Delta z height AC Predator
I don't know how yours can be so different unless the original owner messed with the little metal flags on the top of the carriages.
@jay_s_uk
The flags look/feel the same as my other stock machine. I'll need to get to the endstops as that's a huge difference.Just done another re-probe and similar results.
M665 L440.000:440.000:440.000 R224.513 H456.388 B185.0 X-0.646 Y-0.364 Z0.000
M666 X-6.930 Y3.322 Z3.607 A0.00 B0.00 -
I would investigate your X endstop then as its 10mm different to your Y and Z enstops
@jay_s_uk
Yes. Got my finger under all of them and one is maybe a 0.5/1mm higher, not 10. Disassembly required. Never seen an endstop could it be upside down? -
@jay_s_uk
I got the error " Warning: the height map was loaded when the current Z=0 datum was not determined probing. This may result in a height offset." Just wondered if the problem could be anything like the link below?https://forum.duet3d.com/topic/10835/z-0-datum-was-not-determined-probing/3
I can kind of see that having both a Z endstop switch and a Z probe could cause a problem, as the z tower is not the z height.
Mine Firmware is: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04 (2019-11-01b1)Have you got the same firmware version?
I wouldn't worry about the message around the height map just yet.
If you're going to stick with RRF2 for the moment, I would be upgrading to 2.05.1
I'm on the latest RRF3.01 release and I use conditional gcode in my bed file.You need both a Z stop and a Z probe. The Z stop is set at the maximum end to signify its at the top of the tower. The firmware knows that the Z stop is for the Z tower and will treat it accordingly.
@jay_s_uk
Will update the firmware. It was just a thought as X-6.790 and my probe offset of 5.52 gives 1.27mm which would correlate roughly to what I felt with my finger maybe. -
What do you mean your probe offset is 5.52? In your config, your Z probe offset is 17.656
@jay_s_uk
Sorry I meant initial hot end paper touch before using probe. z=0 at this height. -
Updated, checked all endstops/tabs and they all look okay. Similar distances and wiring the same. Just done another probe and config override as below.
M665 L440.000:440.000:440.000 R227.000 H456.747 B185.0 X0.000 Y0.000 Z0.000
M666 X0.000 Y0.000 Z0.000 A0.00 B0.00That can't be right all zeros. I did notice that the first probe was not in the center of the bed - 10ish mm out.
Hi, Sorted at some point the X belt had twisted with the non-toothed side running on the stepper. I didn’t even notice when checking the stepper grub screws. I couldn’t see the belt twist as it’s slightly recessed on the machine, but I noticed when looking closely at the carriage and tabs. Really noticeable when you manually move the carriage up and down. It makes sense now as when I did a HomeDelta quite often, but not all the time, the interface would report not all axis homed and they weren’t. I just thought it was an annoying “feature” that would sometimes happen and I would have to click Home again. The board was turning the stepper the 490mm distance I have in my HomeDelta and not triggering the end stop giving the error. Also when doing probing from high up the results were inconsistent – belt slippage. Down low with slow probes it was okay. After a Home the X and Y values were not zero on the interface and when touching bed the hot end was not centred on the bed. Now to change the belts and somehow fix the bed which got smashed at the edge when the Perspex lid hit it!
M665 L440.000:440.000:440.000 R226.630 H455.788 B185.0 X0.093 Y0.750 Z0.000
M666 X-0.012 Y-0.045 Z0.057 A0.00 B0.00 -
@Gary said in Delta z height AC Predator:
@jay_s_uk
Yeah I did that before. I deleted config override and re-probed, but I've noticed that re-probing overwrites the M665 and M666 values in the override file. Worth another try though. When you said your endstop adjustments were smaller than mine by how much?It will only do that if you have M500 in your bed.g file, or you send M500 manually. I do not advise using M500 in bed.g.
