Duet "Crashes" on Print
  • When I upload and print a file my Duet seems to crash. The web interface disconnects and the screen on the printer become unresponsive
    I have checked all the movements, including home
    Heated the bed
    Heated the hotend
    tested the extruder
    Tested the probe
    and everything works ok
    If there any logs I can examine to try and work out what is going on?
    When entering M122 I get
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01(RTOS) running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917NK-F23T0-6J9DJ-3SD6N-TDBWF
    Used output buffers: 3 of 20 (20 max)
    Static ram: 28476
    Dynamic ram: 96292 of which 16 recycled
    Exception stack ram used: 484
    Never used ram: 5804
    Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3476)
    Owned mutexes:
    Last reset 00:23:19 ago, cause: power up
    Last software reset at 2019-06-12 20:55, reason: User, spinning module GCodes, available RAM 5960 bytes (slot 2)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 4
    Free file entries: 10
    MCU temperature: min 23.4, current 25.8, max 26.0
    Supply voltage: min 12.1, current 12.3, max 12.4, under voltage events: 0, over voltage events: 0
    Driver 0: standstill, SG min/max 0/200
    Driver 1: standstill, SG min/max 0/214
    Driver 3: standstill, SG min/max 0/132
    Date/time: 2019-06-13 20:46:27
    Slowest loop: 2.99ms; fastest: 0.08ms
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 237, MaxWait: 495583ms, Underruns: 0, 0
    Scheduled moves: 32, completed moves: 32
    Bed compensation in use: none
    Heater 0 is on, I-accum = 0.0
    Heater 1 is on, I-accum = 0.4
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 167.51ms; fastest: 0.08ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address b4:e6:2d:52:f6:a2
      WiFi Vcc 3.40, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 16696
      WiFi IP address 192.168.0.201
      WiFi signal strength -51dBm, reconnections 0, sleep mode modem
      === Expansion ===
    Any help / things to look for most welcome.
    The only change I made since it last worked was to add the duex5 to do 3 point bed leveling (I have now removed that (and related gcode) and gone back to 1 z stepper (2 motors) as a point of elimination
    Regards,
    Mark
  • As an additional test I have also tried printing direct on the duet screen and that also does not start the print.
  • Just to be clear. You can home all the axes, heat the bed, heat the hot end and extrude filament yes?
  • @deckingman Yes, I have full control of the printer and everything works, I just can't start a print
  • @mark That's very odd. Does it do it with every gcode file or just one particular file? I wonder if your SD card has become corrupted. Have you tried a different card?
  • @deckingman
    I have tried a new Benchy and a calibration cube that has been on the card a while and printed previously.
    If I backup all the files on the card and do a factory reset and the issue still persists (once I do a manual setup again), can I just copy the backed up files back on the card to get back to where I am at the moment?
  • Moderator
    An easier test would be to use a new sd card. Copy the contents of your current card over and try the new card.
  • @Phaedrux 👍 will try it out tonight
    Thanks
    @mark, your M122 report indicates that the last software reset was user-initiated, not a crash. This may have been caused by using the Emergency Stop button, or by sending M999, or by upgrading firmware.
  • I figured it out, and am very ashamed to say it was user error 😞
    I accidently uploaded the slt rather than G-code file!
    @deckingman thanks for your input and keep up the good work on your projects, you have a new follower
    @Phaedrux thanks for the advice
    @dc42 Again thanks for responding - should uploading anything else other than a g-code file to print be a valid user story?
    Again thanks all for you inputs
    Mark
  • Moderator
    How did you upload an STL? I've just tried and the file selector greys them all out and dragging and dropping won't take it either.
  • @Phaedrux I can still upload a stl. Maybe I am not using the latest firmware - I need to work out how to update it, but that's a job for another day!
  • Moderator
    Download this zip file https://github.com/dc42/RepRapFirmware/releases/download/2.03/Duet2Firmware-2.03.zip
    Then upload the whole zip file as is to the Settings page in the DWC. That's all you have to do.
