    RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available
    Beta Firmware
    10
    27
    572
      Duet 3 + SBC users can pick it up from the unstable package feed. Other users can find it at https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC4. Be sure to read the release notes at https://github.com/dc42/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md.
      deckingman Schmart DIY-O-Sphere 3 Replies Last reply Reply Quote 6
      • deckingman
        deckingman @dc42 last edited by
        @dc42 The upgrade notes state
        "The M563 S (tool number adjustment) parameter is no longer supported. This parameter was only needed when using very old versions of RRF with old versions of slic3r."
        I think it would be clearer if the "S" was changed to "S1" because at first glance, it reads as if the "S" parameter is no longer supported at all, whereas the S parameter can still be used to assign names to tools.
        • Schmart
          Schmart @dc42 last edited by
          Thanks @dc42, installed this RC right away on my Duet 2 Maestro to test the fix with respect to M220. With the Gcode unaltered, working perfectly again!
          Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
          arhi 1 Reply Last reply Reply Quote 0
          • arhi
            arhi @Schmart last edited by
            @Schmart said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
            How does 220/221 actually work now? If I want to have 50% faster print I need both movements in XYZ to be faster 50% and E to be faster 50% is it enough to do M220S150 or is is necesary to do M220S150\nM221S150 ? My original understanding was that M220 will affect XYZE and M221 only E so M220S150\nM221S150 will actually increase XYZ by +50% and E by +125% but am never sure 😞
            Schmart 1 Reply Last reply Reply Quote 0
            • chas2706
              chas2706 last edited by
              Waited for so long for this update only to find M291 still not recognised so my Z calibration macro, bed screw adjustment macro, leadscrew levelling macro and many other macro's containing M291 useless!!
              Danal 1 Reply Last reply Reply Quote 0
              • Schmart
                Schmart @arhi last edited by
                Hi @arhi, documentation is not yet fully updated with the added behavior, but M220 essentially scales the print speed, as if you set higher or lower print speeds in your slicer. M220 now does not apply to retract/unretract and move commands in macros anymore.
                M221 scales the extrusion, which is independent of M220. So if you want 50% higher speed and 5% more extrusion, that would be M220 S150 and M221 S105.
                arhi 1 Reply Last reply Reply Quote 1
                • arhi
                  @Schmart so M220 S150 will be underextruding?
                  • Danal
                    Danal @chas2706 last edited by
                    @chas2706 said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
                    Works for me, can you post some examples? The whole macro...
                    Board: Duet 3 MB6HC v0.6 or 1.0 (MB6HC)
                    DSF Version: 1.2.5.0
                    Firmware: RepRapFirmware for Duet 3 MB6HC 3.01-RC4 (2020-03-16b1)
                    Duet Web Control 2.0.7
                      Phaedrux Moderator @arhi last edited by
                      @arhi said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
                      No, it's still going to scale the extruder speed to match the new XY speed since it's still a coordinated move.
                      • wesc
                        wesc last edited by
                        deployprobe.g, retractprobe.g don't get run. I had to change it to deployprobe0.g/retractprobe0.g for it to work. Not sure if this is an intentional change.
                        relevant config:
                        M558 P5 H3 F320 T12000 C"io2.in" ; set Z probe type to switch and the dive height + speeds.
                        This worked with the pre 3.0 release that came with my Duet3 (RepRapFirmware 3.0beta12)
                        CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
                        Phaedrux dc42 2 Replies Last reply Reply Quote 0
                          Phaedrux Moderator @wesc last edited by
                          @wesc Is that a BLTouch or an actual switch that deploys?
                          • wesc
                            wesc last edited by
                            It's a switch that's magnetically picked up for probing, then put back in it's dock.
                            https://www.youtube.com/watch?v=Wcs6tyqpClA
                              dc42 administrators @wesc last edited by
                              @wesc said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
                              Are you sure that you are running DSF 1.2.5?
                              wesc 1 Reply Last reply Reply Quote 0
                                dc42 administrators @deckingman last edited by
                                @deckingman said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
                                Thanks, I have changed the wording.
                                • arhi
                                  arhi @Phaedrux last edited by arhi
                                  @Phaedrux said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
                                  So M220 will scale both XY and E, and M221 will only scale E so as I asked before M220S150\nM221S150 will get XY to 150% and E to 225% ? or M221 in this case won't do anything?
                                  @Phaedrux I expected this to be a single sentence answer came to be few posts, maybe better to split it from this thread and create separate one to keep this one clean from this offtopic
                                  • chas2706
                                    @Danal said in RepRapFirmware 3.01-RC4 and DSF 1.2.5 now available:
                                    Sort of works for me sometimes. Think it is due to the fact that the bug where you have to enter gcode twice in the DWC console before it works is still present!
                                    Also M291 P"Jog the Z axis until the nozzle grips a peice of paper and click OK" R"Move Z" Z1 S2 still reports error "code not supported".
                                    So, I'm still having to do everything manually!
                                    • Danal
                                      S1 Z1 works (shows jog buttons and "close"). S2 and S3 are not working, looks like a bug, or a "not there yet" in R3. And... since none of the "blocking" ones work, you are correct, this doesn't help you at the moment.
                                      @dc42, is M291 S2 (and S3) not working a bug, or a "not there yet"?
                                      • wesc
                                        wesc @dc42 last edited by
                                        1.2.4. 1.25 did make deploy/retractprobe.g work.
                                        Figuring out how to get DSF 1.2.5 wasn't pleasant. To repost and save others lots of grepping the forums and internet:
                                        Do this to get the bleeding edge DSF:
                                        wget -q https://pkg.duet3d.com/duet3d-unstable.list
                                        sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                                        sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                                        then apt-get update/upgrade
                                        A Former User 1 Reply Last reply Reply Quote 0
                                        • A Former User
                                          A Former User @wesc last edited by
                                          or it can be shortened to
                                          echo "deb https://pkg.duet3d.com/ unstable armv7" | sudo tee /etc/apt/sources.list.d/duet3d-unstable.list
                                          tbh its not a unreasonable threshold to get non-release versions, there are bigger questions in that regards.
                                            The speed factor will only adjust the E values to maintain the amount that the slicer requested. It has to now that XY moves are faster.
                                            The extrusion factor will increase the E amount the slicer requested but not change the xy speed.
                                            Same as before.
                                            The main difference now is that the speed factor change won't apply to travel moves.
                                            • chas2706
                                              Running Duet3 with SBC and having problems.
                                              In my bed.g I have this:
                                              ; If the printer hasn't been homed, home it
                                              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
                                              G28
                                              while true
                                              if iterations = 5
                                              abort "Too many auto calibration attempts"
                                              G30 P0 X5 Y160 Z-99999 ; probe near first leadscrew
                                              if result != 0
                                              continue
                                              G30 P1 X300 Y160 Z-99999 S2 ; probe near last leadscrew and calibrate
                                              echo result
                                              if result != 0
                                              continue
                                              if move.calibrationDeviation.deviation <= 0.03
                                              break
                                              echo "Repeating calibration, Deviation is " ^ move.calibrationDeviation.deviation ^ "mm"
                                              echo "Auto calibration successful. Deviation = " ^ move.calibrationDeviation.deviation ^ "mm"
                                              G28 Z ; re-home z axis in case it has shifted
                                              Firstly, the code for check homing does not work. The printer just homes anyway.
                                              Leadscrew levelling then takes place and the deviations reported back but there's no further indication of what happens next. There is no reporting from the echo commands whatsoever.
                                              Anyone help please.
                                              • Danal
                                                Danal last edited by
                                                I don't see in any release notes where conditional Gcode is (yet) available on SBC? Did I miss something?
                                                  dc42 administrators @Danal last edited by
                                                  Not implemented in DSF yet. There may be progress on that by this time next week.
                                                  • Danal
                                                    @dc42 fantastic to hear that!
                                                    @chas2706 That's why none of your conditional stuff is working. Wait a little bit...
                                                    • chas2706
                                                      @Danal @dc42
                                                      That will explain it then lol.
                                                      Fantastic news cant wait.
