CR 10 5s
Greetings all together.
I have a CR 10 5s and i have upgraded it with linear rails on all 3 axis and a Titan extruder with volcano hot end.
It's all wired up and moving. But here is the catch. I also bought new motors from e3d
On the Y axis i have :
NEMA 17.
1.8° Step Angle.
200 Steps Per Revolution.
4V Rated Voltage.
2A Phase.
8.2kg/cm (114oz/in) Holding Torque.
60mm Body.
5mm Output Shaft.
On x :
NEMA 17.
0.9° Step Angle.
400 Steps Per Revolution.
2.8V Rated Voltage.
1.68A Phase.
4.4kg/cm (61oz/in) Holding Torque.
48mm Body.
5mm Output Shaft.
On z 2x :
NEMA 17.
0.9° Step Angle.
2.8V Rated Voltage.
1.68A Phase.
3.5kg/cm (48.6oz/in) Holding Torque.
40mm Body.
25mm Output Shaft (5mm diameter)
Ok, the machine is moving but not as much as i want to. I tried to reconfigure with the reprap configuration but there is something that im doing wrong. Because i click on the 50 mm button and it moves less.
Can somebody check my parameters and tell me what I am doing wrong? Attached you will find my config file
Thanks
[0_1588331232137_config2.zip](Uploading 100%)
@Thunder your config.g did not upload. Use the '</>' from the toolbar or try uploading again.
Regards,
Paul
sorry here is it :
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 01 2020 16:13:33 GMT+0200 (Srednjeevropski poletni čas) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"CR10 5S" ; set printer name M918 P1 E4 F2000000 ; configure direct-connect display ; Network ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X32 Y32 Z32 I0 ; configure microstepping without interpolation M350 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1680 Y1680 Z1680 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z500 S0 ; set axis maxima ; Endstops M574 Z1 S0 ; set active low and disabled endstops M574 X1 Y1 S1 ; set active high endstops ; Z-Probe M558 P0 H5 F120 T24000 ; disable Z probe but set dive height, probe speed and travel speed M557 X15:215 Y15:195 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M305 P1 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S275 ; set temperature limit for heater 1 to 275C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined
Thanks
You have a 400 steps/rev stepper, the original are 200. You need to double your steps/mm for every axis that you switched the steppers out
@Thunder said in [CR 10 5s]
Did you use the RRF Config Tool (Click the link)My First glance is your M906, some of your values are high.
My suggestion
M906 X1400 Y1700 Z1400 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
I am guessing In regards to your M92, you can try it, I am not saying it is right!
M92 X400 Y200 Z4000.00 E420.00 ; set steps per mm
Make sure if you move 10mm in any axis from DWC it has physically moved that distance,Also I would start with this, then tweak later.
M350 X16 Y16 Z16 E16 I 0 ; set 16x microstepping for axes & extruder, without interpolation
As I said, not 100%, but it might get you on the right path.
Paul.
I did somthing simular to a cr10 s what is the pich on your screw 5 or 10 mm. Kersy manufacturing Has a u tube video that might be very helpful it was for me. He goes thrie the whole process
Ok. Long time no write. I have made the printer move. And now I have another problem. I have a titan aero extruder with a Vulcano hotend. And now I struggle with the top layer and the edges. I get a bit deformed left corner.
Hope anybody will see this thread.Z is the top layer
Here is my config file.
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun May 24 2020 20:05:38 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M551 P"GoBevk" ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X160.00 Y80.00 Z800.00 E809.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1400 Y1700 Z1400 E800 I50 ; set motor currents (mA) and motor idle factor in per cent M84 S50 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 Y1 Z1 S1 ; set active high endstops ; Z-Probe M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch M558 P9 H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-66.4 Y-10.2 Z2.15 ; set Z probe trigger value, offset and trigger height M557 X15:495 Y15:495 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Any suggestions ??:)
Ok and now the pictures :
https://ibb.co/8MpQxcJ
https://ibb.co/NN1n4zJ
https://ibb.co/q9rRb3G
https://ibb.co/vHDkSY9
https://ibb.co/SnsXfHZ
https://ibb.co/GRvZFQ1
https://ibb.co/1z8SLzXThe nozzle is 0.8mm
You might find it interestin but i put linear rails/ballscrew and with a pich if 10mm if you are interested in knowing the effort was worth it .
all the gosting is gone completely. It was a lot of work please feel free to ask me anything you like
I have not experienced the same issues with my top layers but im only running a .4 nozzle...
Just chainging the board out is enough of a challenge my hats off to you! 😁 knowing whats to be done!! i call it the fankenprinter!!!My next step is to strip the x carrage completely
I thought i would use both an end stop for the z axes and the z probe. I kbow its possable seen a couple of posts
Reasoning behind is after the upgrade there will be no more give on the hotend thus as a safety precaution, i have run my hotend carriage into my build platform several times
Hemera direct drive extrude upgrade to come
By the way its not a cr-10s5 anymore
Same thing i started with.
@ziggymanpopo Thanks. I also upgraded the z-axis and the x-axis to linear rails. Still have to upgrade the x-axis. Why did you decide to change the ball screws? Thanks for the compliment :).
What do i call it ?
I nsmed my printer frankenprinter as a joke almost all of the original parts are gone just the frame left
I found out that almost all of my settings needed tweeking after the d.w.c. change
I used the 10 pitch,, much faster ball screw.
