    Ender 3 Pro and Duet Maestro Guide
    Example setups and prints
    1491
      I've been working on a 4 part step by step guide to upgrading an Ender 3 Pro with the Duet 2 Maestro board, covering wiring, generating a config file set, commissioning the hardware, and doing some basic calibration to get started with good prints.
      Hopefully this will be helpful to anyone doing a similar upgrade. Even if it's a different printer than the Ender 3, it's generally applicable to adapting any printer to use a Duet.
      Future guides will go over adding a BLTouch, replacing 24v fans with 12v fans, adding LED strip, using mesh bed compensation, adding a PanelDue, etc. So stay tuned for that.
      Thanks to everyone who's already provided feedback.
      Check it out here:
      Ender 3 Pro and Duet Maestro Guide Part 1: Wiring
      Ender 3 Pro and Duet Maestro Guide Part 2: Configuration
      Ender 3 Pro and Duet Maestro Guide Part 3: Commissioning
      Ender 3 Pro and Duet Maestro Guide Part 4: Calibration
      Ender 3 Pro and Duet Maestro Guide Part 5: Upgrades
      Config file examples available here: https://github.com/x0rtrunks/Ender3DuetMaestroConfigs
      T3P3Tony 1 Reply Last reply Reply Quote 7
      • oliof
        oliof last edited by
        I'll compare with my CR-20 conversion (basically an Ender 3 with a nicer control box) and see if I can expand (-:
        <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
        • T3P3Tony
          T3P3Tony administrators @Phaedrux last edited by
          @phaedrux looking great!
          www.duet3d.com
          • kmhudgins
            kmhudgins last edited by
            this was very help full to my set up thank you
            • PaulHew
              PaulHew last edited by
              Really good guide, wish it was around when I did my conversion.
              I still refer to it now if I am unsure and want to double check a setting.
              Would it be worth putting a bit in about configuring Cura and adding the Duet RepRapFirmware plugin?
              RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
              Voron 2.4 disassembled..... Waiting for the RailCore Mini....
              • PaulHew
                Just been going through it and found that a link was wrong.
                In the section 'Bed Level Verification Print', the link is the same as the one in 'Extrusion Factor Test Print (Method 1) '
                There is this one..... https://www.thingiverse.com/thing:3235018 which is CHEP's bed levelling routine.
                  Phaedrux Moderator @PaulHew last edited by
                  @paulhew said in Ender 3 Pro and Duet Maestro Guide:
                  The link in the guide is correct, there are two STL files included, a cube and the bed level pattern. https://www.thingiverse.com/thing:3670991
                  PaulHew 1 Reply Last reply Reply Quote 0
                  • PaulHew
                    PaulHew @Phaedrux last edited by
                    @phaedrux Apologies, I did not realise there were 2 files in the download, I was going by the pictures.
                    Paul.
                      Paul.
                      I've updated the description and title of the thingiverse page to more clearly indicate there are 2 files.
                      At the end of the calibration guide there are links to complete Cura and PrusaSlicer profiles.
                      I didn't want to get too in depth with software specifics since things change very rapidly and it would become hard to maintain. The profiles include the printer setup and the print settings. So it's a pretty good starting point.
                      • oliof
                        I had hoped to use your mount in the CR20 but it looks like there is not enough clearance to plug the cables in if I do due to the flat profile of the underbed enclosure )-;
                        I will need to find the time to redesign it -- it's probably enough to increase the diameter of the mount holes so they fit around the metal standoffs integrated into the enclosure.
                        I will most certainly also move diet board back a centimeter or two for clearance from the front plate as I don't plan to expose the micro SD or USB ports directly.
                        • PaulHew
                          @Phaedrux Looking forward to the BL Touch setup .... as there is definately a P.I.C.N.I.C issue with my printer!!!
                          (Problem In Chair Not In Computer)!
                          lodger 1 Reply Last reply Reply Quote 0
                          • lodger
                            lodger @PaulHew last edited by
                            @paulhew and @Phaedrux I will upgrade my second ender to a Bl Touch next week i can send ? take picture if you need any.
                              Phaedrux Moderator @lodger last edited by Phaedrux
                              @lodger I'd certainly like to hear your impressions.
                              • lodger
                                lodger @Phaedrux last edited by
                                @phaedrux I swapped the first ender last week from a probe, Was so easy . Hardest part is making the extention cable up. And we can all do them tiny crimps now lol. the Maestro and a version 3 just work so well.
                                • CADZ
                                  CADZ last edited by
                                  Helped me a lot in replacing controlboard. Thanks a lot for all your effort
                                    Part 5 is now available and covers some upgrade options, including swapping the lead screw, adding a BLTouch, adding a buck converter for 12v accessories, adding LED lighting, swapping out the fans, etc.
                                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+5:+Upgrades/54
