    Solved RRF 3.0 upgrade - Fans
    troubleshooting rrf3 fans setup
    • Simonjb
      Simonjb last edited by
      Spent far too much time trying to get my hotend and partcooling fans to work on my DUET 2 so asking here for help.
      My first PWM fan connection does not work (cock up when building my HEVO) so I have to assign the hotend fan to the second connector and the part cooling fan to the third.
      My config.g (from the online config tool) for the fans is -
      M950 F0 C"fan1" Q500 ; create fan 0 on pin fan1 and set its frequency
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan2" ; create fan 1 on pin fan2 and set its frequency
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      In my 2.06 config.g I had -
      M106 P1 S1 I0 F500 H1 T45 C"HotEnd" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 H-1 C"PrintCool" ; suggested by forum
      Running M98 P"config.g" give the following -
      Error: M950: Pin 'fan2' is not free
      Error: M106: Fan number 1 not found
      And the hotend fan then works correctly if I heat up/cool down turning on/off at 45°C
      If I restart the board it fails again and does not spin up.
      The part cooling fan does not respond at all to M106 P1 and give the error "Fan number 1 not found"
      I'm baffled - no doubt it will be a simple error on my part but I can't find it!
      Anet A8 (lots of mods...). Hypercube Evolution with DuetWifi and 5" PanelDue
      • jay_s_uk
        jay_s_uk last edited by
        which version of RRF3 are you running?
        • Simonjb
          as in the title RRF 3.0
          • droftarts
            droftarts administrators @Simonjb last edited by
            @Simonjb In RRF 3.0, some pins are defined by default on Duet 2; these:
            fan0 -> Fan 0
            fan1 -> Fan 1
            fan2 -> Fan 2
            xstop -> X endstop switch, low end, active high
            ystop -> Y endstop switch, low end, active high
            zstop -> Z endstop switch, low end, active high
            zprobe.in+zprobe.mod -> Z probe 0
            So you need to clear the pin assignment first, with:
            M950 F0 C"nil" ; disable fan 0 and free up the associated pin
            M950 F1 C"nil" ; disable fan 1 and free up the associated pin
            M950 F2 C"nil" ; disable fan 2 and free up the associated pin
            Then your definitions should work.
            NOTE that any newer version of RRF3 will have no default pins (it's a change the community voted for!). Any code clearing pin assignments will be redundant, and the code above will be ignored.
            • Simonjb
              Simonjb last edited by Simonjb
              @droftarts I was right - it was simple. Thanks Ian both fans now working as expected.
