UNSOLVED Release 3.01-RC10
  • guys good evening, I updated to Release 3.01-RC10, but the extruder doesn't work even in manual, do you know anything about it?
  • I had a similar problem when I first upgraded to firmware 3.
    Can you tell me what firmware version you upgraded from?
    Also posting your config.g may help.
  • Moderator
    Did you also update DWC?
  • @Phaedrux
    good morning World
    yes I also updated DWC, if I go to extrude with the command on DWC it does it the first time and then that's enough, and it doesn't tell me if there are problems or not, however I send you the configuration and the log.
    29/4/2020, 11:04:05 M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC10 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-917NK-F23T0-6JTD0-3S06T-TYAJFUsed output buffers: 3 of 24 (10 max)
    Static ram: 28044
    Dynamic ram: 93632 of which 44 recycled
    Exception stack ram used: 256
    Never used ram: 9096
    Tasks: NETWORK(ready,208) HEAT(blocked,1228) MAIN(running,1544) IDLE(ready,80)
    Owned mutexes: WiFi(NETWORK)
    Last reset 00:00:58 ago, cause: power up
    Last software reset at 2020-04-29 00:45, reason: User, spinning module GCodes, available RAM 8128 bytes (slot 1)
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
    Error status: 0
    Free file entries: 10
    MCU temperature: min 27.8, current 32.1, max 32.2
    Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-04-29 11:04:04
    Cache data hit count 104735100
    Slowest loop: 7.35ms; fastest: 0.13ms
    Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
    === MainDDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
    === AuxDDARing ===
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    Telnet is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.91ms; fastest: 0.00ms
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is active
      WiFi firmware version 1.23
      WiFi MAC address 84:0d:8e:b3:b4:8a
      WiFi Vcc 3.40, reset reason Unknown
      WiFi flash size 4194304, free heap 25832
      WiFi IP address 192.168.178.22
      WiFi signal strength -62dBm, reconnections 0, sleep mode modem
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
    M550 P"Lanzet 3d" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes forwards
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P3 S0 ; physical drive 3 goes forwards
    M92 X80.0 Y80.0 Z400.00 E424.00 ; set steps per mm
    M566 X500.00 Y500.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X10000.00 Y10000.00 Z400.00 E1200.00 ; set maximum speeds (mm/min)
    M201 X900.00 Y900.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S240 ; Set idle timeout
    M208 X330 Y330 Z385 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P1 C"zprobe.in" H5 F300 T10000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X-30 Y0 Z2.14 ; set Z probe trigger value, offset and trigger height
    M557 X55:310 Y50:300 S60 ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S90 ; set temperature limit for heater 0 to 90C
    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
    M143 H1 S260 ; set temperature limit for heater 1 to 260C
    M106 P1 S0.5 H1 T45 ; set fan 1 value. Thermostatic control is turned on
    M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
    M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
    T0
  • @Leblond I tried to bring it back to version 3.0 but with the same results, it also gives me z offset problems, even following the procedure available with the macros, the height of the z offset is incorrect, in practice it is too low and the I find the G30 command only in the configuration and not elsewhere
    @Leblond, I've used extrusion from DWC many timis with RRF 3.01-RC10 and DWC 2.1.5. So I think there must be something in the sequence of what you are doing that is different. Please can you do the following:
    • Install 3.01-RC10 and DWC 2.1.5
    • In DWC Settings, check that you really are running those versions.
    • Try to reproduce the problem, taking note of the sequence of commands you used to get to the problem
    When the problem occurs:
    • Check that you have a tool selected
    • Check that the temperature of that tool is at least 160C or that you have cold extrusion enabled
    Report the sequence you used to get to the problem here.
  • hello dc42 Thank you for your intervention
    the update sequence was:
    1. Update of FW 3.01-RC10
    2. DWC update directly from the .zip file
    The nozzle is selected and active: ok
    FW 3.01-RC10 loaded: ok
    DWC 2.1.5 loaded: ok
    The temperature is 220: ok
    I created a macro for ease of use to clean the nozzle:
    G1 X0 Y0
    M104 S220 T0
    M109 S220 T0
    G1 E30 F200
    I bring the temperature to 220, the macro is active, the head moves to the chosen coordinates, but it does not extrude and it is still, I manually try to extrude, but nothing happens and it does not give me any errors whatsoever
    I am attaching photos for viewing:
    Thanks. So the manual extrusion buttons in DWC are not greyed out, but pressing them does nothing. Is that correct?
    Which firmware version were you using before, when extrusion was working?
    Please send the following commands from the console, and check that the E values reported in the responses are expected:
    M92
    M906
    M913
    M563 P0
    Also please confirm that the hot end heatsink fan is running, and that you can push filament through the hot end by hand to make sure that you don't have a filament jam.
  • Moderator
    @Leblond Does the extruder position change? Here:
  • @droftarts guys I will make the checks tonight after work and keep you informed, I realized that the E0 motor is struggling to turn Responding to @droftarts it is at 0.0 but once I try to extrude 10mm the motor vibrates but does not move, but on extruder driver it marks me from 0 to 10mm, tonight i try to clean the nozzle and i will tell you everything
  • @droftarts good morning everyone, after several tests I found out that the nozzle was blocked, what stole me was the engine that did not jump but remained motionless, however I had to replace the nozzle and clean the heat breack, therefore solved, thanks to everyone for the commitment, there is always something to learn here.
  • the cases are two at the origin to the problem of the blocking of the extrusures "correct me if I'm wrong !!", 1: when the trigger is wrong, that is too attached to the plate and does not extrude, by force of give and give yes the filament is compact and freezes, 2: filament dirty or low temperature, but the problem encountered by me is strange perhaps it has something to do with it
    the motor voltage? it is set to 800 but, and in any case it should jump, make the usual "tac tac ..." noise which has not happened to me and which has caused a waste of time for me and for you, I was wondering if there was a way via SW to check if an engine actually runs or not, type ammeter?
  • @chrishamm ok thanks, I print it and I care about it
  • Good morning and good May 1st
    Well I have a problem that repeats itself every time I homing, then I thought the last problem had been the fault of the nozzle blocked by the filament, in part yes, it blocked because the extruder motor stops, now I understood the reason, the tests I did are all without filament in order not to damage the nozzle, I describe what I did:
    1: I set the temperature to 180 in order to have the extrusion and retraction buttons active the drive buttons work very well and the motor responds
    2: if I homing all the axes and retry the procedure n.1 the extruder no longer works
    3: I did the single homing of the axes
    4: homing x axis and retrying the extruder and it works
    5: homing y axis and retrying the extruder and it works
    6: z axis homing and try again the extruder does not work
    I tried to load the fw one by one starting from 3.0 until the last beta and the problem persists,
    7: I removed the sd and reformatted and loaded the fw but nothing happens
    Any suggestions on this?
    for @ dc42
    m92
    Steps / mm: X: 80.000, Y: 80.000, Z: 400.000, E: 424.000
    M906
    Motor current (mA) - X: 800, Y: 800, Z: 800, E: 800, idle factor 30%
    M913
    Motor current% of normal - X: 100, Y: 100, Z: 100, E: 0
    m563 p0
    Tool 0 - drives: 0; heaters (active / standby temps): 1 (180.0 / 0.0); xmap: X; ymap: Y; fans: 0; status: selected
  • to restart the engine I have to reset with the command M999
    @Leblond said in Release 3.01-RC10:
    Please post your homez.g file.
  • @dc42
    ; homez.g
    ; called to home the Z axis
    G91 ; relative positioning
    G90 ; absolute positioning
    G1 X60 Y50 F6000 ; go to first probe point
    ;G91 ; relative positioning
    ;G1 Z10 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • now I have mounted the fw 2.05 to see if even with this it does the same problem
    Is the tool still selected when you have this problem? Send T by itself to report the current tool number.
  • @dc42 ok I reassemble the FW and then I tell you
  • @dc42 made reloaded FW 3.01-RC10
    yes the tool is always active
    1/5/2020, 14:51:33 T
    Tool 0 is selected
  • @dc42 I compress all the sd and send it to you?
  • it still does not work
