    RepRapFirmware 3.01-RC5 available
    Beta Firmware
    12
    37
    1.9k
      Get it from https://github.com/dc42/RepRapFirmware/releases/tag/3.01-RC5. This release features support for multiple Z probes, object cancellation, and bug fixes.
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 3
      • DIY-O-Sphereundefined
        DIY-O-Sphere @dc42
        Unfortunately the issue for macros called over LCD menu still exists.
        https://forum.duet3d.com/topic/13701/rrf3-error-push-stack-overflow-on-maestro
        (UTC+1)
          I'm sorry I forgot about this. I've put a patched verson of 3.01-RC5 for the Maestro at https://www.dropbox.com/s/f4wj6im1nc6curf/DuetMaestroFirmware.bin?dl=0.
          DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
            DIY-O-Sphere @dc42
            Great job. Works like expected. 👍
            (UTC+1)
            • SIamundefined
              SIam
              Is it possible that there is a problem with the print time calculation ?
              The real printing time was 2h and 2min but the log says it was 9h and 11min ?!?
              28.3.2020, 21:51:24: M32 "0:/gcodes/covid19_headband_rc3(6).gcode": File 0:/gcodes/covid19_headband_rc3(6).gcode selected for printing
              28.3.2020, 21:51:46: : Leadscrew adjustments made: -0.112 -0.095 -0.111, points used 3, (mean, deviation) before (-0.106, 0.007) after (-0.000, 0.000)
              Auto kalibrierung erfolgreich, Abweichung von:  0.007mm
              Happy Printing
              28.3.2020, 23:53:34: : Finished printing file 0:/gcodes/covid19_headband_rc3(6).gcode, print time was 9h 11m
              Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
              Duet WiFi 1.02 or later + DueX5
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
              Duet WiFi Server: 1.26
              Duet Web Control 3.4.0beta4 (2021-09-27)
                @SIam said in RepRapFirmware 3.01-RC5 available:
                I think I've seen this happen once too. Let me know if it happens again.
                SIamundefined 1 Reply Last reply Reply Quote 0
                  I've just added version 3.01-RC5 firmware binaries for Duet 3 tool boards and expansion board to this release.
                  • SIamundefined
                    SIam @dc42
                    i have printet now the same thing (a little bit faster) and have this result
                    29.3.2020, 12:09:45: Datei covid19_headband_rc3(6).gcode erfolgreich nach 13s hochgeladen
                    29.3.2020, 12:09:46: M32 "0:/gcodes/covid19_headband_rc3(6).gcode": File 0:/gcodes/covid19_headband_rc3(6).gcode selected for printing
                    29.3.2020, 12:20:46: : Leadscrew adjustments made: -0.076 -0.079 -0.066, points used 3, (mean, deviation) before (-0.073, 0.005) after (-0.000, 0.000)
                    Auto kalibrierung erfolgreich, Abweichung von:  0.005mm
                    Happy Printing
                    29.3.2020, 13:54:23: : Finished printing file 0:/gcodes/covid19_headband_rc3(6).gcode, print time was 22h 12m
                    This print is ca. 13 hours later as the first one (the printer was not switched off), if i calculate the first print time response from duet 9h 11m + 13 hours then the result is 22h 11 so i think the start time of a print will not set the printing time to zero.
                      I confirm the problem with incorrect print time. It will report the time since the Duet was last powered up or reset.
                      • TCundefined
                        TC
                        I am not sure if this is a new issue but can you checck the multiplication operator. It seems not to work at all
                          dc42 administrators @TC
                          @TC said in RepRapFirmware 3.01-RC5 available:
                          It works if you enclose the expression in { } but not otherwise. That's because * normally introduces an end-of-line checksum.
                          • TCundefined
                            TC
                            Ah ok. Maybe that is also something that could be mentioned in the documentation 😉
                            • Dr_Ju_Juundefined
                              Dr_Ju_Ju
                              Has anything changed in the heating routines ? as since I've updated to RC5 my hot-end heater keeps throwing this error:
                              "Error: Heating fault on heater 1, temperature rising much more slowly than the expected 1.7°C/sec"
                              which I've never had on the previous RC's & RRF2x. nothing has changed on the hardware side & I've even power cycled, in case it was just an anomaly....
                              M115
                              FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01-RC5 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-03-27b3
                              M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC5 running on Duet Ethernet 1.02 or later
                              Board ID: 08DGM-95BNL-MGPSJ-6J1F2-3SD6L-9JZHX
                              Used output buffers: 1 of 24 (10 max)
                              Static ram: 28052
                              Dynamic ram: 93204 of which 44 recycled
                              Exception stack ram used: 256
                              Never used ram: 9516
                              Tasks: NETWORK(ready,748) HEAT(blocked,1244) MAIN(running,1844) IDLE(ready,76)
                              Owned mutexes:
                              Last reset 00:00:55 ago, cause: software
                              Last software reset at 2020-03-31 11:27, reason: User, spinning module GCodes, available RAM 9516 bytes (slot 2)
                              Error status: 0
                              Free file entries: 10
                              MCU temperature: min 29.9, current 31.2, max 31.6
                              Supply voltage: min 24.2, current 24.4, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                              Cache data hit count 108426845
                              Slowest loop: 6.93ms; fastest: 0.11ms
                              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                              === MainDDARing ===
                              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                              === AuxDDARing ===
                              Heater 0 is on, I-accum = 0.0
                              Heater 1 is on, I-accum = 0.0
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Slowest loop: 10.03ms; fastest: 0.02ms
                              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                              HTTP sessions: 2 of 8
                              Interface state active, link 100Mbps full duplex
                              Julian,
                              Old goat, learning new things….
                                No, nothing has changed since the previous 3.01 RCs. Is the hot end heating up at all?
                                • Dr_Ju_Juundefined
                                  Dr_Ju_Ju
                                  Yes, its heating that's why I was surprised....but fyi, I've just run an M303\M500 sequence and that at least lets me get to the working temp of 235 for my Petg...
                                  Julian,
                                  • jbarrosundefined
                                    jbarros
                                    I'm having the same issue on 3.01-RC5:
                                    30/03/2020, 23:50:03 Cancelled printing file 0:/gcodes/20mm_calibration_cube.gcode, print time was 0h 36m
                                    Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:35 Printing paused at X34.9 Y44.1 Z8.1
                                    30/03/2020, 23:48:35 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:32 Error: Temperature reading fault on heater 1: short-circuit in sensorResume state saved
                                    30/03/2020, 23:48:31 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:27 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:23 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:18 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:15 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    30/03/2020, 23:48:11 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                                    I'm using a PT100 with an official Duet PT100 temperature sensor board
                                    My sensors config:
                                    M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                    I happened the 3 times I tried to print.
                                    Since I just finished building this printer I was afraid I had some cable, plug, sensor, board issue but was unable to reproduce any errors by flexing the cables.
                                    Edit: the temperature reading I got was 2000, the same I get on open circuit
                                    tobias_munichundefined 1 Reply Last reply Reply Quote 0
                                    • tobias_munichundefined
                                      tobias_munich @jbarros
                                      @jbarros have you tuned your heaters?
                                      https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                      Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                                      Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                                      Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                                      jbarrosundefined 1 Reply Last reply Reply Quote 0
                                      • jbarrosundefined
                                        jbarros @tobias_munich
                                        @tobias_munich
                                        indeed I have:
                                        ; config-override.g file generated in response to M500 at 2020-03-30 01:58
                                        ; Heater model parameters
                                        M307 H0 A154.3 C287.0 D3.0 S1.00 V24.3 B0
                                        M307 H1 A467.5 C123.2 D5.5 S1.00 V24.2 B0
                                          I think either you have a genuine a short circuit, or you have very severe interference on the PT100 leads. Please post a photo of the top of your daughter board so that I can see whether it is the latest version with extra filter capacitors.
                                          • jbarrosundefined
                                            jbarros @dc42
                                            Mine is v0.4
                                            I have 2 AWG24 UTP cables running to my hotend
                                            The cable with the PT100 wires also serves 2 fans. Does that fit your "severe interference" suspicion?
