    Impossible to set extruder micro stepping above 16ms
    39
    1.7k
    • observatoerundefined
      observatoer @JoergS5
      @JoergS5 Looks OK to me.
      G29 S1 P"heightmap.csv" ; Load the height map from file and activate bed compensation.
      G90 ; use absolute coordinates
      M83 ; extruder relative mode
      M98 P"0:/sys/G828.g" ; home if not homed
      M98 P"0:/sys/G832.g" ; if not already leveled, level bed and re-home Z
      ; prime nozzle
      G1 X0 Y0 F99999.0 ; Go home
      G1 Z0.15 ; lower extruder
      G1 X2 Y20 Z0.3 F5000.0 ; move to start-line position
      G1 X2 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
      G1 X2 Y200.0 Z0.4 F5000.0 ; move to side a little
      G1 X3 Y20 Z0.4 F1500.0 E30 ; draw 2nd line
      G92 E0.0
      And the two calls look clean, too:
      ; G828.g
      ; Conditional variant of G28 home command.
      ; Homes all axes if not already homed.
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
      G28
      ; G832.g
      ; Conditional variant of G32 bed command.
      ; Perform bed leveling if not already leveled.
      if move.calibration.numFactors == 0 ; if leveling has not yet been performed...
      G32 ; level bed
      G28 Z ; re-home Z
      else
      echo "Bed already leveled. Skipping..."
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @observatoer
        @observatoer then I have no more ideas at the moment. I would remove and disable or comment out all and readd step by step to find the reason. It is also possible that there is a bug somewhere, because you have a lot of settings, macros etc. To be sure it's not IdeaMaker I would try a different program and g-code file first.
        observatoerundefined 1 Reply Last reply Reply Quote 0
          @JoergS5 Thank you for your time and hints!
          JoergS5undefined 2 Replies Last reply Reply Quote 0
          • JoergS5undefined
            @observatoer sorry that I could not help. I think it's something trivial, a syntax error e.g., but I didn't see one.
            Maybe M350 E16 I0 changing the E without interpolation behaves other than expected. You could try changing it to I1 as a test.
            • JoergS5undefined
              @observatoer I have one more idea: according the information in some threads like https://forum.duet3d.com/topic/4939/m350-not-working-wrt-m584/6 the order of the drives seem to play a role in the M584 command. In you config you have E first, so this may not be seen as an extruder drive in some code for other program parts. You could try changing
              M584 E0 X1 Y2 Z3:4:5
              to
              M584 X1 Y2 Z3:4:5 E0
                If anyone thinks that M350 is not behaving as described in the wiki GCodes page, please supply files that replicate the different behaviour.
                  @JoergS5 That would make sense and I will give it a try. Stii the change will be a bag of hurt to get the order of the z drives and the related measurements for ABL right.
                  Thank you very much for your help! I will report, how this turns out.
                    observatoer @dc42
                    @dc42 I guess, this tread is full of all related logs and describes the issue in detail. Still I understand, it's a pain to go thru the logs.
                      One of the reports says that the steps/mm changes when starting a print, but I didn't see a print file posted. Also, the config files have changed, so it's hard to be sure what the current ones look like.
                        observatoer @dc42
                        @dc42 Thank you, this was the right question.
                        Ideamaker is setting the E value to 822s/mm and writes this at the beginning of the code.
                        That was the reason, why this issue came up.
                        Thanks again and I guess, the solution is found.
