    Need some CoreXY advice
    My Duet controlled machine
    10
    30
    2.5k
    • mrehorstdmdundefined
      mrehorstdmd
      I don't think so- the belts were riding hard on the pulleys. Maybe the long span is the problem and the sagging of the belts under their own weight may have caused the problems.
      • gtj0undefined
        gtj0 @mrehorstdmd
        @mrehorstdmd said in Need some CoreXY advice:
        Gotcha. Maybe I'll use a forked guide in the center to make sure both belts are supported.
        • fmaundefined
          fma
          I use the same-plane configuration, with twisted belts for several months, and I have no issue. The belts cross on they back, and I have a PTFE sheet between them, maintained by a 3D-printed part.
          About dust on idlers, I had some with my previous chineese belt. As its core finally broke (it was really garbage), I bought a Gates, and I don't see anymore dust.
          text alternatif
          Frédéric
          • sonderzugundefined
            sonderzug
            @gtj0 said in Need some CoreXY advice:
            ...and I'm thinking about moving to a CoreXY design to get rid of that front cross member that always seems to be in my way.
            If I built a printer in the future, it would be a coreXY for multiple reasons including this one. However, just choosing coreXY would indeed allow omitting the beam in front, but you'd still either have the belts running across the frame opening in the front, or the motors in the front left and right depending how you orient the belt system. E3D (amongst others) have solved this problem by using one or two more idlers per belt, locating the motors in the back while keeping the open front with their toolchanger platform.
            not really answering your question, but I thought this might be interesting as well.
            • gtj0undefined
              gtj0
              @fma Yeah I stopped buying no-name belts and got the genuine Gates belts and have been much happier.
              @sonderzug Having the motors at the front is no problem for me because they sit inside the profile of the 50mm extrusions. Interesting idea though.
              • fmaundefined
                fma
                I put the motors above the vertical frame profiles, so they don't bother me.
                text alternatif
                Note that I kept the top front profile, but it could be remove, to have full access to the printer (the frame uses 45x45 profiles I had, so is very rigid).
                Frédéric
                • gtj0undefined
                  gtj0
                  OK, I've rebuilt the kinematics but my brain is on vacation...
                  For a CoreXY, when you measure and set steps per millimeter are you doing it for an axis or a drive?? The description of M92 seems to use both axis and drive interchangeably.
                  Basically, should I be isolating the drives while measuring or measuring axis movement with both drives enabled?
                    deckingman @gtj0
                    @gtj0 You set steps per mm for the axes. For one thing, a single drive will give you diagonal movement. For another thing, when you do pure X or pure Y and both motors are employed, the motor movement is about 1.4 x the axis movement.
                    Basically, treat it like you would a Cartesian when setting the steps per mm and let the firmware worry about the calculations.☺
                    • gtj0undefined
                      gtj0 @deckingman
                      Thanks @deckingman !
                      • zaptaundefined
                        zapta @gtj0
                        This is similar to Hypercube Evolution. The front top crossmember is indeed in the way as you say but lowering it 10-15cm instead of removing completely solves that problem for me.
                        • gtj0undefined
                          gtj0
                          Well...
                          • Stationary Y rails are straight and parallel
                          • Gantry X rails are straight, parallel and perpendicular to the Y rails
                          • The belts are parallel to their respective rails
                          • The belts are firm but not over-tightened
                          • Directing the X and Y axes to move 450mm results in 450mm of movement within what I can measure (about .25mm) I did need to adjust the X steps/mm to 160.40 rather than the calculated 160 to get that.
                          • The tool carriage is solidly held by the motors. No movement in X or Y nor is there any rotation around Z.
                          Yet, I still get....
                          The boxes are 20mm square printed in 10mm segments in the order and direction shown. Both boxes are drawn the same. The circles are drawn from 270deg using G2 (clockwise) in the left box and G3 (counterclockwise) in the right box.
                          Notice the mismatch where the lines meet in the middle of each side with the left Y line being the worst. Also notice the astigmatism in the circles is different depending on which way the circles were drawn.
                          I'd immediately say "slop" but I can't figure out where. If I move each axis back and forth, I get the same amount of measured movement and the tool carriage has no movement in any direction. The only thing I can think of at this point is that I needed 4.75m of 9mm belt but I only had 4.5m of the genuine Gates so I had to use a 5m length of no-name stuff for now. Can anyone think of anything else offhand?
                            mrehorstdmd
                            How fast was it going? Acceleration? Jerk?
                              deckingman @gtj0
                              @gtj0 Is the hot end nice and secure. If you put your finger on the nozzle, can you move it in X or Y? Could the drag of your wires and Bowen tube cause the hot end to tilt?
                                mrehorstdmd @deckingman
                                @deckingman I think the tool carriage has a pen mounted on it.
                                I'd suspect the pen holder is a bit sloppy, or he's running too fast- the distortion in the circles looks like what happens when you try to print small perimeters at very high speed. I suspect the different moving masses in X and Y and flexibility in the X axis lead to the distortion.
                                I ran my xy stage as a plotter before I finished the printer. I mounted a ball point pen on a short linear guide so there was no lateral slop. The pen could move up and down so even if the paper surface wasn't parallel to the XY plane it worked fine.
                                plotter operation
                                • gtj0undefined
                                  gtj0 @mrehorstdmd
                                  The issue seems to be independent of speed and acceleration. Currently I have as a test...
                                  M566 X600  Y600  Z125  E6000  ; Set maximum instantaneous speed changes (mm/min)  ***
                                  M201 X600  Y600  Z125  E6000   ; Set accelerations (mm/s^2) ***
                                  M204 P600 T600
                                  M203 X16000 Y16000 Z2400 E2400  ; Set maximum speeds (mm/min) ***
                                  and the boxes are drawn with F6000 but I've tried various other speeds and accelerations.
                                  @deckingman said in Need some CoreXY advice:
                                  The nozzle is rock solid. I'll post some pics of the setup in a bit.
                                  Nope, no pen holder. I clamped some old fashioned thermal fax paper on the bed and set the hot end to 145C. I'm going to try some super-low speeds and accelerations and see what happens.
                                  I'll also get some pics of the various components up so you can see what's involved.
                                  • botundefined
                                    bot @gtj0
                                    That's brilliant.
                                    *not actually a robot
                                      mrehorstdmd
                                      The nozzle isn't dragging the paper, is it?
                                      • gtj0undefined
                                        gtj0 @mrehorstdmd
                                        When I first started using this method last year I did a calibration effort that resulted in homing the Z axis directly on the bed (I use an Orion Piezo with no Z offset), raising 5 mm, then moving over the paper and drawing at an absolute height of 0.05. This gives the nozzle enough contact with the paper to activate it but not enough to cause the paper to ripple. I also heat the nozzle high enough to melt plastic first and make sure the nozzle is perfectly clean, then let it cool down.
                                        This is the paper I use...
                                        https://smile.amazon.com/gp/product/B00006B7QA/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
                                        I tear off a length to match the width of the bed (510mm) then use 4 spring clamps to secure it.
                                        • gtj0undefined
                                          gtj0 @bot
                                          @bot said in Need some CoreXY advice:
                                          That's brilliant.
                                          Comes from being old enough to have used fax machines that had handset couplers and a spinning drum you clamped a sheet of thermal paper to. 🙂
                                          • zaptaundefined
                                            zapta @gtj0
                                            a spinning drum you clamped a sheet of thermal paper to ...
                                            What is paper?
