    Help: Temp Sensors and Homing Issues
    6.9k
    • 94118undefined
      94118
      yes it did connect initially, and yes i did reflash the firmware myself with Bossa i have tried reflashing the firmware may times and have not gotten anywhere
      • T3P3Tonyundefined
        T3P3Tony administrators
        @94118 what error do you get when you flash the firmware?
        www.duet3d.com
        • 94118undefined
          94118
          I was getting no errors when i did this. it now states connecting.
            If it says Connecting, the PanelDue firmware is almost certainly OK.
            • Go to the Setup page on PanelDue, check the baud rate setting there is 57600
            • Connect to the Duet via YAT or DWC and send M575 P1. Check that it also reports 57600 baud.
            • 94118undefined
              94118
              Here is the results:
              console.txt and this after i checked that the board and the panel are on the same baud speed setting. how would i issue a restart or reset of the board and panel.
                Your M575 P1 setting is correct, so it should be able to communicate with the PanelDue assuming that the PanelDue is set to 57600 in the Settings page.
                Next step is to check whether the Duet is receiving data form PanelDue. Connect to the Duiet via YAT and send M111 S1 P3. It should report that debugging enabled for the GCodes module. It will then echo all received GCode commands in the YAT main window. Do you see any messages beginning "aux: M408" ? You should get those as long as the PanelDue is not on the Setup page.
                If you are using the ribbon cable, make sure it is plugged into the CONN_SD socket on the Duet. Not CONN_LCD.
                • 94118undefined
                  94118
                  Here is the result from DWC YAT is not giving me connection options for comm ports. YAT is to difficult
                  console.txt
                    Phaedrux Moderator @94118
                    @94118 said in Help: Temp Sensors and Homing Issues:
                    YAT is to difficult
                    console.txt
                    M111 S1 P3 has enabled debugging messages to steam to the USB port. You will need either YAT or some other USB terminal to view it.
                    • 94118undefined
                      94118
                      having problems with USB terminal emulators they do not see anything beyond comm 1
                        Does the duet show up as a device in device manager?
                        • 94118undefined
                          94118
                          NO it does not
                            But you are able to connect to the duet via the network and DWC?
                              When you connect the Duet via USB does it make the usb device detected sound?
                                Have you followed this part of the getting connected guide?
                                Have you installed the drivers?
                                It also covers YAT.
                                https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s5
                                • 94118undefined
                                  94118
                                  Duet to the network Yes. Duet to USB NO Sound from windows. Unable to install duet drivers cause DM states not compatible with 64bit
                                  • 94118undefined
                                    94118
                                    Request an update for recent message about the paneldue
                                    • 94118undefined
                                      94118
                                      Duet 2 wifi seems to good with USB but not the paneldue
                                        Please see the post from DC42 above. https://forum.duet3d.com/post/134957
                                        You need YAT connected via USB so that we can see if there is communication between the paneldue and the duet.
                                        • 94118undefined
                                          94118
                                          Direct from YAT: with Duet 2 plugged in to USB talking to Paneldue
                                          Debugging enabled for modules: GCodes(3)<LF>Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) LinuxInterface(16)<LF>
                                          NO (aux: M408)
                                          What next
                                            Phaedrux Moderator @dc42
                                            dc42 said in Help: Temp Sensors and Homing Issues:
                                            In your first picture it shows the PanelDue ribbon cable plugged into the wrong port. Are you still connected that way? Have you tried the 4 wire cabling option?
                                            https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
