    Constant errors
    Duet Web Control
    1.9k
    • A Former User?
      A Former User
      Super fun time, this thing is true POS...
      Not even this BOSSA can do it, geting errors here and there.
      Verify failed
      Page errors:1114
      Byte errors:563942
      And now the board is compleatly useless...
        Before you clicked Write in Bossa, did you (a) check Erase All, Lock, and Boot from Flash in Bossa; and (b) remove the Erase jumper from the Duet?
        • A Former User?
          A Former User @dc42
          Yes
          • A Former User?
            A Former User
            Stuck on Writing page 0 (0%) for the past 10min
              jay_s_uk
              What OS are you flashing from?
              • A Former User?
                A Former User
                Windows 10
                  jay_s_uk
                  Windows can be a bit odd sometimes.
                  It's possible to use bossa from a pi if you have one.
                  • A Former User?
                    A Former User @jay_s_uk
                    @jay_s_uk
                    Hell no im not trowing any more money at this thing, like i have stated its discusting that the product quality is so bad.
                      jay_s_uk
                      I'm not suggesting you spend any more money.
                      I was purely stating that windows can be odd with USBs (outside of the control of the Duet team).
                      I would also suggest trying connecting through a USB hub (preferably powered) as your PC may not be able to supply enough power.
                      If you don't have one of those but you have a laptop, you can power the Duet 3 using 12-32v and connect the laptop via USB and try that way. Just make sure the laptop is ran off battery power only.
                      • A Former User?
                        A Former User
                        No luck, have none of those.
                        • A Former User?
                          A Former User
                          What option do i have left, was able to aquire a laptop from my niece and even powering the duet with the PSU and trying with the laptop results in the same thing.
                            dc42 administrators @A Former User
                            @Torppa said in Constant errors:
                            Verify failed
                            Page errors:1114
                            Byte errors:563942
                            This is almost exactly what I get when i use Bossa without removing the Erase jumper first. I am flashing version 3.1.1 so I get slightly different results:
                            After removing the Erase jumper, pressing Write again and then Verify, it works:
                            So please double check that you have removed the correct jumper:
                            • A Former User?
                              A Former User
                              I did not have the jumpper on, still did the reset and erase again and no luck
                                Looks like the MCU is not coming out of Erase mode. Try the following:
                                • Put the Erase jumper on
                                • Press the Reset button on the Duet
                                • Remove the jumper
                                • Press Reset again
                                • Reconnect Bossa (you can normally just click on the COM port dropdown and select the same COM port again)
                                • Ensure that Erase All, Lock and Boot to Flash are checked (but not the other boxes)
                                • Press Write
                                • Press Verify
                                The Write operation should display a progress bar and take 15 seconds or longer.
                                • A Former User?
                                  A Former User @dc42
                                  Does not work
                                    Are you using VIN power to the Duet, USB power, or powering it some other way?
                                    • A Former User?
                                      A Former User
                                      BOSSA just wont write.
                                      And USB power
                                        USB power alone may be insufficient. Please read the notes on avoiding USB ground loop problems at https://duet3d.dozuki.com/Wiki/USB_ground_loops and try again with VIN power. I assume that you have the 5V regulator on the Duet enabled.
                                        • A Former User?
                                          A Former User
                                          Running on VIN and a laptop results in the same problem.
                                            Make sure that the PC and the Duet PSU are plugged into the same power distribution block then. Usually it's not a problem if they are not, but occasionally a home has faulty mains wiring.
