flashing red duty cycle and when i run mesh bed it runs for a bit then the probe stays in the up position.
              • JadonMundefined
                JadonM @jaurand
                I'm sorry, but I don't think I know enough about the Duet and BLTouch to answer your question. I would recommend making a new thread with all the details and one of the much more knowledgeable regulars can help you.
                Sorry that I can't help you!
                • jaurandundefined
                  jaurand
                  @JadonM that is plenty of help enough! Thank you!
