    CNC style Pendant
    Hardware wishlist
    28
    155
    17.9k
    • JoergS5undefined
      JoergS5 @FelixH
      @FelixH If you need PanelDue also, you could consider a solution similar to SMUff https://github.com/technik-gegg/SMuFF-Ifc where an ESP32 is between and allows two devices using the interface.
      FelixHundefined 1 Reply Last reply Reply Quote 0
      • FelixHundefined
        FelixH @JoergS5
        @JoergS5 that's a neat project! However, I will quote Rocket Racoon on this one... "I go for the simple things"... would it be possible to just attach a switch on the UTXD0 and URXD0 pins and flip the switch to the input device you need?. It's not like I need to use them both simultaneously, I think... I guess the answer is no, but still it would be the simplest thing to do
        arhiundefined 1 Reply Last reply Reply Quote 0
        • arhiundefined
          arhi @FelixH
          @FelixH said in CNC style Pendant:
          double pole double throw switch should work without a problem for this purpose selecting one or the other device
          • arhiundefined
            arhi @dc42
            @dc42 said in CNC style Pendant:
            I've written the Arduino Nano code for the pendant-to-PanelDue-port interface
            question. are you sending many short G0 while receiving impulses from the encoder or you scan at a certain frequency (e.g. 2Hz or 10Hz) and then send G0 according to what encoder did between scans? I'm making this wifi pendant for a while now and having issues deciding what I want. First version I made with buttons, then replaced buttons with a stick but now stick is behaving like buttons (you have to move stick for each movement and select increment on other button) and I don't like it. now I'm attaching analog stick so I can use 2-3 different speeds according to the angle of the stick but again, don't know if I wanna send ton of 0.1-10mm gcode's in a loop, or do 2Hz scan and send only gcode's at that frequency. You for sure have more experience with this so know what might be better solution. I guess analog stick is similar to the encoder so decisions should be similar :). Now I'm thinking about adding encoder to the stick too 😄 (I'm never going to finish this, first screen, then stick, then analog stick, now encoder... neverending story).
            p.s. I didn't want to go with "ready made pendant" as they were "expensive", now looking at %$#^^@$# I crammed in to the box it's more expensive than ebay 😞
              dc42 administrators @arhi
              @arhi said in CNC style Pendant:
              I've written it to accumulate movement from the encoder and send it only when the UART transmit buffer is empty. I suspect this will still be too often, and I will need to send it every X milliseconds instead, or immediately if we haven't sent a command for the last X milliseconds.
              • FelixHundefined
                FelixH
                Yesterday I got my Pendant, exactly as the one pictured. I could start working on the implementation on my spare time
                  dc42 administrators @FelixH
                  I'm still waiting for mine, but feel free to try my code. It's at https://github.com/Duet3D/CNC-Pendant-Firmware.
                  • arhiundefined
                    arhi @dc42
                    Serial.write("M112 ;" "\xF0" "\x0F" "\n");
                    any special reason for 0xF00F between M112 and 0x0A ? I see it comes after ; so it's a comment but ?
                      It's a special emergency stop code recognised by the input buffer code on the Duet, so that the emergency stop command bypasses the command buffers.
                      arhiundefined 2 Replies Last reply Reply Quote 1
                      • arhiundefined
                        arhi @dc42
                        @dc42 great, good to know 🙂
                        • arhiundefined
                          arhi @dc42
                                int distance = encoder.getChange() * distanceMultiplier;
                                if (axis >= 0 && distance != 0)
                                  whenLastCommandSent = now;
                                  Serial.write("G91 G0 ");
                                  Serial.print(distance);
                                  Serial.write('\n');
                          seems to me axis is missing from the G0 ?
                            That's because I failed to complete a recent change. Change the line:
                            to:
                            Serial.write(MoveCommands[axis]);
                            • arhiundefined
                              arhi
                              @dc42 do you think it's better for wireless pendant to telnet to the RRF and send G-codes or to exec g-codes trough http://rrf/rr_gcode ?
                              gtj0undefined 1 Reply Last reply Reply Quote 0
                              • gtj0undefined
                                gtj0 @arhi
                                If you use http, you can use the pendant with either a Duet in standalone mode or via the DSF (with a slight change to the URL).
                                • arhiundefined
                                  arhi @gtj0
                                  @gtj0 that's the reason I'm asking. HTTP approach looks better but dunno if there are penalties. I went forward last night and since I need a "send g-code" function in one place only it's not a big deal to have few different ones (one for telnet, one for http, one for - whatever...) as it will not be affecting the code.
                                  I took a 2stick module from some broken game controller, that gives me 2 buttons + 4 axes with limited speed control (2k2 pots on the axes are not very precise, I can safely detect 2 speeds, maybe 3 especially as I added 4k7 in series so the swing is even lower, I might remove the 4k7 but 4x2k2 in parallel on the 3v3 rail is 6mA constant drain on the battery), attached to ESP32+BMS.
                                  Telnet works for now but I'm still thinking if I need to add more buttons 😄 and leds.
                                  • Danalundefined
                                    Danal
                                    Somewhere in all the above I ordered a pendant a few weeks back. JUST after I ordered it, Dave published his code. Which is great, not having to write it... so I haven't done much since then.
                                    I have received the pendant now.
                                    I'm thinking about an ESP32 (massive, massive, overkill, but they are $5 each...!) setup to do Serial or Network, including RRF2 or RRF3 printers. And just experimenting to see if it "feels" right when hooked up by various methods.
                                    And a battery and an "off the shelf" USB charger/manager for the battery.
                                    Going back and forth on having a small display, XYZ.
                                    • gtj0undefined
                                      gtj0 @Danal
                                      @Danal Lock picking for fun and profit?? 🙂
                                      • Danalundefined
                                        Danal
                                        Ooops... need to move that.
                                        You nailed the goal. That is my practice set, they get progressively harder. Keep the 'ol fingers skilled up.
                                        • gtj0undefined
                                          gtj0 @Danal
                                          @Danal The LockPickingLawyer is my hero.
                                          • FelixHundefined
                                            FelixH
                                            Arduino Nano to Duet PanelDue connector connections:
                                            Nano    Duet
                                            +5V     +5V
                                            GND     GND
                                            TX1/D0  Through 5K6 resistor to URXD, also connect 10L resistor between URXD and GND
                                            I don't have any 5K6 resistor at home, and I don't feel like driving 75 km to get one. Is there any way to make this connection possible? My 2 ideas are:
                                            • Using a 3.3 to 5 v logic converter
                                            • Using a 3.3v board to drive the pendant (I have some overkill ESP32 on stock)
                                            Also, I'm guessing that 10L means to be 10K, right?
