    DuetLapse available for Alpha testing
    Third-party software
    26
    239
    22.7k
    • Danalundefined
      Danal @UnderDoneSushi
      @UnderDoneSushi said in DuetLapse available for Alpha testing:
      Would it be possible to use an old iphone as the camera?
      Yes, if it runs software that will allow a still image to be retrieved via a know URL.
      • gtj0undefined
        gtj0
        HA! Just discovered another reason to use a config file if it exists... To turn off things like auto-focus. 🙂
        Danalundefined 1 Reply Last reply Reply Quote 0
        • Danalundefined
          Danal @gtj0
          @gtj0 said in DuetLapse available for Alpha testing:
          Excellent point.
          • tekkydaveundefined
            tekkydave
            Found a solution to an issue I was having using DuetLapse with MotionEye.
            I have a raspicam which is connected to a Pi3B running Motioneye.
            MotionEye will allow a single image to retrieved at a URL similar to:
            http://192.168.1.106:8765/picture/1/current/?_username=admin&_signature=b75e2c8efb0c0694a7a4ac1f48037f90566fbead
            Using this URL with DuetLapse gives this error every time it tries to get an image
            Capturing frame     0 at X65.74 Y47.41 Z0.30
            http://192.168.1.106:8765/picture/1/current/?_username=admin:
            2020-04-07 15:10:57 ERROR 403: Forbidden.
            So I amended the following line in the onePhoto() function in DuetLapse.py
            cmd = 'wget --auth-no-challenge -nv -O '+fn+' '+weburl
            to
            cmd = 'wget --auth-no-challenge -nv -O '+fn+' "'+weburl+'"'
            to put quotes around the url. This seems to fix the problem 🙂
            ~ tekkydave ~
            D-Bot: 300x300mm | Duet WiFi + Duex2 | 3 independent z motors | X,Y & Z linear rails | E3D Titan Aero + V6 | Precision Piezo z-probe
            FreeCAD, PrusaSlicer
            • Danalundefined
              Danal
              THANK YOU
              I will update
                tekkydave
                Another tip if you want to play around with DuetLapse without having to set a print going.
                Temporarily change
                        if ('processing' in status):
                to
                #if ('processing' in status):
                if ('M' in status):   # detect simulating instead of processing
                This will make DuetLapse think the Duet is printing when it is simulating. Remember to change it back later 😉
                Maybe a -dry-run option can be added to do this in future?
                ~ tekkydave ~
                • Danalundefined
                  Danal
                  I've just been starting a print, and then pause/canceling it.
                  Of course, it can do whatever we all agree to... and can code... and dry run is dead simple. I would note that it really only applies to -seconds. A dry run with any kind of -detect is never going to detect anything.
                  tekkydaveundefined 1 Reply Last reply Reply Quote 0
                    tekkydave @Danal
                    @Danal said in DuetLapse available for Alpha testing:
                    It detects layer changes when running a simulation but, as you say, since nothing is physically moving the video is going to be a bit boring. Useful if you are testing options or trying simple code changes though. I know squat about python so I need all the help I can get. I do find your code very easy to follow though 🙂
                    ~ tekkydave ~
                    • Danalundefined
                      Danal @tekkydave
                      @tekkydave said in DuetLapse available for Alpha testing:
                      Thank you. I try to balance being "python-esq" with being readable. For me if nought else.
                      How about having the "detect printing" detect BOTH processing and simulation? Since we control if the script is running, I see very little downside to this.
                        tekkydave @Danal
                        That would be the simplest solution I think.
                        ~ tekkydave ~
                        • chas2706undefined
                          chas2706
                          Keep the ideas coming!
                          In my customised build of Raspbian with duetpi I created a timelapse.desktop entry so that I can access your program from my start menu.
                          By default I set it to take a picture upon Z movement.
                          So now, when I start a print and the printer is ready all I have to do is click on the program entry in the start menu.
                          Thank you again danal for giving us this great program.
                          • kingfisherundefined
                            kingfisher
                            I've set it up and it works 🙂
                            I did get an error on a small print doing a quick test though
                            The error was "requests.exceptions.ConnectionError:
                            ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))"
                            My guess (Although I'm not a Python expert) is that the pi couldn't keep up saving the images as the layers were only taking 20sec (And its an old V2 pi)
                            kingfisherundefined 1 Reply Last reply Reply Quote 0
                              kingfisher @kingfisher
                              @kingfisher
                              I actually think it might be my Duet wifi board causing an error. I've also got a duet maestro and running the same python settings on the maestro IP address hasn't resulted in the "('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))" error
                              • Danalundefined
                                Danal
                                Updates based on feedback:
                                • Added -dontwait flag. This causes the script to not wait for a print to start; it captures images immediately. Of course, it will only capture things that happen... Example: If told only to capture on layer changes, well, that won't happen prior to a print...
                                • Added 'camparms -parms' subsection to command line flags. Anything in that subsection is passed to the camera command (whichever for the appropriate camera type, fswebcam, raspistill, or wget)
                                • Removed pallet from fswebcam (USB attached cameras, despite its name). It will automatically attempt to find the best, or you can specify one, example:
                                  ./DuetLapse.py -duet 192.168.7.101 -dontwait -seconds 3 camparms -parms -p YUYV
                                • Removed -q from fswebcam. Default is 35. You can override, same as above.
                                • Slightly changed the loop timer, to beat on the printer a little less often.
                                *** IMPORTANT *** Found a bug in DuetWebAPI and fixed it, you must download this as well. Therefore, pull these two things into the same directory. One way to do this would be:
                                wget https://raw.githubusercontent.com/DanalEstes/DuetLapse/master/DuetLapse.py
                                chmod 744 DuetLapse.py
                                wget https://raw.githubusercontent.com/DanalEstes/DuetWebAPI/master/DuetWebAPI.py
                                • Danalundefined
                                  Danal
                                  Also, added quotes around the wget URL.
                                  • Danalundefined
                                    Danal
                                    Still thinking about overlay of Z, print time, etc.
                                      tekkydave @Danal
                                      ~ tekkydave ~
                                        tekkydave
                                        @Danal what ide / dev tools do you use for python development. I'm using Eclipse for c/c++ and Netbeans for Java. Is there a tool for python that will allow local (Ubuntu) testing and remote deployment to the pi?
                                        ~ tekkydave ~
                                        • Danalundefined
                                          Danal
                                          For Python, I edit with Sublime on a PC. It could be any editor or IDE that you like that has syntax highlighting or whatever. I interface to the Pi by doing this on the Pi:
                                          # If you want to be able to edit files on the Pi from windows, via a netshare (not a mapped drive):
                                          sudo apt-get install samba
                                          sudo smbpasswd -a pi
                                          sudo nano /etc/samba/smb.conf   # and change 'read only = yes' to no.
                                          # Then use a UNC like '\\192.168.7.101\pi' in a file open in your favorite editor.
                                          # Quite often, you may have to start with just the "\\192.168.7.101" and no subdirectory to get
                                          # it to prompt you for userid and password.  Use 'pi' and the password you set above.
                                          # You may have to try and retry several times to get connected.  It's worth it.
                                          # BE SURE that your editor HONORS UNIX LINE ENDS and that you turn them on in any new files.
                                          # For windows users, I suggest notepad++ or atom or Sublime Text (that last one costs money. Worth every penny)
                                          The big key is the UNC on Windows. \192.168.7.101\pi This is NOT a drive share... and doesn't behave like SMB shares behave. In sublime, if I do an "open folder" on that UNC, I can then click into \192.168.7.101\pi\DuetLapse (or whatever) and see all the files.
                                          Note: This WILL cause your editor to hang if it has files/folders open and the Pi goes away. In sublime, I set it to NOT re-open whatever it had at close...
                                          Testing? For python there is no "make" or "build" phase, so I just test directly on the Pi. Either VNC if I need graphics, or Winterm and ssh if not.
                                          You can, in theory, test on your desktop distro, by building enough "context" around the thing you are testing. Directories, etc. However, many of the things that I'm testing (not necessarily the stuff you are seeing for Duet) is so tightly related to interfaces or other structures in Raspbian and/or the actual Pi hardware, it is just easier to test there.
                                          For cross compile, like binaries for ESP32, or the Atmel chips, or similar, I still edit in Sublime, with the PlatformIO plugin. This makes it a cross-platform IDE. I've come to really like PlatformIO (as vs. the more 'Arduino' like environments). It runs a mini-RTOS and is very well documented and very flexible.
                                          If I'm working with stuff developed by others for Atmel, then it is Atmel studio all the way.
                                          That covers pretty much everything that fits a pattern. There are, of course, one-off environments for exceptional cases.
                                            tekkydave @Danal
                                            @Danal thanks - very interesting.
                                            ~ tekkydave ~
