    Jubilee on Hackaday
    624
      droftarts administrators
      https://hackaday.com/2019/11/14/jubilee-a-toolchanging-homage-to-3d-printer-hackers-everywhere/
      Hey, @Danal, you're mentioned on Hackaday!
      • T3P3Tonyundefined
        T3P3Tony administrators
        great write up @poofjunior
        www.duet3d.com
        • wilrikerundefined
          wilriker
          I have some kind of feeling that I will build a Jubilee or something similar... 🤦 😂
          Manuel
          My Tool Collection
          • fmaundefined
            fma
            What about having a coupler between the motor and the extruder, which allow the motor to be mounted on the carriage, and the hotend+extruder gears on the tool?
            This woule make a direct-drive extruder, without the need of multiple motors...
            Frédéric
              droftarts administrators @fma
              @fma That's what I've suggested many times before, but it does effectively limit the machine to being a 3D printer. The advantage of changing the whole tool is that other tools can perform different functions.
              Edit: Actually, I'd go further, and have the hot end on the carriage as well as the extruder motor, so you're just changing the extruder with the loaded filament. Fine tuning the filament swap would be the main headache!
              • fmaundefined
                fma
                @droftarts said in Jubilee on Hackaday:
                Right!
                Well, it's close to the MMU...
                My other idea was to have the motor and extruder on the carriage, and swap the hotend alone, with the loaded filament. The tricky part is to 'open' the extruder gears to clamp and release the filament...
                Frédéric
                • jens55undefined
                  jens55
                  I am looking forward to the day when a company packages everything as a kit and sells it that way. Even better, make it available in the 'normal' size and a 'super size'. Sell the controller separate as an add-on.
                  Getting the individual pieces is going to get expensive for freight costs and of course the fact that one is buying small qty of parts here and there means that parts costs are fairly high.
                  Danalundefined 1 Reply Last reply Reply Quote 0
                  • Danalundefined
                    Danal @jens55
                    @jens55 said in Jubilee on Hackaday:
                    See the "Group buy" channel on this discord:
                    https://discord.gg/ZnKW8f
                    (note: Link expires Nov 17 2019, 09:45 CST)
