    BLTouch V3.0 Information, Setup, and O'Scope Pictures
    27
    4.3k
    • piperswundefined
      pipersw @JadonM
      @jadonm Yes, it's the clamping diode whose stuck at 3.3V.
      • piperswundefined
        pipersw @dc42
        @dc42 said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
        The Z probe input of the Maestro has an internal pull up resistor inside the microcontroller, value about 100K. I am fairly sure that it is enabled when you select BLTouch probe mode, but I will check.
        On schematic of Maestro, there is a external 10k pull-up, so the internal pull-up of the processor is don't care if enabled or not, because it's around 10k in all case.
          dc42 administrators @pipersw
          @pipersw said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
          If you mean R62, that's a 10K series resistor, not a pullup resistor.
          I have confirmed that the internal pullup resistor is enabled when BLTouch mode is selected.
          piperswundefined 1 Reply Last reply Reply Quote 0
          • piperswundefined
            pipersw @dc42
            @dc42 No, if I take the picture https://i.imgur.com/jPdCPKm.png, I mean R70.
              That's the Z endstop connector, not the Z probe connector.
              • piperswundefined
                pipersw
                you are right !
                • cabal2000undefined
                  cabal2000
                  I have a V3 bltouch installed as per setup guide for the Maestro. When I turn on the board to BL blinks with an error, I have to turn the board off and on several times before it will do a self test. No resistor is used.
                  zaptaundefined JamesMundefined 2 Replies Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @cabal2000
                    @cabal2000, was the bed too close to the nozzle when you turn it on? If the BLT doesn't have sufficient mechanical clearance on power up, it enters an error state and blinks. I added to my homeall script a BLT error reset command I found in one of the threads here.
                    M280 P3 S160 I1
                    cabal2000undefined 1 Reply Last reply Reply Quote 0
                    • JamesMundefined
                      JamesM @cabal2000
                      @cabal2000 My newest BLTouch does the same thing for me but it will work after turning the printer off and back on once.
                        cabal2000 @zapta
                        @zapta Nozzle is no where close to the bed, pin is free. But I will be adding the reset command. Thanks man
                        • jaurandundefined
                          jaurand
                          @JadonM Would you be able to share which pins you are using for your setup? I am having some odd issues and want to try to emulate your setup.
                          JadonMundefined 1 Reply Last reply Reply Quote 0
                          • JadonMundefined
                            JadonM @jaurand
                            @jaurand said in BLTouch V3.0 Information, Setup, and O'Scope Pictures:
                            Absolutely! I would love to have some novel wiring scheme that would solve all your problems, but unfortunately, I've just followed the wiki! 🙂 I have the Maestro, which takes different wiring than the Wifi, Ethernet, or Duet3.
                            My wiring is all on the Z-probe connector and consists of:
                            BLTouch Out - Maestro In
                            GND - GND
                            Control - MOD
                            5V - 5V
                            Hopefully that is a help to you, and feel free to ask me any other questions you have!
                            • jaurandundefined
                              jaurand
                              @JadonM Thank you for the o'scope images
                              I followed this setup https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/ for duet wifi and am unsure about the pins to use for bltouch error reset and 5V logic mode for the duet wifi
                              I keep getting a flashing red duty cycle and when i run mesh bed it runs for a bit then the probe stays in the up position.
                              • JadonMundefined
                                JadonM @jaurand
                                I'm sorry, but I don't think I know enough about the Duet and BLTouch to answer your question. I would recommend making a new thread with all the details and one of the much more knowledgeable regulars can help you.
                                Sorry that I can't help you!
                                • jaurandundefined
                                  jaurand
                                  @JadonM that is plenty of help enough! Thank you!
