    Indirect (bearing) laser filament monitor concept
    Filament Monitor
    26
    109
    14.1k
    • Adrian52undefined
      Adrian52 @SteveYYC
      @steveyyc I tried making a double walled 15mm spacer, with an inner channel of 7x4mm, with a 3mm thick wall, linking the sensor to the bearing surface. I even put a little 0.5mm thick flap to block the LED shining into the sensor chamber. The results were very similar to those obtained with the plain 15mm spacer, so in my hands I don't think light leakage is a problem.
      • 3dmntbighkerundefined
        3dmntbighker
        Sounds like an optimized design is in the near future. I could definitely use a bit more bearing clearance. I think the whole thing could be a bit wider with some bearing slop and room for a longer bolt. It seems like it's tighter in there than it needs to be to save a few mm outer dimension.
        Scratch built CoreXY with Maestro
        Heavily modified Ender 3 with Maestro
        MPCNC work in progress with Duet WiFi
        Adrian52undefined 1 Reply Last reply Reply Quote 1
        • brunofportoundefined
          brunofporto @Adrian52
          @adrian52
          Great information!!!!!!
          I used to compare the slicer predicted total length with the sensor reported total length. How does this correlate with the sensor distance?
          • Adrian52undefined
            Adrian52 @3dmntbighker
            @3dmntbighker I have put a new version on thingiverse, 3649565. I have increased the play, and made the bolts screw in from the side. This is easy for the bottom bearing, but you need a 7mm bolt for the upper bearing to fit between the vertical bolts. Their spacing is determined by the holes on the PCB.
            I have done more experiments with the gap between sensor and top bearing, and have concluded so far that a 5mm spacer is probably ok. I realised that my initial results were essentially single points for the max and min - with repeated runs, the picture is not so clear, but I think 5mm is better than no spacer.
            The percentages I get are still high, but quite reproducible - for the 5mm spacer, the average is about 270%, with the min not below 259, and the max not above 287 on 4 runs of at least 500mm extrusion. The relationship between sensor distance and average percentage reported is very linear - I have 12 points in my dataset now, with a least squares linear fit r squared of 0.998. The slope is 23.0 - the average percentage increases by 23 for each mm of gap between the sensor and bearing surface.
            3dmntbighkerundefined 1 Reply Last reply Reply Quote 3
              3dmntbighker @Adrian52
              @adrian52 said in Indirect (bearing) laser filament monitor concept:
              You are a rock star 😉
              • rogerkamp8817undefined
                rogerkamp8817
                Great job, have duet laser sensor on order and can't wait to try this.
                • Crash69undefined
                  Crash69
                  Wasnt sure if I should start a new thread, hopefully its ok just to add here, I printed the concept above from brunofporto with the latest changes by adrian52.. but I don't have the right bearings on hand to properly test. Was going to take a while for bearings to get delivered..
                  So I decided to have a go at trying to come up with my own design. The goal was to use some decent quality bearings I had on hand - 5x10x4 (mr105) and because I figured it would be something I would be printing different version of, something that was quick & easy to assemble.
                  So here's my attempt:
                  I have tried various sensor to bearing surface distances so far.. and I'm finding that around 9mm seems to be the most consistent.
                  Here is a output from a recent print:
                  So far it seems to work really well - quite similar to adrian52's results. If you normalise the raw average figure of 299 to be 1 (or 100%) then the lowest reading is 0.956 (4.5% below the average) and the highest reading is 1.023 (2.3% above the average.
                  I have short tube of around 25mm between the sensor and my extruder input.. so I have set the check to be every 5mm instead of the 3mm in the example which still allows plenty of time to pause the printer if there is an issue, but the slightly longer check also seems to help a bit with consistency.
                  I have put my stl's and .scad file on thingiverse for anyone to use/mod/try
                  https://www.thingiverse.com/thing:3673768
                  brunofportoundefined tagliaundefined 2 Replies Last reply Reply Quote 2
                    brunofporto @Crash69
                    @crash69 Loved your solution for the barings holder!!!!! These bearings are easier to find around here and also cheaper. I'll buy them ASAP and test your design. 😄 Thanks!
                    • Adrian52undefined
                      Adrian52
                      I have been continuing to play with the monitor, and have also made a version for 10mm bearings - I have put it on thingiverse, 3717158. I have made the jaws part spring loaded, so that you can adjust the tension gripping the filament.
                      When printing slowly, the maximum and minimum values are very accurate (within 2-5%, as above). With faster extrusion, the range tends to get bigger. Using longer measuring intervals seems to give less variation - I am currently using 10mm. Using the A1 switch seem to give a very accurate measure of the total filament used - sometimes giving uncanny agreement with the value reported by DWC (my last print the monitor reported 1640mm, DWC 1639mm, and the slicer said 1643mm). When I use the A0 switch, the monitor reports 85-90% of the filament usage reported by DWC. The total usage data seems to remain extremely accurate when printing faster, where the maximum and minimum values become very wide. Could the max/min variation be due to hitting limits of processing the data?
                        It could be that the synchronisation in firmware between the filament sensor reading and the extrusion commanded isn't always working properly.
                        • Adrian52undefined
                          Adrian52 @dc42
                          @dc42 have done some more tests using a 20x20x4mm cube with 100%fill, printed at 60mm /sec, then varying the layer height or width to achieve specific filament movement rates. I print the first layer at 10mm/sec, so checking after 100 mm gives a 'slow' baseline for each test, and the total is a little over 700mm. Under these conditions I have no hiccups or missed steps.
                          For me, the monitor works well with filament movements up to 1.3mm/sec (max/min within 10% of the average) , but for 1.5mm/sec and 2mm/sec, the max/min range becomes very wide, often going negative on the min side. I get similar results with and without a 5mm spacer, although the actual numbers are higher with the spacer as previously observed.
                          The total extrusion reported by the monitor is very close (usually within 1%) to that shown by dwc or the slicer, even when the extrusion rate is above 1.5mm /sec.
                          I have also started to note the error rates for the monitor reported by M122. For tests below 1.3mm/sec, frame errors are 2000-4000, and pol errors high(20000-30000). Above 1.3mm/sec, frame errors are 20000 - 30000, but pol errors are below 10000. I have also noticed that the error count is not zeroed when you start a new print - I have been doing a reset after each test to zero things up.
                          brunofportoundefined dc42undefined 2 Replies Last reply Reply Quote 2
                          • zaptaundefined
                            zapta
                            @adrian52, what is that you are trying to achieve? If it's the detection of filament grinding, do you need exact measurements or just no movement in a certain time period?
                              @adrian52 What is curious is that I had similar results (high precision with total measured length compared to predicted by slicer) with direct filament readings!!! It was precise enough that I could even calibrate extrusion steps/mm with it. Even with filaments that I had horrible max and min results.
                                dc42 administrators @Adrian52
                                Hmm, that sounds odd. Which firmware version are you running? Run M115 to make sure. Also, which revision Duet do you have? We changed the values of the filtering capacitors on later ones to help the filament monitor signals get through more reliably.
                                Adrian52undefined 1 Reply Last reply Reply Quote 0
                                • Adrian52undefined
                                  Adrian52 @dc42
                                  @dc42 running 2.03+1. I have a 1.01 duet wifi. Is there a way I can improve the situation?
                                    You could try connecting the filament monitor to one of the endstop inputs on CONN_LCD, which have no filter capacitors. That would be easier than removing the filter capacitor from a regular endstop input on the Duet. But if the problem is interference from a stepper motor cable, it may make matters worse.
                                    Keep the cable to the filament monitor away from the extruder motor cable; or if they must run together, try using shielded cable for the filament monitor.
                                    • Adrian52undefined
                                      Adrian52 @dc42
                                      @dc42 Excellent advice. I have connected to stop 10 on conn_lcd using shielded cable (a repurposed USB cable that also has a ferrite ring), and the errors are now zero. I have got up to 3mm/second filament (0.5 width, 0.3 height at 60mm/sec) and the max/min were 107%/95% of the average. Wow.
                                      mitchundefined JADoglioundefined 2 Replies Last reply Reply Quote 1
                                      • tagliaundefined
                                        taglia @Crash69
                                        @crash69 Thank you for this; I really like your design (it printed like a charm)! Also, your .scad file is straightforward to tweak. I have changed the following:
                                        • Added a bracket to attach to my Ender 3 with a SeeMeCNC EZR Struder;
                                        • Increased the sensor distance to 19mm (thanks @Adrian52 for the analysis);
                                        • Made the split on the bearing mounts longer, to make it easier to slide the bearings in;
                                        • Adapted the bearing size to some bearing I had lying around (16x8x5).
                                        I did a quick test with a shorter sensor distance; the results were much better than with direct reading, but I still got a wide range. In the next few days, I will print another one with all the changes listed above. If anybody is interested, I can publish the remix.
                                        Thank you all for this very informative thread.
                                        brunofportoundefined 1 Reply Last reply Reply Quote 0
                                          brunofporto @taglia
                                          @taglia Please do publish! 😄
                                          tagliaundefined 1 Reply Last reply Reply Quote 1
                                          • tagliaundefined
                                            taglia @brunofporto
                                            @brunofporto Apologies for the long silence, it took me a while to get to some good results. I have now managed to print for a couple of days with consistent results and no sudden pauses. The sensor also saved a big part that I was printing (no more filament).
                                            The cause of my problems was the filament sliding on the bearing, and this caused negative reads. I have found this product at a local shop, sprayed two layers on my bearings, and the sensor seems now stable, even at high speed. I have also increased the pressure a bit and reprinted the mount with black eSun PLA+, which appears to be stronger than regular PLA.
                                            This is the model that I am currently using. I was too lazy to remodel the attachment to the extruder, which I had already designed in Fusion 360: this is the STL imported by the OpenSCAD file.
                                            These are the bearings.
