    BL-Touch don´t trigger by Home Z
    227
    • CupaCabra
      CupaCabra last edited by
      I have a other Problem with my Printer and BLTouch.
      I home X and Y, in the second step are Home Z.
      The Bed go´s UP but wehn i Trigger the BL-Touch mith my Finger the Pin are stif and the Bed want chrash into the BLTouch.
      my HomeZ config
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 13:42:31 GMT+0100 (Mitteleuropäische Normalzeit)
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X50 Y50 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      are those OK
      DIY-O-Sphere 1 Reply Last reply Reply Quote 0
      • DIY-O-Sphere
        DIY-O-Sphere @CupaCabra last edited by
        @CupaCabra
        Have you edited also the homeall.g?
        You have to change the M98 for calling the macros for deploy and retract...
        • Veti
          Veti last edited by
          post your config.g
          • CupaCabra
            The homeall.g
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v2.1.5 on Thu Jan 09 2020 09:19:35 GMT+0100 (Mitteleuropäische Normalzeit)
            G1 H1 X-405 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-405 ; home X axis
            G1 H1 Y-405 ; home Y axis
            G1 X5 Y5 F6000 ; go back a few mm
            G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y-405 ; then move slowly to Y axis endstop
            G1 H1 Z505 F360 ; move Z up stopping at the endstop
            G92 Z500 ; set Z position to axis maximum (you may want to adjust this)
            • CupaCabra
              and the config.g
              M550 P"My Printer" ; set printer name
              M667 S1 ; select CoreXY mode
              M551 P"123456" ; set password
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P4 S1 ; physical drive 4 goes forwards
              M584 X0 Y1 Z2 E3:4 ; set drive mapping
              M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z4000.00 E415.00:415.00 ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1400 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X400 Y400 Z500 S0 ; set axis maxima
              M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
              ; BLTouch - Heaters
              ;M307 H3 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
              M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
              G31 X20 Y0 Z3.3 P25 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
              M557 X50:350 Y50:350 S50 ; define mesh grid
              M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
              M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
              M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
              M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
              M143 H2 S280 ; set temperature limit for heater 2 to 280C
              M307 H2 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
              M106 P1 S1 H1:2 T45 ; set fan 1 value. Thermostatic control is turned on
              M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
              M563 P1 H2 F0 ; define tool 1
              G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
              G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
              • Veti
                Veti last edited by
                @CupaCabra said in BL-Touch don´t trigger by Home Z:
                there is no config for the probe
                add
                M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                • Veti
                  Veti last edited by
                  B4138
                  your thermistors are configured wrong. that is the default and incorrect for your thermistors.
                  • DIY-O-Sphere
                    DIY-O-Sphere @CupaCabra last edited by DIY-O-Sphere
                    @CupaCabra
                    As far as I could see the deploy and retract of bltouch is missing on homeall.g.
                    CupaCabra Veti 2 Replies Last reply Reply Quote 0
                    • CupaCabra
                      Ok, i change the Config.g
                      but the thermistors shows the Temp. right.
                      i use the PT100 Thermistors
                      • Veti
                        Veti last edited by
                        that is in no way reflected in your config.
                        CupaCabra 1 Reply Last reply Reply Quote 0
                        • CupaCabra
                          CupaCabra @DIY-O-Sphere last edited by
                          @DIY-O-Sphere are not in the G30 deploy and the retract command inside.
                          • DIY-O-Sphere
                            DIY-O-Sphere @Veti last edited by
                            This post is deleted!
                            • CupaCabra
                              CupaCabra @Veti last edited by
                              @Veti can you help me ar it´s possible 4 you.
                              So i can change the right Data in the Config.
                              Sry 4 the stupid Help Requests
                              • Veti
                                Veti @DIY-O-Sphere last edited by
                                @DIY-O-Sphere said in BL-Touch don´t trigger by Home Z:
                                Probe P9 does not require that
                                • DIY-O-Sphere
                                  @CupaCabra
                                  And where do you call the G30?
                                  It's not incuded in the homeall.g
                                  Normaly it would look like this:
                                  ; homeall.g
                                  ; generated by RepRapFirmware Configuration Tool on Sat Jul 14 2018 17:15:09 GMT+0200 (Mitteleuropäische Sommerzeit)
                                  G1 H1 X-310 Y-325 F3500 ; move quickly to X or Y endstop and stop there (first pass)
                                  G1 H1 X-310 ; home X axis
                                  G1 H1 Y-325 ; home Y axis
                                  G1 H1 X-310 F360 ; move slowly to X axis endstop once more (second pass)
                                  G1 H1 Y-325 ; then move slowly to Y axis endstop
                                  G1 X128 Y160 F6000 ; go to first bed probe point and home Z
                                  M98 "Pdeployprobe.g" ; deploy mechanical Z probe
                                  ;G1 H2 Z5 F100 ; uncomment this line to lift the nozzle after homing
                                  M98 "Pretractprobe.g" ; retract mechanical Z probe
                                  • Veti
                                    Veti last edited by Veti
                                    PT 100 would be configured like this (change the spi to match the correct terminal)
                                    M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs1
                                    M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2
                                    M308 S2 P"spi.cs3" Y"rtd-max31865" ; configure sensor 2 as thermocouple via CS pin spi.cs3
                                    but if you get output without this, this strongly indicated that you do not have pt100 sensors.
                                    • CupaCabra
                                      @DIY-O-Sphere
                                      ; homeall.g
                                      ; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 20 2019 11:16:59 GMT+0100 (Mitteleuropäische Normalzeit)
                                      G1 H1 X385 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                      G1 H1 X385 ; home X axis
                                      G1 H1 Y355 ; home Y axis
                                      G1 X-5 Y-5 F6000 ; go back a few mm
                                      G1 H1 X385 F360 ; move slowly to X axis endstop once more (second pass)
                                      G1 H1 Y355 ; then move slowly to Y axis endstop
                                      G1 H2 X0 Y0 F6000 ; go to first bed probe point and home Z
                                      ;M280 P0 S10 ; deploy
                                      M98 "deployprobe.g" ; deploy mechanical Z
                                      ;M280 P0 S90 ; retract
                                      M98 "retractprobe.g" ; deploy mechanical Z probe
                                      ;G1 S2 Z5 F100 ; lift Z relative to current position
                                      • DIY-O-Sphere
                                        @Veti said in BL-Touch don´t trigger by Home Z:
                                        As you have much more experience you should take over now...😊
                                        • CupaCabra
                                          @Veti YES 🙂 you are right there are
                                          100K 1% NTC
                                          • DIY-O-Sphere
                                            @CupaCabra
                                            That is not the same code as posted first ....
                                            • CupaCabra
                                              CupaCabra @DIY-O-Sphere last edited by CupaCabra
                                              @CupaCabra
                                              yes, there are the revisedet version with your command´s.
                                              i take your script as idol.
                                              • DIY-O-Sphere
                                                @CupaCabra
                                                as @Veti mentioned you can remove the M98
                                                I have removed them too, as they furthermore where not correctly coded.
                                                • CupaCabra
                                                  CupaCabra last edited by CupaCabra
                                                  Hello, i have clean all my Home Script´s.
                                                  I have test with the Orginal Script´s
                                                  like below
                                                  ; homez.g
                                                  ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 12:51:00 GMT+0100 (Mitteleuropäische Normalzeit)
                                                  G1 H1 Z505 F1800 ; move Z up until the endstop is triggered
                                                  and
                                                  ; homeall.g
                                                  ; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 12:36:58 GMT+0100 (Mitteleuropäische Normalzeit)
                                                  G1 H1 X405 Y405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                                  G1 H1 X405 ; home X axis
                                                  G1 H1 Y405 ; home Y axis
                                                  G1 H1 X405 F360 ; move slowly to X axis endstop once more (second pass)
                                                  G1 H1 Y405 ; then move slowly to Y axis endstop
                                                  G1 H1 Z-505 F360 ; move Z down stopping at the endstop
                                                  G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                                  ;G90
                                                  the Pin don´t come Out i have try homeall und homez
                                                  If i write on the DuePanel or in the WebBrowser
                                                  M401 oder M402 der Pin get Out and In
                                                  the same with M280 P0 S10 or S90
                                                  But if i try G30 Code the Z Move UP but the Pin don´t come Out.
                                                  If ist someone possible to Help me to fix the Prob. please
                                                  Veti Phaedrux 2 Replies Last reply Reply Quote 0
                                                  • Veti
                                                    Veti @CupaCabra last edited by
                                                    your home scripts are for switches and not for probes.
                                                    there is no reason why the bltouch should deploy.
                                                    please go to the configurator and select bltouch and generate new home scripts.
                                                      Phaedrux Moderator @CupaCabra last edited by
                                                      Please post your deployprobe and retractprobe files.
                                                      Does the pin respond when you send M401 and M402?
