    Need your advice, V-Slot VS Linear Rail.
    Example setups and prints
    13
    31
    15.5k
    • Rudy2Aundefined
      Rudy2A
      Hello everyone,
      I need your opinion ... I have the project to build a new 3D printer (CoreXY) and I hesitate on XYZ guidance.
      V-Slot or Linear Rail ?
      V-Slot:
      Linear Rail:
      Advantage disadvantage ?
      The printer will have an area of ​​X300 Y300 Z400 with 2 extruders. Nothing is stopped, since it's me who makes the plans.
      Thank you very much for your advice.
      Rudy2Aundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        Me, personally, linear all the way. Considered as a percentage of the total cost of the printer, they are a trivial cost for noticeably better prints.
        Especially because you are asking on the forums for one of the most "high end" controllers available. V-Slot/Roller goes with sub $50USD 8 bit boards. Linear goes with 32 bit boards. Or something like that. 🙂
        • Rudy2Aundefined
          Rudy2A @Rudy2A
          @Rudy2A said in Need your advice, V-Slot VS Linear Rail.:
          J'ai le projet de construire une nouvelle imprimante 3D (CoreXY)
          Of course, all driven by a Duet 2 or 3 ...
            I use V slot to good effect on my printer, though if I was doing it all over again, given the relatively low cost of linear rail hardware these days, I would probably go with linear rails.
            • deckingmanundefined
              deckingman @Danal
              @Danal said in Need your advice, V-Slot VS Linear Rail.:
              Ouch - that's harsh! Especially the bit about "noticeably better prints". Unless you know something that I don't.
              I get asked the question quite a lot on my blog and YouTube channel -i.e. "Why don't you use linear guides" and my answer is always the same - "the Open Builds V slot members are linear guides - so why would I want to attach a linear guide to a linear guide?"
              But like @Phaedrux if was starting again, I might consider using "conventional" linear guides. Not because I believe it will give my any better prints but because it would likely save me some money. At the last count on my CoreXYUVAB I have 60 odd sets of twin bearing Delrin wheels at around £10 a pop. So I've spent upwards of £600 on "non-linear guide" linear guides if you get my meaning.
              Having said all that, they have served me well over thousands of hours of printing with no maintenance and with no problems or issues of any sort. They do need to be set up and adjusted properly to start with though. I'd say the main disadvantage of Open Builds V slot is that the carriages tend to be a bit big in comparison.
                deckingman
                @Rudy2A One piece of advice if you do decide to go the Vslot route is not to use a single gantry plate as shown in your first picture because the bolts could potentially "flex". Use double plates so that the bolts are fixed at both ends rather than the cantilevered arrangement that is so often used. This kind of thing
                Rudy2Aundefined 1 Reply Last reply Reply Quote 2
                • fcwiltundefined
                  fcwilt
                  I have had only one printer that used the V-slot approach. The rebuilt printer using linear rails works much better.
                  • Vetiundefined
                    Veti
                    i second linear rails.
                    i swapped my v slot rails on the ender 3 y axis with linear rails and its a lot more ridgid than before.
                    my other 2 printers are linear rails.
                    • Catalin_ROundefined
                      Catalin_RO
                      I personally experienced exactly what @deckingman mentioned - any "proper" linear rail might be cheaper than the whole V-Slot solution these days. And to make matters worse, there are better quality (more rigid!) standard extrusions that are cheaper to buy. When deciding on which way to go when my wheels on the Y-axis of the WorkBee CNC started to exhibit problems, supported round linear rails (safer for not very rigid machine, and a desktop CNC like the WorkBee is usually not very rigid!) where less than half the price (the WorkBee has 28 wheels on the Y axis!!!).
                      I still have to handle the X and Z axis (due early next year!), but the improvement is visible!
                      • A Former User?
                        A Former User
                        vslot - 3 to 8 rollers usually made out of %@^*& material rolling on the aluminium profile .. both rollers (wheels) and the profile deform over time, aluminium while light is also super soft, dust and other crap collect, stick to the rollers and additionally kills precision ... so, it's cheap, it's "ok", but is far from ideal ... I have not seen anywhere the moment of force these are handling for all degrees of freedom!! ..
                        hiwin style linear rail - hardened balls rolling over hardened steel rail, 40 up to many hundreds of balls in each wagon -> many many many points of contact. properly specified acceptable moment of force for all degrees of freedom. relativly closed design so dirt does not collect a lot .. the con side is you can't use the rails as construction material (like with vslots) so you have added cost and weight. additional "problem" is that there are some reeeeeally shitty prc made rails that have huge tolerances and balls made out of crap so you should know what you buy from where 🙂
                        if you are drafting your prints (most of my printers are running in "draft" mode) the difference in quality is irrelevant, the layers not being laid ideally on top of each other are not a big deal.... but if you do a high quality prints too, there's huuuuuge difference between new v-slot and used rails .. and v-slot with few hundred hours under it's belt .. ...
                          Phaedrux Moderator @A Former User
                          @smece said in Need your advice, V-Slot VS Linear Rail.:
                          huuuuuge
                          😂 What's a few microns between friends.
                          • mrehorstdmdundefined
                            mrehorstdmd
                            Another advantage to linear guides is that their compact size makes it easier to enclose the printer if you want to. Usually you can just bolt some side panels to the printer's frame.
                            The V-slot wheel carriages are running on the printer's frame, so an enclosure has to be built to enclose the whole thing.
                            • yamanundefined
                              yaman
                              to to high quality Linear Rail , linear rail more rigid than V-solt
                              V slot you need to maintain form time to time and the wheels need to change almost every 2 years
                                deckingman @yaman
                                @yaman The rigidity of the linear rail depends on the rigidity of the member that it's bolted to. Likewise the rigidity of vslot depends on the size of the chosen profile. Changing wheels every 2 years is absolutely not necessary if they are tensioned correctly in the first place. Likewise adjusting them.
                                I'll just reiterate that my machine with it's 5Kg plus of moving mass has run for thousands of hours with no adjustment or replacements and motion wise, it worked as well when it was demonstrated at the TCT show in 2017 as it did a couple of months ago in 2019.
                                I'm not advocating one system over the other but there is a lot of misinformation about vslot in this thread. Ultimately the quality and reliability of both "conventional" linear guides and vslot linear guides is down to the quality of the components used, especially bearings, and also how each one is fitted and aligned.
                                • DeltaConundefined
                                  DeltaCon
                                  I am not convinced about linear rail (as defined in the OT). I would go with what Deckingman says. I have read SO MUCH bad experiences with linear rail, especially if you want to go cheaper than the original HIWIN ones (and most of us do want that!).
                                  However I would like to bring these into the equation:
                                  Look at the specs. they look very promising and are much cheaper!
                                  https://us.misumi-ec.com/vona2/detail/110302192160/?HissuCode=PLRH25-560
                                  Or how do we feel about these:
                                  Specifics at: https://www.exoslide.com/
                                  For 20x20, 20x40 and 40x40 available. But maybe not the cheapest solution.
                                  If you think trial and error is dangerous, try routine. That's even more so!
                                  deckingmanundefined A Former User? 2 Replies Last reply Reply Quote 0
                                    deckingman @DeltaCon
                                    @DeltaCon .........and there is also Igus Drylin which is a route I might consider if ever I build another machine
                                    https://www.igus.co.uk/info/linear-guides-linear-guides?gclid=CjwKCAiArJjvBRACEiwA-Wiqq1sfcYmCtI7TcjO7DKYwwFN9BEaYZwQo7fdXNu5dHxfud7TCh26KgxoCO_MQAvD_BwE
                                    One thing that hasn't yet been mentioned is noise. Vslot (and Drylin) are practically silent. My massive CoreXYUVAB with all 6 axes running at high speed is quieter than my old Mendel used to be.
                                    sonderzugundefined DeltaConundefined A Former User? 3 Replies Last reply Reply Quote 0
                                    • sonderzugundefined
                                      sonderzug @deckingman
                                      @deckingman drylin is an interesting mention, but they have to be choosen wisely and the machine has to be properly designed to address the fact that you can't have gliding motion without play. It is possible though, and I've seen some stunning results from printers with drylin-everything.
                                      They are practically silent as well.
                                      My own printer, which hasn't been introduced here yet, runs on drylin W (square shape). It's silent (loudest noise comes from the fans, or the steppers when in spreadcycle mode), dust-proof (yes - I'm not using my machine enough, but the drylin rails don't care), but there is some play in the motion system which makes for not-perfect parts (round parts have flat spots). Had I chosen drylin W with the round shape, I could have picked bearing blocks with set screws to tension the gliding elements.
                                      Drylin N is also widely used in printers, as a cheaper alternative.
                                      • DeltaConundefined
                                        DeltaCon @deckingman
                                        @deckingman said in Need your advice, V-Slot VS Linear Rail.:
                                        That's an interesting addition indeed. Already any idea of which type would be to be preferred?
                                        And wow... Interesting concept fo a delta printer 😉
                                        https://www.youtube.com/watch?v=kyAkmN8WEes&feature=youtu.be
                                        • zaptaundefined
                                          zapta
                                          Can a linear rail stand on its own as a X axis or does it need to be attached to an aluminum extrusion for extra strength?
                                          (considering to upgrade my HEVO but thinking of the moving mass in Y direction).
                                          fcwiltundefined deckingmanundefined DeltaConundefined A Former User? Danalundefined 5 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            fcwilt @zapta
                                            @zapta said in Need your advice, V-Slot VS Linear Rail.:
                                            I've seen folks do that but I wouldn't.
