Need some CoreXY advice
@gtj0 said in Need some CoreXY advice:
Having the motors at the front is no problem for me
This is similar to Hypercube Evolution. The front top crossmember is indeed in the way as you say but lowering it 10-15cm instead of removing completely solves that problem for me.
Well...
- Stationary Y rails are straight and parallel
- Gantry X rails are straight, parallel and perpendicular to the Y rails
- The belts are parallel to their respective rails
- The belts are firm but not over-tightened
- Directing the X and Y axes to move 450mm results in 450mm of movement within what I can measure (about .25mm) I did need to adjust the X steps/mm to 160.40 rather than the calculated 160 to get that.
- The tool carriage is solidly held by the motors. No movement in X or Y nor is there any rotation around Z.
Yet, I still get....
The boxes are 20mm square printed in 10mm segments in the order and direction shown. Both boxes are drawn the same. The circles are drawn from 270deg using G2 (clockwise) in the left box and G3 (counterclockwise) in the right box.
Notice the mismatch where the lines meet in the middle of each side with the left Y line being the worst. Also notice the astigmatism in the circles is different depending on which way the circles were drawn.
I'd immediately say "slop" but I can't figure out where. If I move each axis back and forth, I get the same amount of measured movement and the tool carriage has no movement in any direction. The only thing I can think of at this point is that I needed 4.75m of 9mm belt but I only had 4.5m of the genuine Gates so I had to use a 5m length of no-name stuff for now. Can anyone think of anything else offhand?
How fast was it going? Acceleration? Jerk?
@gtj0 Is the hot end nice and secure. If you put your finger on the nozzle, can you move it in X or Y? Could the drag of your wires and Bowen tube cause the hot end to tilt?
@deckingman I think the tool carriage has a pen mounted on it.
I'd suspect the pen holder is a bit sloppy, or he's running too fast- the distortion in the circles looks like what happens when you try to print small perimeters at very high speed. I suspect the different moving masses in X and Y and flexibility in the X axis lead to the distortion.
I ran my xy stage as a plotter before I finished the printer. I mounted a ball point pen on a short linear guide so there was no lateral slop. The pen could move up and down so even if the paper surface wasn't parallel to the XY plane it worked fine.
@mrehorstdmd said in Need some CoreXY advice:
The issue seems to be independent of speed and acceleration. Currently I have as a test...
M566 X600 Y600 Z125 E6000 ; Set maximum instantaneous speed changes (mm/min) *** M201 X600 Y600 Z125 E6000 ; Set accelerations (mm/s^2) *** M204 P600 T600 M203 X16000 Y16000 Z2400 E2400 ; Set maximum speeds (mm/min) ***
and the boxes are drawn with
F6000
but I've tried various other speeds and accelerations.@deckingman said in Need some CoreXY advice:
The nozzle is rock solid. I'll post some pics of the setup in a bit.
Nope, no pen holder. I clamped some old fashioned thermal fax paper on the bed and set the hot end to 145C. I'm going to try some super-low speeds and accelerations and see what happens.
I'll also get some pics of the various components up so you can see what's involved.
That's brilliant.
The nozzle isn't dragging the paper, is it?
When I first started using this method last year I did a calibration effort that resulted in homing the Z axis directly on the bed (I use an Orion Piezo with no Z offset), raising 5 mm, then moving over the paper and drawing at an absolute height of 0.05. This gives the nozzle enough contact with the paper to activate it but not enough to cause the paper to ripple. I also heat the nozzle high enough to melt plastic first and make sure the nozzle is perfectly clean, then let it cool down.
This is the paper I use...
https://smile.amazon.com/gp/product/B00006B7QA/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1I tear off a length to match the width of the bed (510mm) then use 4 spring clamps to secure it.
@bot said in Need some CoreXY advice:
That's brilliant.
Comes from being old enough to have used fax machines that had handset couplers and a spinning drum you clamped a sheet of thermal paper to.
a spinning drum you clamped a sheet of thermal paper to ...
What is paper?
@zapta said in Need some CoreXY advice:
What is paper?
Ha!
@mrehorstdmd
At last I understand the differing opinions on core-xy with twisted crossing.
Some say it works well and runs smoth, and others say it grinds the belts rapidly.
Most agree that the belts need to be back to back as they cross.
But here comes the point:
They have to be "back to back" all the way! Your belts have the teeth facing each other at the pulleys.
You do the 180ยบ twist, and avoid that the teeth face each other in the middle. But the result is that
they scratch edge to edge instead (at two points).With the usual core-xy with twisted crossing layout, you can do it like the image below.
Green circles marks twisted regions. Black lines next to the red/blue lines marks the side with teeth. -
Just FYI... I've been running my single-level back-twist arrangement for over a year now with the same belt and no wear at all.
