Auto bed compensation working just not very well
  • I decided to print a bird house. This is the largest print I've done since I built my core xy printer. As can be seen in the picture the first layer is not very consistent. As the nozzle moves around laying down the first layer it can be seen that in some areas the filament is layed down perfectly in other areas the nozzle is high resulting in poor adhesion to the bed and other areas the nozzle is too close.
    Is this a result of poor resolution of the height map requiring more probing points in the X and Y axes or some other issue?
    I printed a Z axes wheel so I can easily observe Z axes movement during a layer and the bed is being moved but the compensation doesn't seem to be enough. What do I need to do to correct this?
    Also I wasn't happy with the bed that came with the printer so Mandella Roseworks made me a cast aluminum bed which is quit a bit better than the stock bed. I have the bed installed and have of course ran a G29.
  • Hi,
    It's hard to be sure but it looks like your first layer Z height is too close to the bed.
    What kind of Z probe do you have?
    What are the dimensions of the grid (M557) you are using when creating your height map?
    Are you performing a G30 before the G29?
  • The Z height is definatly too close to the bed in some places and in others it's not close enough.
    Using a BLtouch
    M557 X15:295 Y0:240 S40:40
    G30 is performed at the end of home all and home Z
    Although the BLtouch has X and Y offsets I'm currently configured with no offsets. The reason for this is when I configure with the correct offsets a G29 is unable to probe all points necessitating the need to run a G29 after every power down. I've tried to configure so that with probe offsets the machine probes all points but so far haven't been able to do so, probably a lack of understanding on my part. That is why Y is 240 instead of 295. I may be wrong but I don't think this is causing my first layer issue but want to mention it because maybe it is.
  • @luckyflyer looking at the way the stripes obviously go with the different infill sections I'd wonder if its actually your z height varying over time (I.e. a mechanical issue, not the compensation).
    Where are your z lead screws located on your bed? On my printer I used to have one on either side, slap bang in the middle. This meant the bed could actually rock a little if anything disturbed it (e.g high xy jerk etc). It only moved maybe 50um but it's enough over a smaller layer height
  • What are your probe offset values?
  • @engikeneer said in Auto bed compensation working just not very well:
    Where are your z lead screws located on your bed? On my printer I used to have one on either side, slap bang in the middle. This meant the bed could actually rock a little if anything disturbed it (e.g high xy jerk etc). It only moved maybe 50um but it's enough over a smaller layer height.
    Two lead screws in the middle such as yours with two very large stabilizing brackets. The bed is very stable.
  • @Argo said in Auto bed compensation working just not very well:
    Offset values are 0:0 for the reasons stated in my post above.
  • If your offset values are zero, you are probing points that the Duet doesn't know about and you are then taking those probing points to adjust the mesh height. You are creating a bad height map and then applying it.
    I don't understand how you can possibly expect any results but crap. You might as well work without any height map.
    It's odd that you get stripes but before anyone can give you any suggestions about what is wrong, you MUST set things up properly !!!
  • Hi,
    You need to set the offsets of your Z probe - otherwise nothing will work as designed.
    To deal with the offset when probing you can...
    1 - limit the probing to points it can reach
    2 - use M564 to allow moving to points you normally couldn't reach so you can probe the desired points
    To use 2 you have to determine if you can move the probe to the desired points without something hitting something else.
    On my printer the Z probe offset is X = 0 Y = +25 BUT I can actually move safely to Y = -25 (past the normal min of Y = 0) so M564 works for me and the probe can get to any point the nozzle can normally go.
  • @fcwilt
    Thanks for that info I'll do that when the bird house is finished.
  • Moderator
    Post your config.g.
    To maximize the grid and not skip any points you need to take the offsets of the probe into consideration. M577 = M208 - G31 XY. Does that make sense?
    Having correct offsets is critical to mesh compensation working properly otherwise the firmware is compensating where it thinks the nozzle is rather than where the nozzle actually is.
    Thankfully, it sounds like you have a really nice and flat bed, so you might not even need much of a mesh at all. a 3x3 grid might be enough.
  • @Phaedrux
    ; generated by RepRapFirmware Configuration Tool v2.1.8 on Wed Apr 29 2020 12:52:20 GMT-0600 (Mountain Daylight Time)
    G90                                          ; send absolute coordinates...
    M83                                          ; ...but relative extruder moves
    M550 P"Duet 3"                               ; set printer name
    M669 K1                                      ; select CoreXY mode
    ; Configure panelDue
    M575 P1 S1 B57600                            ; set to channel 1, panel due mode with checksum, baud 57600
    M569 P0.0 S1                                 ; physical drive 0.0 goes forwards
    M569 P0.1 S1                                 ; physical drive 0.1 goes forwards
    M569 P0.2 S0                                 ; physical drive 0.2 goes backwards
    M569 P0.3 S0                                 ; physical drive 0.3 goes backwards
    ; Bed leveling
    M671 X0.0:155.0:300.0 Y-8.0:242.0:-8.0       ; Define position of bed leveling screws
    M584 X0.1 Y0.0 Z0.2 E0.3                     ; set drive mapping Y = drive 0 X = drive 1 Z = drive 2 Extruder drive 3
    M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
    M92 X200.00 Y200.00 Z1600.00 E420.00         ; set steps per mm
    M566 X900.00 Y900.00 Z100.00 E120.00         ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z600.00 E1200.00      ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E1000 I30                ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                      ; Set idle timeout
    M208 X0 Y0 Z-3 S1                            ; set axis minima
    M208 X300 Y310 Z300                          ; set axis maxima
    M574 X1 S1 P"!io1.in"                        ; configure for low end, active-low endstop on X via pin io1.in
    M574 Y1 S1 P"!io2.in"                        ; configure for low end, active-low endstop on Y via pin io2.in
    M574 Z1 S1 P"!io3.in"                        ; configure for low end, active-low endstop on Z via pin io3.in
    M950 S0 C"io4.out"                           ; create gpio servo 0 for BLTouch
    M558 P9 C"io4.in" H2 F120 R.350 T6000        ; set Z probe to bltouch, set input to io 4 in, set dive height,set feed rate, set delay, set speeds
    G31 P500 X-4 Y59 Z3.20                       ; set Z probe trigger Height, X and Y offset and trigger height
    M557 X10:300 Y0:251 P3:3                     ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
    M143 H0 S110                                 ; set temperature limit for heater 0 to 110C
    M307 H0 A236.8 C516.8 D3.0 V24.1 B0          ; disable bang-bang mode for the bed heater and set PWM limit
    M140 H0                                      ; map heated bed to heater 0
    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
    M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
    M143 H1 S260                                 ; set temperature limit for heater 1 to 260C
    M307 H1 A445.5 C173.0 D5.5 V24.1 B0          ; disable bang-bang mode for hotend heater and set PWM limit
    M950 F0 C"out7" Q500                         ; create fan 0 on pin out7 and set its frequency
    M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
    M950 F1 C"out8" Q500                         ; create fan 1 on pin out8 and set its frequency
    M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
    M563 P0 S"E3D-V6" D0 H1 F0                   ; define tool 0
    G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
    G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
    ; Lights
    M950 P1 C"out3"                             ; Create port on out 3 to power lights, 12v led strips are wired in series
    T0                                           ; select first tool
    My M557 looks wonky since the pei sheet size is 310X310, this was my attempt to compensate for no offset, I'm now aware of this flawed logic.
  • Moderator
    Alright, first steps are to make sure the M208 is correctly sized. 0,0 being the front left corner of the bed. The minima would be the far left and front positions where the endstops trigger and then from there you can move the head to the far right and back positions of travel to get the m208 maxima.
    Then you can measure the probe offset with this: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
    Then you can maximize the mesh grid by choosing the starting points for the minimum X Y that can actually be reached based on the offset. For example, If the probe is to the right of the nozzle by 20mm, it can't reach X10.
  • @Phaedrux said in Auto bed compensation working just not very well:
    Ok, everything you have stated I understand. For reference my Z probe is 59mm behind and 4mm to the left of the nozzle. So for my offsets I have X-4 and Y59 as can be seen in the config.G file above.
    This is what happens when I do a G29 with the above config.G. The nozzle heads for the front left corner 0,0 but stops short at 41mm in the Y plane which puts the probe at 100mm from the front edge of the pei plate, I'm losing 41mm of probe area. If I leave the Y offset at 0 then a G29 will probe with the nozzle going to Y0 putting the probe at 59mm. So why is 41mm sacrificed when there is an offset? Also I get the points not probed message, I don't get that message with 0 offset. This is the main reason I tried using 0 offsets.
  • Can anyone tell me why I lose 41mm of probe(able) Y bed area when I have a 59mm Y offset? And what if anything can be done to correct it?
  • Moderator
    Please try M557 X10:290 Y60:300 P3:3
    This should give you a 3x3 grid of the reachable area based on your values
    M208 S1 X0 Y0
    M208 S0 X300 Y310
    G31 X-4 Y+59
    If those values are correct this is what your reachable area looks like.
    The green box isn't quite right, but you get the idea.
  • @Phaedrux Yes sir thank you for that. I've been playing with the offsets the better part of the day to try to understand The "if I do this it causes that". Getting my first layer down consistently over a large area is the only major thing I have left to tune on this printer.
    Pretty well fried for the day will try your settings tomorrow. Very nice diagram btw.
  • @Phaedrux I used your M557 and G31 X-4 Y59 numbers and then a G32 which is .00 and .01 Then a G29. Then did a one layer test print with auto height adj active.
    The print started in the lower left corner and is perfect. But right after the square of holes you can see an abrupt change. The nozzle is not as close to the bed. Bed adhesion is poor. As the print progresses from the lower left to the top right into the X it gets really bad getting a little better towards the print end. It is interesting (at least to me )that I got basically the same quality of print with and without the proper offsets. Here is height map.Heightmap.jpg
    What I don't understand is why is Z -.096 for the center measurement? Since I'm using a BLtouch my homeall ends in a G30 at the center of the bed. Shouldn't the center measurement always be 0.00? I'm not aware of any further mechanical adjustment that should be done or redone to correct my first layer issues. My G32 is either perfect or near perfect.
    All thoughts on this appreciated.
  • @luckyflyer
    I always do a G30 right before probing with G29 and right before printing to try and compensate for any mechanical/temperature changes.
    Also 9 points can give you a good overview of the bed but unless you know your bed is truly flat from edge to edge you will have to probe a lot more points for mesh comp to work well.
    I probe by 300 x 300 bed using X and Y spacing of 20 mm.
  • Moderator
    At this point I think it would be good if you could post your homing files and bed.g as well as your current config.g and your slicer start gcode so we can see the entire sequence of gcode events. Now that you have the grid correct there are some tweaks you can do to improve the results of the mesh.
  • ; bed.g
    ; Remember to include probe offsets in X and Y coordinates
    G28                          ; home
    M401                         ; deploy Z probe
    G30 P0 X11 Y55 Z-99999         ; probe left front adjusting screw
    G30 P1 X296 Y55 Z-99999       ; probe right front adjusting screw
    G30 P2 X152 Y305 Z-99999 S3  ; probe middle rear adjusting screw and report adjustments needed
    M402                         ; retract probe
    ; homeall.g
    ; called to home all axes
    G1 H2 Z7 F6000          ; lower bed 7mm to ensure probe is above the Z probe trigger height
    G1 H1 X-310 Y-310 F2600  ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-310             ; home X axis
    G1 H1 Y-310              ; home Y axis
    G1 X5 Y5 F6000         ; go back a few mm X and Y
    G1 H1 X-310 F360        ; move slowly to X axis endstop once more (second pass)
    G1 H1 Y-310 F360         ; then move slowly to Y axis endstop
    G1 X157 Y99 F2000       ; Move probe over to the center of the bed
    G30                     ; lower probe, stop when probe triggered and set Z to trigger height, home Z by probing the bed
    ;G91                    ; relative positioning
    ;G1 Z5 F100             ; lift Z relative to current position
    ;G90                    ; absolute positioning
    And since the new bed is thicker than the oem bed I'm preheating for 10 minutes before I start a print.
    I'm now printing the same print without height comp. Will post when finished.
  • @fcwilt Heightmap done yesterday with many probe points. Made me wonder about the quality of plate I received. A print with this height map was about the same as above.
  • Moderator
    ; bed.g
    G28                          ; home all
    M561      ; clear any bed transform
    ; first run
    ; second run
    ; z probe in config.g
    M558 P9 C"io4.in" H2 F60 R0.5 T6000 A10 S0.003       ; set Z probe to bltouch, set input to io 4 in, set dive height,set feed rate, set delay, set speeds
    G31 P25 X-4 Y59 Z3.20                       ; set Z probe trigger Height, X and Y offset and trigger height
    M557 X10:290 Y60:300 P12:12                     ; define mesh grid
    Make these changes in config.g and bed.g, reboot, and then run G32 and then G29. That should home the printer, adjust lead screws twice, reestablish Z0, and then do a more detailed mesh grid. 3x3 lacks the detail needed and the interpolation between the sparse points is causing adjustment that isn't actually there. Your grid needs a higher resolution.
    The changes to the BLTouch will make it probe more accurately, but it will take longer.
  • @Phaedrux Sounds good, thanks
    Also sorry , did not see slicer start script,
    T0                                         ; select tool
    M109 S200                             ; wait for hotend temp
    M190 S60                               ; wait for bed temp
    G28                                        ; home all axes
    G29 S1                                   ; load height map
    G1 X130.0 Y15 Z0.0 F2000       ; move tool
    G1 X40.0 E10 F1000                ; prime nozzle
    G92 E0                                   ; reset extruder
    G1 E-.65                                 ; retract 1 mm
  • Hi,
    You can also try forcing the probe to average a fixed set of readings.
    For example in M558 an A value of 5 and a S value of -1 the firmware will take 5 readings at each point then average them.
    While averaging takes longer I think you would get a truer picture of your bed.
