    Help: Temp Sensors and Homing Issues
    6.8k
      Phaedrux Moderator @94118
      @94118 said in Help: Temp Sensors and Homing Issues:
      would it be better to just remove the Z movement from X and Y also
      You could since you aren't using a probe or anything that would need to be raised above the bed before movement.
      • 94118undefined
        94118
        Would i be all good to load filament and try a test print
        • 94118undefined
          94118
          Machine movement controls not responsive i click on the fine movement tabs and it does noting machine is in idle
            So the printer will home properly but then you can't use the jog buttons in DWC?
            • 94118undefined
              94118
              Yes that is correct
                Can you send movement commands in the console?
                Do the paneldue move buttons work?
                • 94118undefined
                  94118
                  No i cannot send commands from console or paneldue
                    Please post your current config.g and homing files so I can see what state your machine would be in after homing.
                    • 94118undefined
                      94118
                      config (1).g homex.g homey.g homez.g
                        In homeX you should have a negative move to back off the endstops.
                        G91               ; relative positioning
                        G1 H1 X235 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 H2 X5 F6000    ; go back a few mm
                        G1 H1 X235 F360  ; move slowly to X axis endstop once more (second pass)
                        G90               ; absolute positioning
                        Should be
                        G1 X-5 F6000    ; go back a few mm
                        Your homey has the negative, but you don't need the H2 on the second move.
                        G1 H1 Y215 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                        G1 H2 Y-5 F6000  ; go back a few mm
                        G1 H1 Y215 F360  ; move slowly to Y axis endstop once more (second pass)
                        Should be
                        G1 Y-5 F6000  ; go back a few mm
                        Your homez only has a single homing pass. You may want to add a second slower pass. You're also missing the G90 at the end, which could be your movement problem.
                        G1 H1 Z200 F1800 ; move Z up until the endstop is triggered
                        G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
                        Should be
                        G1 Z-5
                        G1 H1 Z200 F360 ; second pass
                        • 94118undefined
                          94118
                          Got it to home correctly still cannot use jog controls for fine movement
                            What exactly do you mean by that? Can you post a photo of what you're trying to use?
                            • 94118undefined
                              94118
                              https://drive.google.com/open?id=1E9Nnj0lRRrosyiqkRENvNrMgNKRmSi7d
                              https://drive.google.com/open?id=1E9ZpqFKI_MspoPvdRPRjLaykGRvhTB9-
                              I would use the jog controls for filament load and unload as well as jams or clogging
                                The extruder motor won't move unless it's at printing temp.
                                Are the x and y and z jog buttons working?
                                • 94118undefined
                                  94118
                                  they will work only if i press the plus side of the controls then press the negative side
                                    Ok that probably means that your endstop positions and/or your motor directions aren't correct.
                                    Where is the X endstop? Left or right side?
                                    Where is the Y endstop? Front or back?
                                    Perhaps take a look at this guide on commissioning a printer: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                                    • 94118undefined
                                      94118
                                      X is at the Right, y is at the Left rear corner
                                        M574 X1 S1 P"!xstop"
                                        That should be
                                        M574 X2 S1 P"!xstop"
                                        Because your X endstop is at the high end of travel on the right side.
                                        Change that and see if it works better after homing.
                                        • 94118undefined
                                          94118
                                          when i changed it from x1 to x2 motor direction went in opposite direction so i changed it back to x1
                                          • 94118undefined
                                            94118
                                            Should i change my "Z" endstop from x2 to x1 cause current tool postition read (x230, y210, z0) i think it should be 200 or 195
