Think its broken...
  • Guys
    apologies but i am a little frustrated. So having had issues getting the wifi connect before, it now seems that the wifi is faulty. Having read the forums regarding my error and having tried everything ive come across i still cant get the wifi working again.
    WiFi reported error: network scan failed
    WiFi module is idle
    WiFi module is idle
    Error retrieving WiFi status message: SPI timeout
    WiFi module is idle
    Failed to change WiFi mode (code -7)
    m552 S1
    ok
    WiFi module started
    m552
    WiFi module is changing mode
    ok
    Then the entire YAT sreen fills up with this....
    WiFi module is idle
    WiFi module is idle
    I am sure this is only my bad luck, but i have actually not even been able to get as far as a test print since starting this upgrade.
    Thanks
    Shaun
  • m122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-9T6BU-FG3SN-6J9F4-3SD6R-TUZHF
    Used output buffers: 1 of 24 (24 max)
    Static ram: 25680
    Dynamic ram: 93644 of which 0 recycled
    Exception stack ram used: 304
    Never used ram: 11444
    Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3844) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:06:45 ago, cause: reset button or watchdog
    Last software reset at 2019-09-11 08:23, reason: User, spinning module GCodes, available RAM 11436 bytes (slot 2)
    Error status: 4
    Free file entries: 10
    MCU temperature: min 35.3, current 36.4, max 36.5
    Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
    Driver 0: ok, SG min/max not available
    Driver 1: ok, SG min/max not available
    Driver 2: ok, SG min/max not available
    Driver 3: ok, SG min/max not available
    Driver 4: ok, SG min/max not available
    Cache data hit count 816394668
    Slowest loop: 100.03ms; fastest: 0.06ms
    Hiccups: 0, FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "m122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.84ms; fastest: 0.00ms
    HTTP sessions: 0 of 8
    • WiFi -
      Network state is changing mode
      WiFi module is idle
      Failed to get WiFi status
      ok
      Error retrieving WiFi status message: bad reply format version
      WiFi module is idle
      Failed to change WiFi mode (code -4)
  • m122
    Static ram: 25680
    Dynamic ram: 93688 of which 0 recycled
    Never used ram: 11400
    Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3744) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:09:54 ago, cause: reset button or watchdog
    Error status: 4
    MCU temperature: min 36.0, current 36.4, max 36.5
    Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Cache data hit count 1195047035
    Slowest loop: 1.08ms; fastest: 0.06ms
    === DDARing ===
    Segments left: 0
    === Network ===
    Slowest loop: 1.95ms; fastest: 0.00ms
    • WiFi -
      WiFi module is trying to connect
      WiFi firmware version 1.23
      WiFi MAC address 84:f3:eb:41:4e:f8
      WiFi Vcc 3.40, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 26240
      ok
    Have you tried re-flashing the WiFi firmware?
  • @dc42 said in Think its broken...:
    DC i have, all went through fine. Was one of the 1st threads i read on here where you suggested that.
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-06-13b2
  • This doesn't look healthy or right to me.
    m552 s0
    ok
    m552
    ok
    WiFi reported error: Timed out while trying to connect to Spiffy
    WiFi module is idle
    @Shaun on this thread:
    https://forum.duet3d.com/post/107352
    It appeared that you were at the point where the wifi module was working. what changed since then?
    Let me clarify, WIFI now connects when i run M552 S0 then M552 S1. Webconsole also responds pretty quickly.
  • @T3P3Tony said in Think its broken...:
    Thats just it, i started checking the settings as per the links sent to me when i lost connection to the web console. Wifi light was then slowly flashing on and off. Thought it was my router and checked everything. Eventually plugged the board into my PC and ran some checks. The researched the errors on the forums and tried everything i could. Nothing worked, wifi kept saying changing mode. ive posted the outputs and ive now even re-installed the firmware and the WiFi. Nothing seems to change.
    Im happy to try anything else you want to throw my way.
  • Moderator
    What do you currently have in your config.g?
  • Still getting an error
    m552
    WiFi module is idle
    ok
    m122
    Static ram: 25680
    Exception stack ram used: 288
    Never used ram: 11416
    Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3756) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:09:08 ago, cause: software
    Error status: 4
    MCU temperature: min 36.5, current 37.1, max 37.3
    Cache data hit count 1085375973
    Slowest loop: 1.10ms; fastest: 0.06ms
    === DDARing ===
    Segments left: 0
    === Network ===
    Slowest loop: 2.02ms; fastest: 0.00ms
    • WiFi -
      Network state is running
      WiFi module is idle
      ok
      m552
      WiFi module is idle
      ok
  • @Phaedrux said in Think its broken...:
    ; generated by RepRapFirmware Configuration Tool v2.0.0 on Sun Sep 01 2019 16:01:34 GMT+0100 (British Summer Time)
    M550 P"CR10" ; set printer name
    M350Z16 I0 ; configure microstepping without interpolation
    M350X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z400 S0 ; set axis maxima
    M574 X1 Y1 Z1 S1 ; set active high endstops
    M574 Z1 S3 ; set endstops controlled by motor stall detection
    M574 Z1 S2 ; set endstops controlled by probe
    M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
    G31 P0 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S1 I0 F500 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H-1 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
  • Moderator
    @Shaun said in Think its broken...:
    Unrelated, but you're missing a space between the M350 and the axis letter.
    I understand the frustration. Let's see if we can nail down the issue.
    The config looks ok.
    Can you send M587 by itself to get a list of saved SSIDs? This will confirm that the SSID has been properly added.
    The error message network scan failed would indicate that it's unable to identify a network SSID in range to connect to and it's given up. In your other thread we did identify that the signal strength was rather weak. In order to diagnose if this is in fact the case, I suggest temporarily relocating the wireless access point or the printer so that they are both in close proximity with very little obstruction and seeing if you can then in fact connect.
    Remembered networks:
    Spiffy IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
    ok
    Signal is 100%
    How do i clear any config for network. maybe a clean slate would be a good idea.
  • I have redone the config.
    ; generated by RepRapFirmware Configuration Tool v2.0.3 on Wed Sep 11 2019 09:04:56 GMT+0100 (British Summer Time)
    M552 S0 ; enable network
    M558 P0 H5 F0 T6000 ; disable Z probe but set dive height, probe speed and travel speed
    M106 P0 S0 I0 F300 H1 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P1 S0 I0 F300 H1 T150 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
  • Moderator
    From the previous thread:
    From the console can you please send the following:
    M552 S0
    M588 S"*"
    M587 s"Spiffy" p"Password1"
    M552 S1
    M122
    This will take the wifi module to idle, clear all saved SSIDs, re-add your SSID, and re-enable the module and hopefully connect. Then the diagnostic should show the connection stats.
    M552 S0
    M588 S"*"
    M552 S1
    M122
    I’ve done all of that, same problem. Ill set up my old router tonight and see if I can connect to that. Just in case it’s my current router.
  • @Shaun said in Think its broken...:
    Is it just me or are those 1.6-1.8V VIN indeed usable? 😮
    @themelle if just powering off USB (fine for WIFI tests) you don't need VIN
  • @T3P3Tony Ah ok, I see 🙂
    (I thought powering off USB would show up as VIN around 5V)
    Thanks for clarifying!
  • OK so ive done the following.
    Changed WiFi SID, no change
    Changed WiFi Password. no change
    Tried old router, no change
    I get the same result each time.
    Used output buffers: 1 of 24 (10 max)
    Static ram: 25680
    Exception stack ram used: 256
    Never used ram: 11492
    Tasks: NETWORK(ready,1244) HEAT(blocked,1236) MAIN(running,3808) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:08:56 ago, cause: power up
    Error status: 0
    MCU temperature: min 34.9, current 35.9, max 36.1
    Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
    Cache data hit count 1062453510
    Slowest loop: 46.87ms; fastest: 0.06ms
    === DDARing ===
    Segments left: 0
    === Network ===
    Slowest loop: 77.22ms; fastest: 0.00ms
    • WiFi -
      WiFi Vcc 3.39, reset reason Hardware watchdog
      WiFi flash size 4194304, free heap 26560
      ok
    I am now totally exhausted.
