    How to specify exact probing points in config.g
    226
    • deonholt
      deonholt last edited by
      Please help.
      How to I state exact probing points in config.g? I assume it has to be done with M557.
      For example:
      Probe X110 Y110 & X190 Y190
      Thanks.
      • Veti
        Veti last edited by
        its not done in the config.g but the homeall.g / homez.g
        • PCR
          PCR last edited by
          Probing for the Mesh bed Level?
          deonholt 1 Reply Last reply Reply Quote 1
          • deonholt
            deonholt @PCR last edited by
            @PCR said in How to specify exact probing points in config.g:
            Yes. Sorry, forgot to mention that. 😁
            • droftarts
              droftarts administrators @deonholt last edited by
              @deonholt Bed mesh is currently only defined by M557 https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M557_Set_Z_probe_point_or_define_probing_grid
              Are you trying to probe at just those two points? It's impossible to create a bed mesh from just two points. Or is that the minimum and maximum points? If the latter, try:
              M557 X110:190 Y110:190 P2
              Using the P parameter sets the number of points in each direction (X and Y). So a total of 4 points will be probed, at X110 Y110, X190 Y110, X110 Y190 and X190 Y190.
              If you're trying to level an axis at these points, which is different from mesh compensation, see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
              deonholt 1 Reply Last reply Reply Quote 0
              • deonholt
                deonholt @droftarts last edited by deonholt
                @droftarts thanks for the reply.
                No, I want at least 9, three in each direction. Want to know how to specify the probe points.
                I have just tried this:
                M557 X0:218 Y30:219 P3 (My bed is 218 x 218; Ender 5)
                It only probed 4 point and said it couldn't do more as it was out of bounce for the BL Touch. The nozzle needs to be at X45 Y0 to have the touch not probe in this air. But, I want my first probe to be at X55 Y30 and then from there work out the rest of the probes. But it cannot. This is why I want to enter the 9 points manually. (I hope my newbie terminology makes sense.)
                What I am not sure about, is this:
                Do I need to work with probe or nozzle positions? The offset between my BL Touch and nozzle is X45:Y12. I want the corner probe to be 30mm from each corner and the center probe to be at X110 Y110. But, If I enter those positions that is not where the probe is. The probe is 45mm to the left and 12mm to the front. And this is what confuses me and I cannot get any information about this. Do we enter probe or nozzle positions?
                Thanks for your help & time. I really appreciate it.
                Veti 1 Reply Last reply Reply Quote 0
                • PCR
                  PCR last edited by
                  What does your G31 Say
                  • Veti
                    Veti @deonholt last edited by
                    @deonholt said in How to specify exact probing points in config.g:
                    you need to adjust the x and y taking your offset of the probe into account.
                    so if the offset ist x30
                    it would become
                    M557 X30:218 Y30:219 P3 (My bed is 218 x 218; Ender 5)
                    • PCR
                      PCR last edited by
                      and where is the probe located ?
                      The Value of X0:218 is calculated with the offset of the probe. So if you have the probe on the left side of the printer it trys to prope at 218mm but you head is then over the limit of the x axis.
                      so if your probe is 20mm to the left try
                      X0:198
                      • deonholt
                        @PCR
                        G31 P500 X-45 Y-12.20 Z2.965
                        • PCR
                          PCR last edited by
                          then try
                          M557 X0:173 Y20:219 P3
                          Veti deonholt 2 Replies Last reply Reply Quote 0
                          • deonholt
                            deonholt @Veti last edited by
                            @Veti
                            This is my offset:
                            So, I need to know how to enter a single probe position so that I can see where it probes. I want to use X110 Y110 as a test.
                            • Veti
                              Veti @PCR last edited by Veti
                              dont forget the y
                              so
                              M557 X0:173 Y0:205 P3
                              • PCR
                                PCR last edited by PCR
                                @deonholt
                                @Veti is right try
                                M557 X0:173 Y0:219 P3
                                • Veti
                                  @PCR
                                  his bed is 218 so 218-12.2=205
                                  PCR 1 Reply Last reply Reply Quote 1
                                  • deonholt
                                    @PCR
                                    Thanks, will quickly try it. 🤞
                                    Update: It probed 6 points. It started off promising but stopped after 6 with these errors:
                                    G32
                                    Warning: Skipping grid point (0.0, 219.0) because Z probe cannot reach it
                                    Warning: Skipping grid point (86.5, 219.0) because Z probe cannot reach it
                                    Warning: Skipping grid point (173.0, 219.0) because Z probe cannot reach it
                                    6 points probed, min error -0.011, max error 0.049, mean 0.013, deviation 0.022
                                    Height map saved to file heightmap.csv
                                    • Veti
                                      @deonholt
                                      use the values i posted
                                      • PCR
                                        PCR @Veti last edited by
                                        @Veti long day 😉 You are right !
                                        • deonholt
                                          @Veti
                                          Thank you SO MUCH, guys.
                                          M557 X0:173 Y0:205 P3 did it. I REALLY appreciate your time & patience. 👏 🏅
