    Slicing G-Code curves from solid (not mesh) geometry.
    59
    3.7k
    • botundefined
      bot
      I must be clairvoyant or something -- Fusion just dropped the update with FFF toolpath creation. See y'all in a few weeks... I've got some exploring to do.
      *not actually a robot
      • gtj0undefined
        gtj0
        I just pulled it down as well. Looks promising at first glance. Now if I could figure out how to generate gcode instead of a 3mf file...
        botundefined 1 Reply Last reply Reply Quote 1
        • jens55undefined
          jens55
          How are you guys getting this into your fusion install ?
          botundefined 1 Reply Last reply Reply Quote 0
          • botundefined
            bot @gtj0
            @gtj0 lol... I just generated some toolpaths and they certainly do NOT look promising.
            I see no settings for "meshing" or smoothing/tolerance, and the supports are generated based on settings and it seems you can't edit them.
            We shall see how they improve it...
            • botundefined
              bot @jens55
              @jens55 I had to close down fusion, restart it -- then when I restarted it started downloading the update, then when its done you click retsrat fusion 360 (it's in the clock icon at the top right)...
              Then it's in the additive pane of the manufacture workspace.
              • jens55undefined
                jens55
                Tried that initially but it didn't do an upgrade. Trying again ....
                • jens55undefined
                  jens55
                  Ahh, this time it updated ... maybe I wasn't patient enough. Thanks !
                  • jens55undefined
                    jens55
                    I rest my case re my previous opinion about their ability to come up with anything that competes with the current slicers. They have a LONG way to go !
                    • botundefined
                      bot @jens55
                      @jens55 I'm actually very upset right now how right you were. Damn. 😞
                      • gtj0undefined
                        gtj0
                        Have you guys actually generated a gcode file? If so, how?
                        botundefined jens55undefined 2 Replies Last reply Reply Quote 0
                        • botundefined
                          bot @gtj0
                          @gtj0 I did not generate a gcode file. A post-processing script would be required or something..
                          However, you can "simulate" the toolpath and see the preview of the toolpaths... they use the lowest resolution imagineable in generating the toolpaths. Not even close to approximating curves...
                          jens55undefined 1 Reply Last reply Reply Quote 0
                          • jens55undefined
                            jens55 @gtj0
                            @gtj0 said in Slicing G-Code curves from solid (not mesh) geometry.:
                            Tried but wasn't able to ... thought it was just me but glad to hear that it isn't just old age creeping up on me 🙂
                            • jens55undefined
                              jens55 @bot
                              @bot said in Slicing G-Code curves from solid (not mesh) geometry.:
                              Tried to simulate but no dice on that either 😞
                                So they didn't include a post processor capable of outputting gcode to print on the machines they even have profiles for?
                                I was able to slice a model for the Ender3Pro and simulate it, but... what post processor are you supposed to choose? The default gives an .NC files...
                                A .3MF isn't much use?
                                It doesn't seem too bad for a first release. It's definitely very FUSION360 like, if you know what I mean.
                                jens55undefined A Former User? 2 Replies Last reply Reply Quote 0
                                • jens55undefined
                                  jens55 @Phaedrux
                                  @Phaedrux said in Slicing G-Code curves from solid (not mesh) geometry.:
                                  Con-fusion .... 🙂
                                  • schneik80undefined
                                    schneik80 @bot
                                    This post is deleted!
                                      schneik80
                                      Try this. Open the Machine Configs from the additive toolbar.
                                      In the samples find a test machine, and drag it to your local folder so you can modify it.
                                      Next, select the local folder, pick the machine and choose the post (1).
                                      This brings up the post library. Filter to Additive (2).
                                      Then select one of the sample posts to use (3).
                                      Phaedruxundefined 1 Reply Last reply Reply Quote 2
                                      • A Former User?
                                        A Former User @Phaedrux
                                        thats fusions default extension for g-code btw; but weather or not compatible with RRF is another story.
                                        schneik80undefined 1 Reply Last reply Reply Quote 0
                                          schneik80 @A Former User
                                          @bearer Using an additive post will default to .gcode
                                          • botundefined
                                            bot
                                            Ahh, they have a "generic FFF" post process.. Gonna see what the toolpaths look like in s3d preview.
                                            schneik80undefined A Former User? 2 Replies Last reply Reply Quote 0
