    Release 3.01-RC10
    2.6k
      Is the tool still selected when you have this problem? Send T by itself to report the current tool number.
      Leblondundefined 3 Replies Last reply Reply Quote 0
      • Leblondundefined
        Leblond @dc42
        @dc42 ok I reassemble the FW and then I tell you
        • Leblondundefined
          Leblond @dc42
          @dc42 made reloaded FW 3.01-RC10
          yes the tool is always active
          1/5/2020, 14:51:33 T
          Tool 0 is selected
          • Leblondundefined
            Leblond @dc42
            @dc42 I compress all the sd and send it to you?
            • Leblondundefined
              Leblond
              it still does not work
              • Leblondundefined
                Leblond
                the engine practically vibrates as if it were stalled
                • Leblondundefined
                  Leblond
                  @dc42 I confirm that with version 3 of the fw I have this problem, but with the version of FW 2.05 everything works great, so I will continue to use FW 2.05, until you can understand where the problem lies
                  • Leblondundefined
                    Leblond
                    Hi everyone, have you discovered anything about my problem?
                    • Leblondundefined
                      Leblond
                      good morning guys
                      I have found that by sending the axes home manually one at a time starting with x, y and z, the extruder works
                      • Leblondundefined
                        Leblond
                        but as soon as a g28 is made it no longer works and the extruder stalls
                        sebkritikelundefined 1 Reply Last reply Reply Quote 0
                        • Leblondundefined
                          Leblond
                          I also installed Release 3.01-RC12 ma niet
                          • Leblondundefined
                            Leblond
                            for @dc42 no idea?
                            • Leblondundefined
                              Leblond
                              Guys forgive me if I insist, but it seems strange to me that only I have a problem with a brand new card and you can't find a solution
                              • sebkritikelundefined
                                sebkritikel @Leblond
                                @Leblond said in Release 3.01-RC10:
                                When you send "G28" or "G28 Z" ?
                                Can you post homeall.g?
                                good morning guys
                                G28 X
                                Extruder Works
                                G28 Y
                                Extruder Works
                                G28 Z
                                Extruder Works
                                G28
                                Does not work?
                                • Leblondundefined
                                  Leblond
                                  it is exact only when sending g28 the extruder stalls
                                  • Leblondundefined
                                    Leblond
                                    ; homeall.g
                                    ; called to home all axes
                                    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 22:39:29 GMT+0200 (Ora legale dell’Europa centrale)
                                    G91 ; relative positioning
                                    M913 X50 Y50 ; Riduci la corrente al 50%
                                    G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass)
                                    G1 H1 X-9999 ; home X axis
                                    G1 H1 Y-9999 ; home Y axis
                                    G1 X5 Y5 F2000 ; go back a few mm
                                    G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass)
                                    G1 H1 Y-9999 ; then move slowly to Y axis endstop
                                    G90 ; absolute positioning
                                    G1 X60 Y50 F9000 ; go to first bed probe point and home Z
                                    M913 X100 Y100 :Riporta la corrente al 100%
                                    ;G91 ; relative positioning
                                    ;G1 Z10 F100 ; lift Z relative to current position
                                    ;G90 ; absolute positioning
                                      ; homeall.g
                                      Can you try:
                                      ;homeall.g
                                      ;;;M913 X50 Y50 ; Riduci la corrente al 50%
                                      G1 H1 Y-9999 F360 ; then move slowly to Y axis endstop
                                      ;;;M913 X100 Y100 :Riporta la corrente al 100%
                                      Leblondundefined 2 Replies Last reply Reply Quote 0
                                      • Leblondundefined
                                        Leblond @sebkritikel
                                        @sebkritikel ok now i try
                                        • Leblondundefined
                                          @sebkritikel said in Release 3.01-RC10:
                                          ;homeall.g G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position ;;;M913 X50 Y50 ; Riduci la corrente al 50% G1 H1 X-9999 Y-9999 F4000 ; move quickly to X or Y endstop and stop there (first pass) G1 X5 Y5 F2000 ; go back a few mm G1 H1 X-9999 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-9999 F360 ; then move slowly to Y axis endstop G90 ; absolute positioning G1 X60 Y50 F9000 ; go to first bed probe point and home Z ;;;M913 X100 Y100 :Riporta la corrente al 100% G30 ; home Z by probing the bed
                                          91/5000
                                          wait because it gives me an error "6/5/2020, 18:12:41 G28
                                          Error: G0 / G1: insufficient axes homed "
                                          sebkritikelundefined 2 Replies Last reply Reply Quote 0
                                            This post is deleted!
