    All axis stop moving before hitting switches
    939
    • Gabell20undefined
      Gabell20 @JoergS5
      @JoergS5 Cool, I have just upgraded
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @Gabell20
        @Gabell20 and it's all working now ? 🙂
        Gabell20undefined 1 Reply Last reply Reply Quote 0
        • Gabell20undefined
          Gabell20 @JoergS5
          @JoergS5 no 😞 this is not as related but my z is going the opposite way
          • Gabell20undefined
            Gabell20 @Phaedrux
            @Phaedrux The x switch is on the left and the y switch is mounted to the x carriage and triggers at the back.
              Can you go through these steps to test endstop and motors before homing?
              https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39#s145
              • JoergS5undefined
                JoergS5 @Gabell20
                @Gabell20 when I imagine that your G1 H2 runs ok, but G1 H1 stops after a few mm, and you use NC endstop, is it possible that the movement triggers the endstop, by the movement eg? If the G1 H1 stops, does the DWC show the endstop triggered?
                • Gabell20undefined
                  Gabell20 @Phaedrux
                  @Phaedrux That is helpful, but i followed along and the problem persists.
                  • Gabell20undefined
                    Gabell20 @JoergS5
                    @JoergS5 that could be it, I noticed that sometimes under acceleration thy show up triggered, I wonder if I can makes the axes accelerate slower but only during homing.
                    Phaedruxundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                      Phaedrux Moderator @Gabell20
                      @Gabell20 said in All axis stop moving before hitting switches:
                      You certainly can. Just add a new acceleration command at the start of the homing file and then change it back to the previous value at the end.
                      • JoergS5undefined
                        JoergS5 @Gabell20
                        @Gabell20 as a first test you can set the F values low while homing.
                        Phaedrux you were faster and had the better answer 😉
                        • Gabell20undefined
                          Gabell20 @Phaedrux
                          @Phaedrux @JoergS5 thank you i will try that now. EDIT: that did not work, now I have the same problem but slower lol, I should just purchase new switches
                            What exactly are the switches?
                            • Gabell20undefined
                              Gabell20 @Phaedrux
                              @Phaedrux I don't know, they are just no name switches that came on the machine. i am going to try putting ferrules around them.
                              • Gabell20undefined
                                Gabell20
                                So as it turns out, the wires from the switches were picking up some noise and causing the input to go high. I solved this by using shielded wire for my limit switches and now the machine homes just fine. Thank you @Phaedrux @JoergS5 @fcwilt for your responses.
                                  Glad you got it figured out.
