My corexy hbot configurations and build pictures
i really did not know much about the sys folder and its contents , but a week later i got my printer working with a bit of help from a couple of smart moderators here : thanks
this is a work in progress, if you see any thing i need to pay attention to please let me know , i can test it out and see if it fits my build. and i will update as necessary .
Printer is a custom made Hbot. 500mm x 500mm x 950mm
dual independent Z axis steppers with each their own endstopRepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
capable of homing the z axis (Z and U) separately and independently
to get the bed fairly levelit also can use G32 bed leveling to get it really level.
my X/Y endstops are in the rear left corner
my z endstops are on the left and the right sides of the x axis in the middle of the y axis.X0 and Y0 are in the front left corner
im using external closed loop stepper drivers
x and y are (5) and (6), z and U are (7) and (8), in the config.g M584my endstops are 24v proximity sensors, with schottky bat43 diodes
my config files are below and are the only files i changed, all else are original
; General preferencesG31 X0 Y0 Z0 P25
M550 P"Duet2" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P5 S0 T5 R1 ; physical drive x axis goes forwards
M569 P6 S1 T5 R1 ; physical drive y axis goes forwards
M569 P7 S1 T5 R1 ; physical drive z axis goes forwards
M569 P8 S1 T5 R1 ; physical drive U axis goes forwards
M569 P3 S1 ; physical drive Extruder goes forwards
M584 X6 Y5 Z7:8 U8 E3 P3 ; set drive mapping
M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
M350 X16 Y16 Z16 U16 E16 I1 ; configure micro stepping with interpolation
M92 X200.00 Y200.00 Z800.00 U800.00 E138.23 ; set steps per mm
M566 X200.00 Y200.00 Z12.00 U12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X25000.00 Y25000.00 Z1000.00 U1000.00 E2400.00 ; set maximum speeds (mm/min)
M201 X400.00 Y400.00 Z20.00 U20.00 E400.00 ; set accelerations (mm/s^2)
M906 X300 Y300 Z300 U300 E800 I30 ; set motor currents (mA)
M208 X0 Y0 Z0 U0 S1 ; set axis minima
M208 X440 Y535 Z900 U900 S0 ; set axis maxima; Endstops
M574 X1 Y2 Z1 U1 S0 ; set active high endstops 1= minimum 2=maximum, S1 = normally closed and S2 = normally open; Z-Probe
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
G31 P500 X0 Y0 Z4.247 ; set Z probe trigger value, offset and trigger height
M557 X70:400 Y180:500 S100 ; define mesh grid x70:400 starts at 50, ends at 400 SXX moves by what its set to between points; Heaters
M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
;M575 P1 S1 B57600 ; enable support for PanelDue; deployprobe.g
;deployprobe.g
M280 P7 S10 ;deploy bltouch;retractprobe.g
M280 P7 S90 I1 ; retract BLtouch pin; homeall.g
; called to home all axes
M280 P7 S160
G91 ; relative positioning
G1 S2 H2 Z5 F800 ; lift Z relative to current position
G1 H1 X-445 Y540 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-445 ; home X axis
G1 H1 Y540 ; home Y axis
G1 X5 Y-5 F800 ; go back a few mm
G1 H1 X-445 F200 ; move slowly to X axis endstop (second pass)
G1 H1 Y540 F200 ; move slowly to Y axis endstop (second pass)
M584 Z7 U8 P4 ; split Z motor control to Z and U
G1 S1 H1 Z-900 U-900 F400 ; home Z and U axis
G1 Z5 U5 F200 ; go back a few mm
G1 H1 Z-900 U-900 F100 ; move slowly to Z and U axis endstop (second pass)
M584 Z7:8 P3 ; back to combined axes and hidden U
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
G1 Z10 F800 ; lift Z relative to current position
G90 ; absolute positioning; homex.g
; called to home the X axis
M280 P7 S160 ; Alarm Release and Push-Pin UP
G1 H2 Z5 F800 ; lift Z relative to current position
G1 H1 X-445 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F800 ; go back a few mm
G1 H1 X-445 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F800 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y540 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y-5 F800 ; go back a few mm
G1 H1 Y540 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 H1 Z-900 U-900 F100 ; move slowly to Z axis endstop (second pass)
G1 Z5 F400 ; lift Z relative to current position
G90 ; absolute positioning; bed.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 02 2020 19:54:07M280 P7 S90
M561 ; clear all bed compensation
G28 ; home all axis
G1 X220 Y330 Z25 ; move probe to center of the bed
G30 ; set Z0 position with the probe
G1 Z25 ; return to 25mm height
G30 P0 X440 Y330 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X0 Y330 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
M280 P7 S90i hope by leaving this as an example for others it can be a good visual aide.
pictures of pin connections and printer layout to come.
@tracar said in My corexy hbot configurations and build pictures:
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1your thermistor settings are not configured properly. 4138 is the default and most likely wrong for your thermistors.
@Veti
this i had no clue i needed to fix. what do i need to do to fix this ? -
find out what thermistors you have and look in the spec sheet and find the beta value.
@Veti
ahhhh , i had to configer these in marlin as a 6 on the old prusa
i think that was a 100k -
nearly all thermistors used today are 100k
marlin 6 is
6 : 100k EPCOS - Not as accurate as table 1 (created using a fluke thermocouple) (4.7k pullup)
not a good starting point.
where did you buy the thermistors?
@Veti
think it came with the prusa, i3 clone from folgertech a few tears ago!! -
the prusa i3 clone comes with a mk8 hotend. are you still using that?
@Veti has been parted out long ago.
after reading up on this thermister stuff, i see what you are trying to get after.
i dont think i have the info, but can find out by using a temp probe . Or just ordering some from amazon that the values are known. -
if you can establish the resistance at certain temperatures, then that would be perfect.
measure the resistance at something like 25, 120 and 240.
then use the https://configtool.reprapfirmware.org/Heaters click on the Beta value, select custom and enter those values.
It will calculate B and C for you. That would be more accurate as thermistors have variations that can lead to +/- 10 C.Failing to do that you can buy a thermistor.
Preferable a Semitec 104-GT2.
I personally use a PT1000 (no daughter board necessary) for hotend and bed. -
@Veti said in My corexy hbot configurations and build pictures:
I personally use a PT1000 (no daughter board necessary) for hotend and bedi understand, even with my current setup, i notice, its always overshooting the temp around 10 degrees, but then adjusts it to where it needs to be.
@tracar
that is an indication that you need to adjust the pid tuning.see
https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_controlIf during initial heating the temperature undershoots the target, reduce the A parameter. If it overshoots the target, increase the A parameter. Try increasing/decreasing it by 5% or 10%.
so 3724.2 would be a good starting point
what about
M303 H1 S240 ; auto tune heater 1, default PWM, 240C target or maximum temperature
M303 ; report the auto-tune status or last result
yes and save those values in your config.g
the results of the M303 H1 S240
M307 H1 was used to get this info after the M303 H1 S240:
Heater 1 model: gain 869.9, time constant 308.4, dead time 3.1, max PWM 1.00, calibration voltage 24.2, mode PID, inverted no, frequency default
Computed PID parameters for setpoint change: P20.7, I0.672, D44.3
Computed PID parameters for load change: P20.does it auto save this info? or how and where do i add this
Is it H-bot or corexy? AFAIK, it can't be both...
@mrehorstdmd hbot
so after auto tuning and creating this :
M307 H1 A869.9 C308.4 D3.1 V24.2 B0
where in the config.g do i place it?
what is the B0? for -
after the
M950 H1
commandB0 Disables Bang Bang and enables PID mode.
M950 H1
im still on firmware version 2.03 -
you should at least update to 2.0.5.1. That should work without config adjustment.
However at some point you have to invest the time to update to rrf3
in rrf2 place it after the other M305 commands.
like this ?
M305 P0 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 1
M307 H1 A869.9 C308.4 D3.1 V24.2 B0 -
yes. dont forget to pid tune your bed as well.
