    topic_unsolved Duet 3 rrf3.1.1 Z offset
    53
    • mrenz999
      mrenz999 last edited by
      I can't seem to get my z offset to the bed to change anything. I have set it to 6 and to -6 and it stays the same.
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
      M550 P"Duet 3" ; set printer name
      M669 K1 ; select CoreXY mode
      M569 P0.0 S0 ; physical drive 0.0 goes forwards
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z480.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X2500.00 Y2500.00 Z20.00 1000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X330 Y330 Z400 S0 ; set axis maxima
      M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
      M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P1 C"!io3.in+io3.out" H5 F120 T6000 ; set Z probe type to modulated and the dive height + speeds
      ;M558 H30 ;*** Remove this line after delta calibration
      G31 P500 X0 Y40 Z-3 ; set Z probe trigger value, offset and trigger height
      M557 X30:300 Y20:300 S20 ; define mesh grid
        What is your probe?
        Please post your homeall.g file.
        • mrenz999
          My probe is a simple IR probe. Seems to be working fine. Just won't change height when I start a print. I never use homeall Just x then y the z. But I'm not opposed 🙂
          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G1 H1 X-335 Y-325 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-335 Y-325 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 X150 Y150 F9000 ; go to first bed probe point and home Z
          G30 ; probe the bed
          G1 Z5 F100 ; lift Z relative to current position
          G90 ; absolute positioning
          ;G1 X0 Y0 ; return to parked position
          Phaedrux JoergS5 3 Replies Last reply Reply Quote 0
            Phaedrux Moderator @mrenz999 last edited by
            @mrenz999 said in Duet 3 rrf3.1.1 Z offset:
            In that case post those files.
            mrenz999 1 Reply Last reply Reply Quote 0
            • JoergS5
              JoergS5 @mrenz999 last edited by JoergS5
              @mrenz999 this homing file would not work. The xy move stops at the first x or y endstop, repeated a second time, also stopping at the first endstop. Necessary is after the first stop to move x and y separately, so the other endstop is reached also. In ducumentation is an example.
              Please see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_homeall_g_file
              but S1 replaced by H1
              • mrenz999
                mrenz999 @Phaedrux last edited by
                @Phaedrux I would like to use the homeall but it doesn't work so I use the individual ones.
                ; homex.g
                ; called to home the X axis
                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:21 GMT-0700 (Pacific Daylight Time)
                G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 X5 F6000 ; go back a few mm
                G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
                G1 H2 Z-5 F6000 ; lower Z again
                ; homey.g
                ; called to home the Y axis
                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 13 2020 19:59:22 GMT-0700 (Pacific Daylight Time)
                G1 H1 Y-335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G1 Y5 F6000 ; go back a few mm
                G1 H1 Y-335 F360 ; move slowly to Y axis endstop once more (second pass)
                ; homez.g
                ; called to home the Z axis
                G30 ; home z by probing the bed
                ;G91 ; relative positioning
                ;G1 Z5 F100 ; lift Z relative to current position
                • mrenz999
                  mrenz999 @JoergS5 last edited by
                  @JoergS5 Thank you for the link. I will try to implement those and see what happens.
                  JoergS5 1 Reply Last reply Reply Quote 0
                  • JoergS5
                    @mrenz999 in worst case -335 may not reach the endstop, just use e.g. -400 for x and y movements, it stops when reaching the endstop.
                    At M201 is missing the E for the last value, please add.
                      Please post your slicer start gcode as well.
                      Your homeall looks to mirror your individual homing files. What exactly happens when you homeall?
                      You appear to be missing an M950 for your probe pin which is required for RRF3. Does it come later? Did you hand create this config file or did you get it from the configurator?
                      Can you post the entirety of your config.g?
                      Also please post the results of M122.
                      Trying to duplicate your config in the online configurator I seem to get something similar without an M950 as well. Maybe I'm confused myself.
                      M574 X1 S1 P"io0.in"                         ; configure active-high endstop for low end on X via pin io0.in
                      M574 Y1 S1 P"io1.in"                         ; configure active-high endstop for low end on Y via pin io1.in
                      M558 P2 C"io3.in+io3.out" H5 F120 T6000      ; set Z probe type to modulated and the dive height + speeds
                      G31 P500 X0 Y0 Z2.5                          ; set Z probe trigger value, offset and trigger height
                      M557 X15:215 Y15:195 S20                     ; define mesh grid
                      mrenz999 Phaedrux 2 Replies Last reply Reply Quote 0
                      • mrenz999
                        @Phaedrux
                        M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
                        M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
                        M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                        M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                        M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                        M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                        M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
                        M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                        M501
                        I am not using and G code in my slicer yet. Wanted to make sure I wasn't causing additional issues.
                          Phaedrux Moderator @Phaedrux last edited by
                          @Phaedrux said in Duet 3 rrf3.1.1 Z offset:
                          Sorry, ignore this. I've been looking at too many BLTouch threads. You do not need a M950 for the IR probe because there is obviously no servo to control!
                          Going back to your original problem description:
                          Where are you trying to set it and how are you measuring the result?
                          For the IR probe you should have a G31 Z with a positive value (the probe triggers before the nozzle hits the bed. Negative would mean the nozzle touches and presses into the bed.)
                          Have you gone through this? https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          • JoergS5
                            your E is still missing, please replace
                            by
                            M201 X2500.00 Y2500.00 Z20.00 E1000.00 ; set accelerations (mm/s^2)
