What fuse its for fan02?
  • Hi,
    I noticed that a layer fan was not starting, and I have done some tests to identify the cause:
    I have to say that it is a Delta printer, with a Heatsink fan and two layer fans ... And I have the layer fans connected to the FAN0 and FAN2 sockets, the one of the heatsink being on FAN1.
    The fan settings in config.g is:
    M106 P0 S0 I0 H-1; Layer 01
    M106 P1 S0 I0 H1 T80; Heatskin
    M106 P2 S0 I0 H-1; Layer 02
    1st Test. The first thing I thought was that the fan was not working. What I have done has been to change the connector for the other fan. Result is that the fan has started, that has ruled out that the problem is the fan or the wiring to the Duet board.
    2nd Test. That the fan setup in config.g is not correct, but as you can see from how I have them configured, fan P0 is configured the same as P2.
    3rd Test. I suspect the problem is in the fuse, but I don't know if there is a fuse for that fan only, I have been looking at the diagram on the board and I don't see it clearly.
    Is there a fuse for each fan? Or is it the same fuse for all fans?
    What can be?
  • @peirof Afaik, it is one fuse for all of the fans.
    You might want to check the jumper just below the fan connectors.
    I have tried to find more info on the jumpers, I know on the Duex you can select the voltage output.
    HTH
    Paul
  • @PaulHew
    Past week, fans worked
  • Please post full config.g
    Paul.
  • @PaulHew
    ; generated by RepRapFirmware Configuration Tool v2.0.4 on Mon Sep 16 2019 11:43:14 GMT+0200 (hora de verano de Europa central)
    M550 P"TLM Duet v2.2" ; set printer name
    M665 R157 L397.1073 B125 H495 ; Set delta radius... STOCK EFFECTOR (M665 R157 L397.1073 B125 H491)S
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M572 D0 S0.1 ;Pressure in advance
    M550 P"TLM DUET2.2" ; Set machine name
    M552 S1 ; Enable network
    M587 S"Devolo.Terraza2.4" P"a1b2c3d4" I192.168.1.25 ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S1 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M350 X256 Y256 Z256 E32 I0 ; Configure microstepping without interpolation
    M92 X1280.00 Y1280.00 Z1280.00 E830.00 ; Set steps per mm
    M566 X1000.00 Y1000.00 Z1000.00 E900.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X10980.00 Y10980.00 Z10980.00 E3600.00 ; Set maximum speeds (mm/min)
    M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; Set accelerations (mm/s^2)
    M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I60 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; set minimum Z
    M574 X2 Y2 Z2 S1 ; set active high endstops
    M558 P8 I1 R0.9 F500 Z1 ; set Z probe type to effector and the dive height + speeds---- antes M558 P8 I1 R0.9 F150 Z1
    G31 P500 X0 Y0 Z-0.1 ; set Z probe trigger value, offset and trigger height antes---- antes G31 P500 X0 Y0 Z2.5
    M557 R90 S15 ; define mesh grid for (0.4 Nozzle M557 R120 S18) (0.2 Nozzle M557 R70 S10)
    M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
    M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0 M305 P0 T100000 B4138 R4700
    M305 P1 T100000 B4850 R4700 ; Set thermistor + ADC parameters for heater M305 P1 T82202 B4371 R4700
    M106 P0 S0 I0 H-1 ;Capa
    M106 P1 S0 I0 H1 T80 ;Heatskin
    M106 P2 S0 I0 H-1 ;Capa
    M563 P0 D0 H1 F0:2 ; Define tool 0
    G10 P0 S0 R70 ; Set tool 0 operating and standby temperatures
    T0 ; select first tool
  • Moderator
    @peirof I would think this is a MOSFET failure on FAN2, unfortunately.
  • @droftarts how can check it?
  • Moderator
  • @Phaedrux Thanks.... For the moment will connect two fans to the same socket...
