WiFi help please
Are you using DuetWiFiServer version 1.23? If so then I'll re-test this.
You will get clearer responses in YAT if you go into Settings -> Text Settings and change the line ending to LF only.
Using 1.21
Should I go to 1.23? ...this is all foreign to me... -
@dc42 said in WiFi help please:
Geez....feeling stupid......I searched and find PanelDue v 1.23, but cant for the life of me find DuetWiFiServer version 1.23.
Is it this? Duet2CombinedFirmware.bin -
You can find it here: https://github.com/dc42/RepRapFirmware/releases/tag/2.02
Though you should be able to upload the entire zip file to the DWC settings page and it will update everything as needed.
https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02b.zip
Duet2Combined or DuetWiFiServer?
BTW, Thanks for the fast response.
@danl said in WiFi help please:
Both are available at the first link.
But you can just download the zip file from the second link and upload that to get everything at once.
@phaedrux
Yep...just before your response the lightbulb went on. I was trying to upload the unzipped folder. In retrospect, this stuff seems straightforward, but the first time through is a bear.
Loaded the full zipped folder and it loaded fine.
Are differences summarized somewhere please?
Again, the support you provide is awesome. Thank you and the other "first responders". -
Yes there's a what's new link in the description of that first link.
https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md
@phaedrux @dc42 @Red-Sand-Robot
Got through loading 1.23 and the M588 worked first try.
Thanks for all the help....and patience...ha.
Feel like I'm still in 3D printing kindergarten, but amazed how good the DuetWiFi is. That old chinese board, drivers and Marlin were driving me crazy.Just bought a second printer - another disowned, unloved, pre-assembled FT5. This kit does build into a good printer with some TLC. Some mechanical and electrical upgrades and it should be great....but only with another Duet and PDue.
So...should I get another DuetWF now, or is a newer version maybe coming sometime soon? -
@danl I think the duet 3 would be overkill for an ft5. The duet 2 boards aren't being replaced either they are still sticking around. The 3 is just another tier above that for people who need more.
Thank you.
