    Super Volcano with BMG and 0.9 Motor Wierd behaviour
    925
    • TonyGRundefined
      TonyGR
      Hello Mindhive and thank you in advance for your input.
      I have build a CoreXY on which i use Zaribo motors 1.8 for XYZ and 0.9pankake for E with BMG extruder and an E3D supervolcano.
      At the moment i am trying on Prusa Slicer to build a profile and it seem i have found my self with a curious issue.
      I have Calibrated E steps and multiplier and i get precise thickness over 2 outer walls, but when it comes to my infill, its always much thinner than what i have setup.
      My configuration is as follows and i have attached pictures of slicer settings.
      M350 X32 Y32 Z16 E8 I1 ; Configure microstepping with interpolation
      M92 X160.00 Y160.00 Z400.00 E407.00 ; Set steps per mm
      M566 X800.00 Y800.00 Z100.00 E3000.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
      M204 P6000 T6000 ; Set printing and travel accelerations
      M201 X5000.00 Y5000.00 Z60.00 E3000.00 ; Set accelerations (mm/s^2)
      M906 X850.00 Y850.00 Z950.00 E950.00 I35 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S303_1562755413973_image3.jpg 2_1562755413972_image2.jpg 1_1562755413972_image1.jpg 0_1562755413967_extrusionwidth.jpg
      • Martin1454undefined
        Martin1454
        rectilinear infill? try grid instead
        • OBELIKSundefined
          OBELIKS
          Are you using Maestro board? If not M350 line is not OK, but its not the problem here.
          Try to set Max volumetric speed in slicer to 20 (it's under Filament settings-Advanced or under Print settings-Speed) and see if it is any better.
          P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
          Original Prusa i3 MK3S
          • TonyGRundefined
            TonyGR
            I am using the wifi board and for some reasson with M350 E8, i found better results than 16 microsteps.
            I will check the volumetric config on slicer. Thank you.
            • mrehorstdmdundefined
              mrehorstdmd
              If the infill is rectilinear, it is bridging. 0.8 bridge flow ratio x 0.7 line width = 0.56 mm, not too far from what you're measuring. When bridging the line won't get squashed flat, so it will probably measure narrower than the calculated value, which means it's probably about right.
              • TonyGRundefined
                TonyGR
                Had never though that rectalinear might be considered bridging. Makes sense and i will test more infill patterns to compare. Thank you
                • singhm29undefined
                  singhm29
                  Apologize for reviving such an old post but would be really interested to hear where you ended up and if you wouldn't mind sharing your Prusaslicer profile!
                  TonyGRundefined 1 Reply Last reply Reply Quote 0
                  • TonyGRundefined
                    TonyGR @singhm29
                    @singhm29 No problem sharing my current profile for my Ratrig CoreXY. Would you like PLA or PETG? Remember that this is for a SuperVolcano
                    singhm29undefined 2 Replies Last reply Reply Quote 0
                    • DocTruckerundefined
                      DocTrucker
                      I see no linear or non-linear extrusion correction. Was that checked?
                      • singhm29undefined
                        singhm29 @TonyGR
                        @TonyGR PLA please! Yep tackling the supervolcano as well. What nozzle size did you end up sticking with?
                        • singhm29undefined
                          singhm29 @TonyGR
                          @TonyGR don't forget about me 😞
