    All black D-bot
    My Duet controlled machine
    • claustroundefined
      claustro
      Hi guys, I am stressing many forum members with all kind of questions on how I could improve my D-bot so I decided to post some photos for let the curious guys see the " responsible " of all my questions 🙂
      The printer: ( for now)
      • Duet wifi ( thx @deckingman for the case)
      • changed from cantilevered to 4 point sustained bed
      • 3 wheels Z carriage
      • 2 lead screw with belt driven by single motor
      • Dual 24 v Meanwell PSU
      • Switched after some weeks to direct with titan extruder
      • Magnetic Duet filament sensor that works great ( I can't understand why duet crew didn't make it available on the market)
      • Cable chains on Z and hotend
      • Originale Bl touch
      • Self designed radial fan for print material that work very well
      Upcoming change.
      • I bought a 330x340x8 PEI covered here https://clever3d.de/ with 3 regulation point ( thank you @mrehorstdmd )
      • New heated bed 220V 750W 300x300 so I'll remove a PSU
      • I would like to rework my Z axis that works good but not as good as I would like my actual idea is to shift to 3 lead screw driven by single motor ( thank you @Phaedrux for all the input). I need to decide how many guides to use if stay with the actual 4 or go for 2.
      In the future I am tempted to test 3 Z motors for autolevelling but for now I want to follow advise of all the people that suggest me that a good solid printer don't need bed leveling more than occasionally
      For me aesthetic is very important so cable wire is a large part of the time spent building this printer,
      3_1556406994994_e.jpg 2_1556406994993_d.jpg 1_1556406994993_c.jpg 0_1556406994993_b.jpg
      thweundefined 1 Reply Last reply Reply Quote 1
      • thweundefined
        thwe @claustro
        @claustro said in All black D-bot:
        I can see that clearly - made great!!! I am also a cable and cable-tie fetishist 😂
        How satisfied are you with the v-slot guides?
        Thomas
