DWC 3.2.0 beta-1 is ready!
Get it here at the GitHub Repo. Of course, you have to build it yourself.
Shows data on the right, but no visualization
Can you please share your heightmap.csv? What board are you using and do you have an SBC attached (if applicable)?
Duet3 standalone with 3.2-beta1
heightmap.csvEdit: I reloaded DWC few times, and it started to work. Magic
Edit2: Or not... Worked only once, and same message now, but it does not even show data on the right side, only n/a everywhere.
I have the same problem. No expansions, heightmap.csv. Mine says Cannot read propery 'add' of null.
maybe this will help. got this error on refresh of page:
And here is the /www/js directory on the printer:
@chrishamm as soon as I unload all the plugins, all of my connection reset issues go away.
so i disabled all plugins, then only enabled the height map and it started working.. even though i'm still getting connection reset issues on random files..
I think the plugins are making connections outside the other threads and it's causing issues.. but i cant' really prove that.
@chrishamm had the same problem. A F5 "Refresh" solved it.
Best
should the visualizer work when simulating a print? nothing shows up.
I've found the visualiser tends to show off screen and needs to be zoomed out to see the display of the gcode
Visualizer just appears as a grey box. What's the best info to help diagnose?
I have this error when trying to load a height map
Here is the height map.
heightmap.csv
This height map was generated in 3.2 beta 1
@jay_s_uk same here so bumping this thread. Can we get someone to weigh in on what's happening and if there is a workaround? Thanks
It works fine for me on a couple of my SBC based printers but fails on the standalone
@jay_s_uk I failed to mention this is a Duet3/RPi combo that's throwing this error.
@devpeeps said in DWC 3.2.0 beta-1 is ready!:
Hope you don't mind but I find this post to be really confusing. It appears to be an "official" beta release similar to this one https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1601043732402. It's just that up until now, @chrishamm has always been the one who took care of DWC. Is your link the "official" DWC version or your own branch? If it's a link to the "official" DWC beta, are you now part of the Duet team and have you taken over from or are you assisting @chrishamm ? If it's your own branch of DWC, has does it differ from the Duet one?
@deckingman said in DWC 3.2.0 beta-1 is ready!:
+1 on this, a little clarification would be nice
I think it was just enthusiasm on @devpeeps part to share a link to the release. But that's just my read of it.
While @devpeeps links to the official github he is not part of the Duet team. To add confusion a link to the repo and a comment about having to build it yourself misses that there is a build included with RRF 3.2b1:
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta1
@T3P3Tony, @Phaedrux Thanks for the clarification guys - I was beginning to wonder if the Duet team had expanded or whether @chrishamm had adopted another pseudonym.
I think the post was from a time when I had DWC 3.2-b1 mostly ready but when I had not finished my first tests. Of course the official prerelease can be found on the DWC GitHub repo, too: https://github.com/Duet3D/DuetWebControl/releases/tag/3.2.0-b1%2B2
