    Help: Temp Sensors and Homing Issues
    6.8k
    • 94118undefined
      94118
      Failed to load filaments
      Directory 0:/filaments not found
      i was trying to setup a filaments list for PLA, ABS, PetG
        Phaedrux Moderator @94118
        @94118 said in Help: Temp Sensors and Homing Issues:
        when i changed it from x1 to x2 motor direction went in opposite direction so i changed it back to x1
        Leave it as X2, and change the direction of the X motor as well. You have S1, should be S0.
        M569 P0 S0                                     ; physical drive 0 goes forwards
        Should i change my "Z" endstop from x2 to x1 cause current tool postition read (x230, y210, z0) i think it should be 200 or 195
        No, When the nozzle is at the bed, it's at 0. When the bed or nozzle move away from each other, the Z axis increases position.
        Put the SD card in your PC and create the filaments folder manually.
        • 94118undefined
          94118
          the Sd card from the duet 2 wifi board cause i do not have one for the panel
            yes.
            • 94118undefined
              94118
              recommended steps per mm for PetG as that is currently the roll of filament i have on the printer
                Is that a question?
                • 94118undefined
                  94118
                  Yes that is the question!
                    You'll need to calibrate the extruder.
                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                    Do you have a known starting value for the extruder typical for that printer/extruder?
                    • 94118undefined
                      94118
                      Example shows an ender 3 i do not own an ender 3
                      • Danalundefined
                        Danal
                        Calibrating the extruder is the same process on every printer.
                        • 94118undefined
                          94118
                          have calibrated my extruder here are my numbers.
                          1. 311.82
                          2. 336.82
                          3. 306.82
                          4. 339.82
                          5. 281.82
                          they all seem inconsistent to me
                            Well it seems to be bouncing around a central value. Try starting with the average. 314.
                            You may need to do it several more times if your starting value wasn't very close to being correct.
