    Hotend mosquito
    • froma1976undefined
      froma1976
      Alguien tiene el problema de que al configurar el hotend mosquito Magnum con la config tool calienta muy despacio después de 250 grados?
      zaptaundefined 1 Reply Last reply Reply Quote 0
      • sebkritikelundefined
        sebkritikel
        I have not had this issue with my Mosquito Magnum. Are you using the Slice Engineering thermistor? Have you properly set the thermistor values in the Duet config file? What heater cartridge are you using, and what power supply voltage (12v, 24v)?
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
        froma1976undefined 1 Reply Last reply Reply Quote 0
          froma1976 @sebkritikel
          @sebkritikel si, configurado con el config tool y fuente de 24v el termistor es el de slicer enginier
            froma1976 @froma1976
            @froma1976 y el cartucho de ellos 24v 50w
            • zaptaundefined
              zapta @froma1976
              E mafai ona e tuʻu lau faila faila ?
                droftarts administrators @zapta
                @zapta said in Hotend mosquito:
                Samoan! Nice. @froma1976 Please post your config.g.
