    Duet3D PCB delta printer effector sneak preview
    53
    367
    77.5k
    • Dougal1957undefined
      Dougal1957
      @dc42:
      @loic:
      what kind of sensor does effector use for autobed?
      It's a strain gauge that detects a minute flexing of the PCB.
      it was revealed on page 9 of this thread what tech it used.
      • T3P3Tonyundefined
        T3P3Tony administrators
        They won't be in stock until next week. I put the listing up to answer some questions about the cost.
        www.duet3d.com
        • Rommieundefined
          Rommie
          Ahhh ok thanks
          • oleeundefined
            olee
            @T3P3Tony:
            Glad to hear it! And could I order 12 not 6 Magballs as spare addon?
            • inachisiojexusundefined
              inachisiojexus
              @CaLviNx:
              @roboduet:
              It seems that this is the first public picture of the bottom side of the printed circuit board with sensor electronics 🙂 Unfortunately, the quality of the photo is very poor and labels of IC chips are not visible.
              UPD: SmartEffector is called as StrainEffector 1.3 on PCB silkscreen. Maybe this is the key to unraveling the way of bed probing?
              Why do you want to unravel the thing ? are you looking to reverse engineer it to rip the technology off or something ?
              Off-topic but I found your question of "why" strange. Like we're unraveling the order of nature just to rip it off. It's funny because it's true. 😉 I've gotten the impression that the people behind Duet are very OSS/RepRap-minded, a central point of which is "ripping off" without shame. Maybe your second sentence suggested commercial purposes, but that's quite a leap to infer from a mere motivation to figure out and understand how something works.
              • A Former User?
                A Former User
                @inachisiojexus:
                You can take it and infer anything from it you wish.
                As Dougal already pointed out the information as to how the unit operates was ALREADY revealed.
                  inachisiojexus
                  @CaLviNx:
                  Only conceptually if my memory and attentiveness serve me right. I think that's beside the point anyway.
                  My point was that some people enjoy tearing down and reverse-engineering devices built by others, and I found your question strange especially in the broader context of 3d-printing which as a hobby still involves a lot of DIY, tinkering and generally; involvement.
                  • number40fanundefined
                    number40fan
                    @JohnOCFII:
                    @Hergonoway:
                    I had 50mm for some time, but I like the 40mm compact size, same as classic 40mm fans, but it can be put alongside the e3d for a narrow design. If you take time to search you'll find ones with more than 10CFM
                    A 40mm blower fan would certainly fit better than 50mm. I had ordered the 50mm, as it is what it on the Prusa i3 MK2 I have, and it does a fantastic job. If I can find a 40mm with a healthy CFM, that would certainly fit better on my T3P3 Kossel Mini.
                    Here's one possible contender (at 12V) - showing 9.5 CFM.
                    http://www.ebay.com/itm/Ball-Bearing-4cm-40mm-x-40mm-x-10mm-Blower-Fan-12V-Brushless-DC-Cooling-fan-2pin-/262701643053?hash=item3d2a3cf52d:g:HrwAAOSwzgBYz1cr
                    John
                    Thanks. Been looking for a fan like that for a while.
                    • A Former User?
                      A Former User
                      @T3P3Tony:
                      @Zesty_Lykle:
                      Not having a board, that is kinda tricky, but I think it is OK, looking at the photos.
                      Thanks for the measurements.
                      I hope this helps a bit more:
                      https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#SmartEffector_SMT_Component_Clearances
                      @__Tony__ <–--------------------------------------
                      The Last missing part of the puzzle (for me anyway) I have highlighted, I need the distance from the centre of the hole to the short edge of the effector
                      Please accept my apologies if it's out there and I have missed it
                        Dougal1957
                        @CaLviNx:
                        @T3P3Tony:
                        @Zesty_Lykle:
                        Tony Last missing part of the puzzle (for me anyway) I have highlighted, I need the distance from the centre of the hole to the short edge of the effector
                        https://vgy.me/aMJKcm.jpg
                        By calculation I would say 6.64mm the long side is 66.5 and the spacing is 55 so that is 5.75mm to the corner so I reckon the calc is 5.75/cos30+ the distance you are asking for.
                        Doug
                        • oleeundefined
                          olee
                          @CaLviNx:
                          @T3P3Tony:
                          @Zesty_Lykle:
                          You can print https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#SmartEffector_SMT_Component_Clearances on a printer (plain old paper printer of course) , calculate a scale from any known size (distance for the ball stud holes for example) and measure any things you want.
                          • botundefined
                            bot
                            Based on the known dimensions, and the schematics shown, it would be between 7.8-8mm
                            *not actually a robot
                            • Hergonowayundefined
                              Hergonoway
                              It's time for me to prepare wiring 🙂
                              so I've got a 2 wires PT100, with everything under 24v, from what I see I can use one of my 6 wire cable for Molex KK, 22AWG will do the job.
                              But what about the Molex Microfit, I would like to use the same cable but could I use a 22AWG for the extruder heater ? I currently have a 40w 24v cartridge, from my point of view it's OK, but I'll prefer a second advice 🙂
                              Delta goes BrrrRRRRrrrrrRRRRrrr
                              • oleeundefined
                                olee
                                @Hergonoway:
                                1.7A current is well within ampacity of 22AWG for chassis wiring. And voltage drop of 0.2V is not much of concern for the case.
                                  My plan was to use fairly thin 8 core multicore cable for the signal connection (4 wire PT100 connection from the effector back to the Duet), and use the same cable for the heater/fan connector with 2 conductors in parallel for each of the heater wires. In the end I didn't change the heater and fan wires because they were already working well. I can't remember what gauge the conductors were, but the resistance per conductor was just under 0.1ohm per metre.
                                    inachisiojexus
                                    @CaLviNx:
                                    x = 5.75 * sqrt(2) * cos(15) ~= 7.8546460717605222188914082318294
                                    • A Former User?
                                      A Former User
                                      I had the dimensions worked out, I just wanted Tony's confirmation.
                                      And suddenly a lot of non Tony's jumped in !!!!
                                      • DADIYundefined
                                        DADIY
                                        For the cabling, I was planning on using 6 core 22awg for the heater and fan connections,
                                        6 Core - http://www.ebay.co.uk/itm/Flexible-2-3-4-5-6-Multicore-Cable-AWG-Black-Signal-Power-Auto-Data-Car-Wire-UK/281776562442
                                        and then for the PT100 and probe connections, I have lots of stranded cat 6 that I can use. Hopefully, the probe and the PT100 won't interfere with each other? Any thoughts?
                                          The probe and the PT100 signals don't interfere with each other. The 8-core cable I used was this http://uk.rs-online.com/web/p/multicore-industrial-cable/6604052/?sra=pstk.
                                          • oleeundefined
                                            olee
                                            @dc42:
                                            David, how about crimping two wires in one Microfit pin, does it fit?
