    USB Drivers
    20
    1617
    • Bmilam
      Bmilam last edited by
      Im trying to install an new Duet 2 wifi board, the link to the Windows USB Drivers is broken, anyone have a working link?
      here is the broken link:
      https://github.com/Duet3D/RepRapFirmware/blob/dev/Driver/DuetDriverFiles.zip
      • A Former User
        A Former User last edited by
        you'll find them randomly in the release as well
        f.ex. https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetDriverFiles.zip
          Phaedrux Moderator @Bmilam last edited by
          @Bmilam said in USB Drivers:
          Where was that link from? We should get it corrected.
            I renamed that file earlier this week to WindowsDriverFiles.zip.
              I have corrected the link in the Getting Connected guide.
              hblz 2 Replies Last reply Reply Quote 0
              • hblz
                hblz @dc42 last edited by
                @dc42 I can't get the driver working. Is the driver Windows 10 ready? It doesn't say in the info.
                I really need it to get connected to my duet because there went something wrong with setting the duet to a fixed ip adres with the M552 in the config.g. Thanks for helping out
                  Yes it works with Windows 10. To install it, unzip it (2 files) into a directory on your PC, then double click on the .inf file.
                  • hblz
                    hblz last edited by
                    This is a fast response! Install worked but Unfortunatedly the device is still not connecting.
                    Is there a way to reset the IP adres so I can connect again through wifi?
                    I need it to get connected to my duet because there went something wrong with setting the duet to a fixed ip adres with the M552 in the config.g
                    • jay_s_uk
                      jay_s_uk last edited by
                      Pull the sd card and edit the config.g manually.
                      No settings are physically stored on the duet and are all loaded from the config.g file from the sd card at start up
                      • hblz
                        hblz last edited by
                        Yeah, great advise! Thanks. It works. But now back to setting my Duet wifi to a fixed adress. M552 S1 Px.x.x.x does not work...
                        jay_s_uk A Former User 2 Replies Last reply Reply Quote 0
                        • jay_s_uk
                          jay_s_uk @hblz last edited by
                          @hblz if possible, I would suggest you look at assigning a fixed IP from the router rather than the duet. That way there's no chance of another device getting assigned the same IP
                          hmortensen 1 Reply Last reply Reply Quote 0
                          • hmortensen
                            hmortensen @jay_s_uk last edited by
                            @jay_s_uk If you know your own network segment, and assign static IP on the ESP, you shave around 1-2 sec in boot time.
                            • A Former User
                              A Former User @hblz last edited by
                              @hblz said in USB Drivers:
                              i think it should, been awhile since i tried it. the other option is to store it with m587 Ix.x.x.x
                              you may want to forget the old entry first for good measure.
                              (also, what he said ☝ )
                              • hblz
                                @dc42 I still can't get the USB driver working. Is there a way to clean the drivers up? Is there a difference between versions of the Duets wifi ? I would like to be able to connect the duet3d to my simplify 3d since this is sometimes easier and quicker then sending files to the duet.
                                  Do you see anything show up when the duet is connected if you go to view > show hidden devices?
                                  hblz 1 Reply Last reply Reply Quote 0
                                  • hblz
                                    hblz @Phaedrux last edited by
                                    @Phaedrux Yes, it says 'unknown USB, device descriptor failed' (translated from dutch)
                                      Can you delete that device and then replug the duet into a new port?
                                      Do you have a powered usb hub to try with as well?
                                      • hblz
                                        @Phaedrux Unfortunatedly deleting does not change a thing. Different cable doesnt help either.
                                        • M1sterd
                                          M1sterd last edited by
                                          Does this work over Wifi now as well? I know originally it was said that Windows 10 and 3D printers was around USB, but wondered if this had changed?.
                                            Phaedrux Moderator @M1sterd last edited by
                                            @M1sterd said in USB Drivers:
                                            I'm not exactly sure what you're asking here.
