Solved Creality BLtouch kit compatibility and wiring
@Phaedrux According to the config.g file it says its running firmware 2.03 so I'll try updating it. I have one question though sinch the user interface of the configurator of that version is slightly different.
It asks for a modulation pin input for the z probe. If my wiring is exactly the same as this, what should I set this to? I assume either zprobe.mod or zprobe.mod(inverted).
EDIT: I tentatively install version 3 firmware with what I think are the right settings and now it gives me an error when I type in the M280 P3 S10 I1 command.
It says "invalid servo index 3 in M280 command".
@Phaedrux I had a chance to look through the gcode documentation on the duet3d website and I see I have to assign a GPIO port in servo mode to the duex pwm 1 channel for RRF3.
After looking through the new config.g the tool gave me I can see it assigned M950 S0 C"deux.pwm1", so the pwm channel is defined as port 0. But when I Input M280 P0 S10 into the gcode console I still recieve the error.
Error: M280: Invalid servo index 0 in M280 command
Here's the new files
homez.g
homeall.g
deployprobe.g
config.g -
In config.g in your M558 remove
+!zprobe.mod
and add a ^ in front of zprobe.inM558 P9 C"^zprobe.in" H5 F120 T6000
The rest looks correct now if you're actually plugged into Duex PWM1 and you're using version 3.1.1.
Please send M115 in the console to confirm the firmware version and send M98 Pconfig.g and report back with any errors.
@Phaedrux Now something strange is happening. I'm certain I selected version 3 software and even looking back at my config.g is says it was generated by Configuration Tool v3.1.3:
; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jun 19 2020 13:20:18 GMT-0400 (Eastern Daylight Time)
But the M115 command returns this:
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05 ELECTRONICS: Duet WiFi 1.02 or later + DueX5 FIRMWARE_DATE: 2019-12-13b1
Either it's not updating the system files when I upload the zip folder or I'm not understanding something. Is it refering to the same thing or another piece of firmware?
Yes it appears that the firmware update was unsuccessful. Going from 2.05 will require updating to 3.0 first, and then 3.1.1. The intermediate upgrade to 3.0 is required to update the programing files before you can go to 3.1.1.
From the release notes: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1
Back up the contents of your /sys folder before upgrading to RRF 3.x in case you need to revert to RRF 2
Many changes to config.g are needed when upgrading from RRF 2.x to 3.x. See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Summary_of_what_you_need_to_do_to_convert_your_configuration_and_other_files for a summary. It may be simpler to use the online configurator to generate new files for scratch.Users of RepRapFirmware 2.x cannot upgrade directly to this release because the binaries for the Duet 2 series are too large for the Duet 2 IAP programs. So you must upgrade to RepRapFirmware 3.0 first, then you can upgrade immediately to version 3.1.1. Alternatively, you can use Bossa over USB to upgrade directly to RepRapFirmware 3.1.1 but in this case you will need to upload DWC 3.1.1 and the appropriate IAP file separately.
Once you are actually updated to 3.1.1 your config should work.
Could someone please summarize, how to properly connect the Creality BLTouch (Red, Blue, Yellow, Black, White cables) to the Duet 2? I'm still not able to get it running and all the pists about the different colors are quite confusing.
Thanks, Martin
OMG...why they are not just stick to a standard
Thanks for that!!!
Sorry, but I need to double check. It is still confusing to me because the picture show colors in a different order than my Creality BLTouch. Mine has Red, Blue, Yellow, Black, White from richt to left.
Just want to make sure that I don't cable it wrong and damage the Duet 2 board.
Thanks, Martin
@MartinNYHC I saw a lot of different combinations.
I expect the best chance of correct assignment is to check the order at the connector and deciding from that which single cable and color is which connection.
My Geetech clone, Smart 2.0 and Smart 3.1, all cables have colors brown-red-yellow-black-white and at all three the 5-pin connector have the same order, so chances are high that when you look at the 5-pin connector, you can find out the correct color-function assignment.
For Duet wiring, please check https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch then.
For those of you who have a beautiful "Red, Blue, Yellow, Black, White"-cable-BLTouch:
Blue goes to expansion pin 1 (+5V)
Red goes to expansion pin 2 (GND)
Yellow goes to expansion pin HEATERx
White goes to Z_PROBE_IN
Black goes to GND on ZPROBE portMaybe this can also be added to the documentation.
