    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    23.3k
    • Danalundefined
      Danal
      Sort of.
      You can
      • sudo apt-get install samba
      • sudo smbpasswd -a pi
      • sudo nano /etc/samba/smb.conf # and change 'read only = yes' to no. It is fairly far down in the file.
      Then, on your windows machine,use a UNC like '\192.168.7.101\pi' in windows explorer, or an editor, or whatever. This is not a pure SAMBA "net share" in that there is no drive mapping. In my opinion, it actually works better...
      • Danalundefined
        Danal
        Either suggested technique will work fine.
        • luckyflyerundefined
          luckyflyer
          Ok, success finally, installed winscp, xfered the jpg's and videos to the pc, pictures look good and video's play to. There will be dancing in the streets I tell ya, thanks you guys.
            luckyflyer
            There was a post somewhere in this thread where someone made a macro to control Duetlapse, How would that be done, the start script is the macro?
            Edit, wasn't a macro was a desktop entry.
            arhiundefined 1 Reply Last reply Reply Quote 0
            • arhiundefined
              arhi @luckyflyer
              @luckyflyer said in DuetLapse available for Alpha testing:
              I run duetlapse like this
              create file go.sh
              #!/bin/sh
              while [ /bin/true ]
              do
                python3 DuetLapse.py -duet ender5.local.lan \
                                     -camera usb -detect layer \
                                     -pause no -two yes \
                                     -first /dev/video0 -second /dev/video2 \
                                      camparms -parms -r1280x960
              done
              make it executable
              chmod a+x go.sh
              start it (or doubleclick on it from X)
              ./go.sh
                jay_s_uk @arhi
                @arhi
                Now all we need is to be able to call that from within a print file...
                • arhiundefined
                  arhi @jay_s_uk
                  @jay_s_uk said in DuetLapse available for Alpha testing:
                  well this script runs duetlapse over and over again so you need to start it once and forget, you could call it from rc.local so it starts when the rpi boots up and it will run till you shut it down
                  • agent0810undefined
                    agent0810
                    Hey guys, have DuetLapse running and its communicating with my Duet 2 wifi board. When it sees a layer change it pauses the print, takes the pic and then does not start the print again. Is there a setting im missing?
                    Here is some info of what im doing, at the bottom i am manually restrarting the print from my web interface.
                    ./DuetLapse.py -duet 10.1.2.xxx -camera pi -pause yes -movehead 200 200 -detect layer
                    it stops, moves the head to the corner then never starts again. any advice would be great, thank you!
                    this is a duet 2 wifi board on a Ender 5 pro using cura slicer.
                    Note "-pause yes" means this script will pause the printer when the -detect or
                    -seconds flags trigger.
                    If instead, it is desired that this script detect pauses that are already in
                    in the gcode, specify:
                    "-detect pause"
                    Attempting to connect to printer at 10.1.2.xxx
                    Connected to a Duet V2 printer at http://10.1.2.xxx
                    Options in force for this run:
                    camera = pi
                    printer = 10.1.2.xxx
                    seconds = 0
                    detect = layer
                    pause = yes
                    camparms =
                    vidparms =
                    movehead = 200.00 200.00
                    dontwait = False
                    Waiting for print to start on printer 10.1.2.xxx
                    Will take pictures when printing starts,
                    and make video when printing ends.
                    Or, press Ctrl+C one time to move directly to conversion step.
                    Print start sensed.
                    End of print will be sensed, and frames will be converted into video.
                    Requesting pause via M25
                    Moving print head to X200.00 Y200.00
                    Capturing frame 0 at X0.00 Y0.00 Z6.12 Layer 6
                    Capturing frame 1 at X103.69 Y86.69 Z1.32 Layer 7
                    Capturing frame 2 at X79.03 Y101.37 Z1.52 Layer 8
                    Capturing frame 3 at X67.97 Y145.27 Z1.72 Layer 9
                    • A Former User?
                      A Former User @Danal
                      @Danal Hi, I've installed everything needed in my printer and Raspberry PI but when I start the script, as you can see, the Raspy doesn't recognize the (correct) printer IP :
                      Could you help me to solve the problem?
                      Thanks!
                        jay_s_uk @A Former User
                        @the_dragonlord @Danal passed away a few months back.
                        I'm not sure if anyone has taken this script any further
                        • A Former User?
                          A Former User @jay_s_uk
                          oh my....I didn't know...so sorry for that...
                          • A Former User?
                            This post is deleted!
                            • JohnOCFIIundefined
                              JohnOCFII
                              As mentioned in the GitHub ticket - I wanted to see if you could ping the printer from the Pi, just to rule out low-level IP connectivity issues.
                              I just installed the DuetLapse about a month ago, so it is pretty fresh in my brain.
                              John
                              A Former User? 2 Replies Last reply Reply Quote 0
                              • A Former User?
                                A Former User @JohnOCFII
                                @JohnOCFII said in DuetLapse available for Alpha testing:
                                John
                                Reading the very first messages of this thread I've seen a message of a user who suffered the exactly problem I've experienced... Both of us has setted the password and this seems to be the problem. Tomorrow I'll try to take off the password from config.g and see if it works.... I'll let you know
                                • A Former User?
                                  John
                                  Good morning, I've taken off the password and now the scripts comunicate with the printer but it doesn't work for this error:
                                    JohnOCFII
                                    What the of camera do you have? Looks like a Raspberry Pi camera? I'll need to look at that tomorrow. I have a USB-type camera.
                                    A Former User? stuartofmtundefined 2 Replies Last reply Reply Quote 0
                                    • A Former User?
                                      Yes. i have a PI camera
                                      JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
                                        JohnOCFII @A Former User
                                        @the_dragonlord What happens if you try to execute the raspistill -o cam.jpg command? Do you get an image?
                                        (I'm just guessing at a first troubleshooting step from here: https://www.raspberrypi.org/documentation/usage/camera/raspicam/raspistill.md )
                                        This stack exchange issue mentions some other possibilities -- some were fixed by updating the firmware on the Pi with sudo apt-get update and sudo apt-get upgrade
                                        https://raspberrypi.stackexchange.com/questions/13764/what-causes-enospc-error-when-using-the-raspberry-pi-camera-module
                                        • stuartofmtundefined
                                          stuartofmt
                                          EDIT: These changes can be downloaded from here:
                                          https://github.com/stuartofmt/DuetLapse
                                          First of all - thanks for this very useful program!!
                                          I am using a Duet Wifi2 and have a Pi 3 near it that I use to provide a video stream from here:
                                          http://picamera.readthedocs.io/en/latest/recipes2.html#web-streaming
                                          I also run the Dueui app for local control. I am now adding DuetLapse.
                                          One thing I noticed with the standard pi camera is that only one process can be connected to it at a time (otherwise you will get ENOSPC errors) - so the standard DuetLapse approach gave errors.
                                          I added this code (and the appropriate checks for the new camera type etc.)
                                              if ('ffmpeg' in camera):
                                                  if (camparms == ''):
                                                      cmd = 'ffmpeg -y -i ' +weburl+ ' -vframes 1 ' +fn
                                                  else:
                                                      cmd = 'ffmpeg '+camparms+' '+weburl+ ' -vframes 1 ' +fn
                                          I use it like this (where the weburl is the pi camera stream. That way there is only one process connected to the camera but the output is serving two uses.
                                          /usr/bin/python3 ./DuetLapse.py -duet <duet ip> -camera ffmpeg -weburl http://<camera ip:port>/stream.mjpg -detect layer &
                                          Hope this helps others.
                                          P.S. I also added this to the top of DuetLapse.py to prevent multiple instances from running due to my own fat fingering 🙂
                                          # Added to stop multiple instances running
                                          import psutil
                                          procs = [p for p in psutil.process_iter() if 'python3' in p.name() and __file__ in p.cmdline()]
                                          if len(procs) > 1:
                                              print('Process is already running...')
                                              sys.exit(1)
                                            stuartofmt @JohnOCFII
                                            @JohnOCFII
                                            See my post above
                                            If you have two applications both trying to connect to the same Pi camera you will get these ENOSPC errors. This does not mean this is your exact problem - but is a good place to start.
