    Hemera goes wild! heat and no moving...
    Firmware installation
    966
    • duttiundefined
      dutti
      hey,
      I just installed the hemera anc changed some date in my config.g , but the hemera just make weird sounds and it´s going to be hot.
      Some Ideas what could be wrong?
      Thanks toall
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S0 ; physical drive 1.0 goes forwards
      M569 P1.1 S1 ; physical drive 1.1 goes forwards
      M569 P1.2 S1 ; physical drive 1.2 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1600.00 E409:409:409 ; set steps per mm ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z3000 E1330:1330:1330 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X700 Y700 Z800 S0 ; set axis maxima
      M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
      M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
      M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X10:600 Y10:600 S200 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out8" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0.8 H-1  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
      M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
      M671 X-19.5:99.5:99.5:-19.5 Y110:110:540:540 S2.5
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
      • Vetiundefined
        Veti
        what is getting hot. the nozzle, the motor or the entire hemera?
        • duttiundefined
          dutti
          the motor...
          • Vetiundefined
            Veti
            the motor is rated at 1.33A rated current.
            you should set it to 60-90% of the rated current.
            see
            https://duet3d.dozuki.com/Wiki/Setting_motor_currents
            try 75%
            • duttiundefined
              dutti
              ok.... 75% motor current. Still not moving, weird sound.
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti @dutti
                recheck the cabling. one phase might have disconnected.
                if that happens you get a loud sound and no movement
                • duttiundefined
                  dutti
                  ok... it´s not getting hot anymore.
                  I connected a different Nema and it´s working good. Connecting the hemera again and it´s still making this sound and no moving.
                  Is it possible that the cable need to connect different?
                  Are there different options?
                  thanks
                    Phaedrux Moderator @dutti
                    @barbarossa-cologne said in Hemera goes wild! heat and no moving...:
                    Yes, you must identify the motor phases for each motor and connect it appropriately. Not every motor is the same.
                    https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                    It could also be a loose crimp or bad connection.
                    Do you see any error messages in the gcode console?
                    duttiundefined 1 Reply Last reply Reply Quote 0
                    • duttiundefined
                      dutti @Phaedrux
                      @Phaedrux
                      When I connect my old normal nema 17, it´s working fine. So I don´t think it´s a wiring problem.
                        Does the motor have a plug of it's own or is the wiring internal to the motor?
                        • duttiundefined
                          dutti @Phaedrux
                          @Phaedrux
                          Plug
                            Well the problem as described would indicate that one of the motor phase wires isn't making a good connection at some point. If the same wiring works on one motor, but not the other, then it's most likely at the motor plug. Lucky it hasn't damaged the driver. Replace that motor.
                            • duttiundefined
                              dutti
                              ok.... so do you really think that the motor isn´t working correct?
                              tomorrow I´ll get a new E3D Hemera. Should I connect the new one to test it?
                              thanks!!
                                Well if you think the wiring is good and it does work with another motor, then the motor plug pin may not be up to spec. I may want to try with new wiring just to test the motor for sure.
                                • Vetiundefined
                                  Veti
                                  use a multimeter and measure the phases. see if each phase has the same resistance
                                  • duttiundefined
                                    dutti @Phaedrux
                                    @Phaedrux
                                    OK... I´ll connect the new motor tomorrow.
                                    • duttiundefined
                                      dutti @Veti
                                      @Veti
                                      resistance is fine.
                                      Thanks
                                      • Vetiundefined
                                        Veti
                                        have you tried a different cable?
                                          When using a motor with a plug on the body and a separate cable, you MUST confirm the phases with a multimeter or by other means, because the pinout of the connector is not standardised. Although if the cable was supplied by E3D as part of the Hemera kit, it ought to match.
                                          • mitchundefined
                                            mitch
                                            I found the hemera wiring to be different from my stock motor. I had to swap pins 3&4 when using the hemera.
                                            here is my wiring table i used with the duet:
                                            PDF: Extruder 0
                                            https://drive.google.com/file/d/1IE73tfQX7RgpArzxZJwyxEA-VIYsMFzE/view?usp=sharing
                                            https://www.randoprojects.com/2020/07/26/ender-5-w-hemera-and-duet-2/
                                            duttiundefined 2 Replies Last reply Reply Quote 0
