    supported code high lighters on forum - add gcode?
    229
    • A Former User
      Having looked at https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet#code I see we can specify which langue highlighting to use, but its not complete according to https://highlightjs.org/static/demo/
      Could it be update to include gcode and accesslog maybe?
      • Danal
        Danal last edited by Danal
        Until this is added, "```json" works fairly well:
        O003 (DIAMOND SQUARE)
        N2 G54 G90 G49 G80
        N3 M6 T1 (1.ENDMILL)
        N4 M3 S1800
        N5 G0 X-.6 Y2.050
        N6 G43  H1  Z.1
        N7 G1 Z-.3 F50.
        N8 G41 D1 Y1.45
        N9 G1 X0 F20.
        N10 G2 J-1.45
        (CUTTER COMP CANCEL)
        N11 G1 Z-.2 F50.
        N12 Y-.990
        N13 G40
        N14 G0 X-.6 Y1.590
        Certainly better than the default:
        N2 G54 G90 G49 G80
        N4 M3 S1800
        N5 G0 X-.6 Y2.050
        N6 G43  H1  Z.1
        N7 G1 Z-.3 F50.
        N8 G41 D1 Y1.45
        N9 G1 X0 F20.
        N10 G2 J-1.45
        N11 G1 Z-.2 F50.
        N12 Y-.990
        N13 G40
        N14 G0 X-.6 Y1.590
        • A Former User
          Suppose making gcode the default would be a added bonus if its doable to add this.
          • droftarts
            droftarts administrators @Guest last edited by
            @bearer I think weโ€™re at the mercy of what the forum software (I forget what it is, momentarily) chooses to support/
            Include. I tend to use the json code highlighter.
            arhi 1 Reply Last reply Reply Quote 0
            • A Former User
              #WishfullThinking then:)
                Oh that's great. I had no idea ````json was a thing. Looks much better. Even if that was the default that would be great.
                • arhi
                  arhi @droftarts last edited by
                  @droftarts said in supported code high lighters on forum - add gcode?:
                  DISCOURSE I think
                  • droftarts
                    droftarts administrators @arhi last edited by
                    @arhi said in supported code high lighters on forum - add gcode?:
                    DISCOURSE I think
                    Nope, I finally remembered... NodeBB.
                      Just doing some googling for nodeBB and code blocks and it looks like it's fairly customizable. So maybe not impossible. Would be up to @T3P3Tony to dig into it though.
                      • A Former User
                        I think someone might have done something? Line numbering seems to be a new thing, or maybe just a side effect of people using various specific language tags as opposed to the default?
                          I just
                          noticed
                          that
                          line numbers are
                          showing up now as well
                          json:
                          M667 S1                                            	; Select CoreXY mode
                          M208 X0 Y0 Z-0.5 S1                                   	; Set axis minima
                          M208 X325 Y273 Z305 S0                             	; Set axis maxima (x has 295 printable reach)
                          M569 P0 S0                                         	; Drive 0 (x) goes backwards
                          M569 P1 S0                                         	; Drive 1 (y) goes backwards
                          M569 P2 S0                                         	; Drive 2 (z) goes backwards
                          M569 P3 S0                                         	; Drive 3 (e) goes backwards
                          default:
                          Html:
                          Js:
                          • droftarts
                            droftarts administrators @Phaedrux last edited by droftarts
                            @Phaedrux
                            This is
                            with
                            โ€˜textโ€™
                            set
                            • A Former User
                              Someone is being sneaky ... I like it! ๐Ÿ‘‡
                              • T3P3Tony
                                T3P3Tony administrators last edited by T3P3Tony
                                Good idea, I have added line numbering but pulling in the custom highlighting for gcode etc is not currently working. Any NodeBB experts out there feel free to DM ๐Ÿ˜
                                Test cases:
                                var s = "JavaScript syntax highlighting";
                                alert(s);
                                s = "Python syntax highlighting"
                                print s
                                G10 X100 ;gcode syntax highlighting (not working)
                                www.duet3d.com
                                • bot
                                  bot last edited by
                                  Line numbering may get confusing
                                  when only snippets of a larger file are copied and pasted.
                                  This isn't line 3, it's actually line 4250!!
                                  *not actually a robot
                                  A Former User 1 Reply Last reply Reply Quote 0
                                  • A Former User
                                    A Former User @bot last edited by
                                    @bot said in supported code high lighters on forum - add gcode?:
                                    I've used ```text since the numbers were introduced as shown by Ian for this very reason. Line numbers will be usefull when referring to posted configs (snippet or not) etc, just not always if referring to source code maybe.
